Do you use two grease guns or one?
Discussion in '4Runners' started by Northwoodshyun, Feb 19, 2019.
  1. Feb 19, 2019 at 6:26 PM
    Northwoodshyun
    Northwoodshyun [OP] Well-Known Member
    St. Paul MN
    Toyota specifies two different greases for 4Runner. I know the dealer only uses one type.
    Do you use molybdenum disulfide lithium based chassis grease for the slip yokes only? Then use lithium based grease for the spider bearing?
  2. Feb 19, 2019 at 6:29 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    just use one or the other type of grease you wont need 2 grease guns it uneccesary
  3. Feb 19, 2019 at 6:31 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just one.
    It's grease. Push in new grease and push out old grease and contaminates. It's not worth spending time overthinking.
    Grease the truck once a year and you will be doing more than 90 percent of the population does.
    I like the red and tacky grease.
    The fact that you are using grease on a regular basis, far outweighs whatever grease you use.
  4. Feb 19, 2019 at 6:46 PM
    Northwoodshyun
    St. Paul MN
    spider greasing is easy because you grease until the new grease comes out. For slide yokes, how many times do you pump? which grease do you use?
  5. Feb 19, 2019 at 6:48 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Which ever grease no more than 3 pumps. You can hydro lock the slip yoke.
    koditten likes this.
  6. Feb 19, 2019 at 6:50 PM
    koditten
    Kirk
    Central Michigan
    The only issue is on my 1st Gen Tacoma is I need a special grease nozzle for the front drive shaft. Regular nozzles won't fit.
  7. Feb 19, 2019 at 6:50 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Just a funny aside, when I finally talk the wife into giving up our sequoia it's a 4runner to replace it.
  8. Feb 19, 2019 at 6:53 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Really? Got a pic?
  9. Feb 19, 2019 at 6:55 PM
    koditten
    Kirk
    Central Michigan
    This is funny. I want a saquoia to replace the wife's Tacoma.
  10. Feb 19, 2019 at 6:57 PM
    koditten
    Kirk
    Central Michigan
    No. Not gonna crawl under the thing for this. I just know the front diffy ujoint is a bitch to lube.
  11. Feb 19, 2019 at 6:58 PM
    Northwoodshyun
    St. Paul MN
    it is only -5F today.
    koditten[QUOTED] likes this.
  12. Feb 19, 2019 at 6:58 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    I've got a 04 4x4. 186,000 miles on it. Now that all 6 boys are grown, its overkill. I put big ass tires on it and pulled the running boards. Looks good
