Do you use a washer on the oil drain plug?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SamS, Jan 28, 2011.
  1. Jan 30, 2011 at 1:12 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I'm still using the one that came from the factory on my 07. I have about 12 oil changes on it and never a problem.
    To the OP, just keep an eye on it and next time u change the oil, just slap one on.
  2. Jan 30, 2011 at 1:22 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I got my dealer to lower the price on the drain plug washers from $1.50 to 50 cents ea. I've been putting new ones on every oil change but I think I'll start doing it every other. Alot of hardware stores sell crush washers that will fit our trucks for a pretty good price also.
  3. Jan 30, 2011 at 5:51 PM
    SamS
    SamS [OP] Well-Known Member
    Vancouver Island, BC, Canada
    06 Access cab 4x4
    Yep, that's what I'm going to do. It seems OK for far... no drip in the past couple days. I saved the washer so will put that one back on at the next oil change.
    BTW, I'm not sure what kind of washer it is. It looks solid metal, black in color when viewed from top or bottom, but on the side view there is a lighter color in between the black sides. It looks solid enough to be able to re-use.
  4. Jan 31, 2011 at 2:40 AM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
  5. Jan 31, 2011 at 3:41 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Still got the original one on mine. 54K miles later, still no leaks knock on wood.
  6. Jan 31, 2011 at 4:13 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If it was that important to use a fresh new one every time, it would come in the box with the toyota filter.
  7. Jan 31, 2011 at 4:45 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    1 minute to fill out time sheet ???:rolleyes:
  8. Jan 31, 2011 at 5:30 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    x100
  9. Jan 31, 2011 at 5:33 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Who wants to buy Fumoto? Not gonna use it on mine..........
  10. Jan 31, 2011 at 5:52 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Use the washer... It's there for a reason...:pccoffee:
  11. Jan 31, 2011 at 6:07 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    always using washer...fumoto? not so much.
  12. Feb 2, 2011 at 2:44 AM
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    How much?
  13. Feb 2, 2011 at 5:48 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    Hey all you guys that don't install a new washer at every oil change, do you work for Jiffy Lube?
    O'DubhGhaill and Mush Mouse like this.
  14. Feb 3, 2011 at 6:00 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I am very careful to put the tape at the base of the bolt only. Oil does not seem to erode the tape at all and I have yet to have a problem using this method on any car or truck I ever owned.
    I wouldn't put it over the entire thread to be sure it didn't get into the pan but at the base of the bolt it seems to do the job quite well and I only use about two wraps around the bolt.
  15. Feb 3, 2011 at 10:45 AM
    #35
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Never has with mine. I believe you'll find teflon is impervious to pretty much any fluid you're likely to use in a car. Indeed, to even dent the stuff you have to use some pretty nasty acids (hydrofluoric acid).
    I think the concern with teflon tape is that people put too much on so bits get cut off by the threads and then contaminate the thing your sealing (really bad with gas appliances). Careful application prevents that.
  16. Feb 3, 2011 at 5:28 PM
    #36
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    Did the first oil change on my 2010 2.7L yesterday. There was no washer there. Drain bolt is a one piece bolt with a flange that looks like it would serve as a washer. Anyway, I replaced it without a washer. It's not leaking.
  17. Feb 3, 2011 at 5:39 PM
    #37
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    x2
  18. Feb 3, 2011 at 5:43 PM
    #38
    dirtfondler
    dirtfondler Well-Known Member
    San Jose, CA
    00 F250 7.3L Diesel
    BMW and Mercedes both include crush washers and o-rings with their filters. There may be other manufacturers too, but those are the only others I have experience with.
  19. Feb 3, 2011 at 6:00 PM
    #39
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    on first oil change I take the drain plug to parts store or napa and get a nylon washer for drain plugs, making sure that its a snug fit on the threads so it doesn't fall off when I change oil. 83 toy went 183000 miles with same washer never a drip [sold it] 06 is at 83000, same thing no drips
  20. Feb 3, 2011 at 7:56 PM
    #40
    05SuperChrg
    05SuperChrg Well-Known Member
    SF Bay Area
    TRD Supercharger, TRD Air Filter,Rancho 9000's, Old Man,Fumoto Oil Drain Valve,Kenwood Sub, Sony HU,Wet Okole, debadged,satoshi,Slee Sliders
    One minute to pee after drinking the beers. :)
