Do you use the Rear Window?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gizzygone, Mar 24, 2010.
  1. Mar 24, 2010 at 4:54 PM
    sprinja
    sprinja hah ...member
    NC
    08 BSP DC Sport
    Can't reach it from the drivers seat, but I use it a good bit. Sunroof and back window open combo is perfect, much less wind noise even on the interstate.
    When they put in my sunroof, I sacrificed my overhead console, but the compass is still there. Totally worth it though.
    And x2 on the easy cooler access too.
  2. Mar 24, 2010 at 4:56 PM
    planman
    planman Member
    Mississippi
    06 DC PreRunner SR5
    Fog light mod, DTRL mod, Undercover bed cap, Console mtd. Ipod,Console lock,maplight/ dome light mod, homelink receiver install
    I've had my truck for 4 years and I'm not sure if it will even open.:eek:
  3. Mar 24, 2010 at 5:19 PM
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    Indespensible, IMHO. Use it all the time!
  4. Mar 24, 2010 at 5:19 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I open mine all the time. Its great for the dogs to stick their heads out of. They love it. I'm 6 1 and I can reach it but its a bit of a strech for me. I have to really lean back and make sure i'm driving in a straight line before I do it.
  5. Mar 24, 2010 at 5:19 PM
    Stirlinglyon
    Stirlinglyon Member
    Ken
    Dana Point, Ca.
    06 Prerunner SR5 Debadged
    Tonneau cover-Grill-added lights-
    As a contractor I have used the window many, many times. A 12ft. plank fits 3ft. inside the cab, 6ft. over the bed, and only 3ft. out beyond the tailgate. This can be a work vehicle, you know!!
  6. Mar 24, 2010 at 5:19 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    I use it all the time??
  7. Mar 24, 2010 at 6:06 PM
    centraltaco
    centraltaco Well-Known Member
    Central, Louisiana
    '10 Dub cab 4x4
    Man, I use mine all the time. My son sits in the back and I get him to open it up. Sort of like having a rear window remote. It regulates air very well with just cracks in the front windows. I also have vent visors on the front 4 windows.
  8. Mar 24, 2010 at 8:33 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I use mine all the time. I have a cap so I open that window, the front window in the cap, and I open the vent side windows on the cap...gets some fresh air moving without too much wind in the cab.
  9. Mar 24, 2010 at 8:48 PM
    airsoft_warrior
    airsoft_warrior Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    my weather stripping comes off too. I just push it back into place and it is okay again.
  10. Mar 24, 2010 at 8:48 PM
    SURFTACO
    SURFTACO Well-Known Member
    New Jersey
    09 TRD SPORT
    3'' Lift: Bilstein 5100’s, SPC UCAs, All Pro 3” leaf packs, Bilstein 5125’s, Kenda 33X10.5R17 Tires Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover Cali Raised Ditch Lights Snorkel
    Ill try to remember to open it, but usually it stays closed. Once in a while I'll open it.
  11. Mar 24, 2010 at 8:49 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Same here. On days when it's around 100 degrees I like to open up the rear window and the snug top window while parked to help cool everything.
    Take the time to tighten up the screws that are used for the window lock on the rear slider...had a screw come out the other day after offroading. I reinstalled them with lock-tight so it doesn't happen again.
  12. Mar 24, 2010 at 9:09 PM
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    I have that same problem with the weather seal on mine. In fact, it is messed up right now. It's a bitch to get that thing back on there right- for me at least.
  13. Mar 24, 2010 at 9:10 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I love the little back window. I use it a lot when camping. I'm looking for some kind of no-see-um mesh screen I can use for the window. If anyone has any good ideas for a custom solution please let me know!
  14. Mar 24, 2010 at 9:12 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I don't use it, too damn far away. should have been electric.
  15. Mar 24, 2010 at 9:13 PM
    #35
    callahansd
    callahansd Guest
    hell iv put an extension cord from my bed outlet through the window, still closes, and i can shave on the way to pt
  16. Mar 24, 2010 at 9:20 PM
    #36
    Freelance
    Freelance Well-Known Member
    Curtis
    Las Vegas, NV
    07 DC PreRunner SR5
    Had to charge my phone like that once, all ghetto-like.
    I do use mine a lot though. During the 5-6 weeks per year where the air is nice here in the desert.
  17. Mar 24, 2010 at 9:22 PM
    #37
    OffroadToy
    I open it and the canopy slider so the fishing poles fit in the bed.
  18. Mar 24, 2010 at 9:26 PM
    #38
    EBBS03
    EBBS03 Well-Known Member
    Rob
    Philadelphia, PA / Morgantown, WV
    '10 Tacoma TRD 4X4 Off Road
    Stock
    I love using mine.
  19. Mar 24, 2010 at 9:27 PM
    #39
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Cant reach it. I barely even use it to be honest with you.:eek: Only thing I use it for is the TacomaWorld.com sticker on the backside of it!!!:D
  20. Mar 24, 2010 at 9:48 PM
    #40
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    I have a Engle fridge mounted in the back seat, Runs most of the time. I open the back to keep cab temps down while i am parked. Compressor runs a lot less.
