Do You Turn On AC/Heat At Start Of The Engine?
Discussion in 'Technical Chat' started by tim920, Jul 7, 2010.
Heat/Ac on at start of engine?
Poll closed Apr 1, 2013.
  1. Yes
    88 vote(s)
    51.8%
  2. No
    82 vote(s)
    48.2%
  1. Jul 7, 2010 at 10:27 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Indirect air makes sense. An AC clutch cutoff switch would be in order there.
    If I remember right, put a switch on the control side of the AC's relay.
  2. Jul 7, 2010 at 10:43 AM
    ChompsterTacoma
    ChompsterTacoma Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    I have mine on immediately after start. It's hot here in the valley and my lil girl don't like it. I even idle it alot with ac running. I figured a vehicle is bought to be used so use it.
    P.S and the satellite station must be on Disney at all times even before I start the car!
  3. Jul 7, 2010 at 6:30 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    How can the electronic clutch for the compressor engage before the truck is on? When I start my truck, I clearly hear the truck start, then a second passes, and THEN the clutch engages bringing on the compressor. They do not start simultaneously.
    Furthermore, an A/C system in cooling is a dehumidifier. That is why you have a condensate drain. The water dripping on the pavement and running down the PVC drain attached to the air handler in your house is the moisture removed from the air. The refrigeration cycle was designed to be a dehumidifier, it wasn't until the condenser was moved to a remote location did they realize that it could be used to cool the air as well.
  4. Jul 7, 2010 at 7:38 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I'm from the same school.
  5. Sep 7, 2010 at 6:10 AM
    Barnone
    Barnone Guest
    Duh, this is 2010 not 1950. Time to get with it. If your vehicle won't handle a start with the a/c on then you got big problems.
  6. Sep 7, 2010 at 6:18 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I clicked no, But actually its both yes and no. Depends on the situation, if its really hot out and I'm just running in some where I might just leave it on. I would say normally I turn it off though. And now that I think of it I don't know why, Guess I'm just alittle old school myself and feel like it should'nt be on. Now with the heat in the winter, unless its defrost, I'll just leave it on. Just not a fan of the compressor being on at start up. Good question. Alot of different opinions on this.
  7. Sep 7, 2010 at 5:09 PM
    travelingman
    Brian
    Ohio
    07lb4x4DC
    We'll see in about ten years fella.You do it your way and I'll do it mine;)
  8. Sep 8, 2010 at 7:27 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The AC compressor is not engaged at engine startup. If the AC is on when the ignition is turned off, when the engine is started, the AC compressor is not engaged, then after 3-5 seconds or so the AC compressor will engage. I know this as I have an electric fan wired into the AC clutch engagment signal so that the electric fan comes on whenever the AC compressor is engaged.
  9. Sep 8, 2010 at 8:18 PM
    Barnone
    Barnone Guest
    Duh,
    I've had my 2002 since new so I'm coming up on nine years, fella.
  10. Sep 28, 2010 at 12:03 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    10 years as of next month with 297k on the odo with original A/C components and no engine problems - my A/C is almost always ON. I've never even taken the caps off the A/C lines.
    Turning the A/C off before starting a vehicle is much ado about nothing.
  11. Sep 28, 2010 at 1:53 PM
    v8killerturbo4
    v8killerturbo4 Member
    Ft Worth Texas
    2010 TRD Sport 4x4
    Stock!
    Having your AC on or off at start up doesn't make a difference. As stated before the AC is technically off while cranking the engine even if the knob is set in the "on" position. While cranking, all power is sent to the starter to turn the motor over, once the motor starts, accessories are then powered. Leaving your AC off then turning it on after the motor is started is the same thing the truck does automatically. All vehicles operate this way.
  12. Oct 3, 2010 at 12:25 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I start the truck then turn on the AC and I turn the AC off before I turn the truck off...I don't use a heater cause I live in AZ :)
  13. Oct 3, 2010 at 6:02 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    X2 I do the same.
  14. Nov 4, 2010 at 4:03 AM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    Having the a/c at startup won't hurt anything I wouldn't think. The belt is still there for the compresser whether it is on or off, and besides I don't think it turns on until after the engine has been started. But usually if it is cold outside I wait until after I've driven a few miles and the engine temperature gauge just starts to move to turn on the heat, because otherwise cold air will just come out and blast me in the face.
  15. Dec 21, 2010 at 9:38 PM
    #35
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Nothing special for start up. But for shut down I turn off my a/c and blow out the the cold air to get rid of the moisture during the summer months.
  16. Jan 11, 2011 at 6:13 PM
    #36
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    A/C yes, heat no.
  17. Jan 15, 2011 at 11:38 PM
    #37
    Przemekmsu
    Przemekmsu Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    I am a creature of habit and I turn everything OFF (Heat/AC, Radio, Lights etc.) before I turn the engine OFF. Then I don't turn it back ON until my engine is ON and ready to go. I was told that having everything OFF when turning the engine ON it saves your battery, starter, and alternator. I don't know how much truth is in it but I just do it.
  18. Jan 15, 2011 at 11:44 PM
    #38
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    gen 1 and 2??? also what about defrost/floor???
  19. Jan 16, 2011 at 10:10 AM
    #39
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Me too, but since I have gotten this truck I leave the lights on. I'm a fan of them shutting off on there own. Even if me turning things off doesn't do anything I still do it.
  20. Oct 8, 2011 at 10:45 AM
    #40
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I have always been taught to do this, but on the other hand with many of today's cars having the automatic climate control, not sure it really matters? :notsure:
