Do your brakes feel different since your lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OCTaco, Jun 7, 2010.
  1. Jun 7, 2010 at 9:44 AM
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    My truck has a 3” lift in the front, but nothing in the back. Every now and then when I release the brake, I can feel the truck move/jerk. I’m not sure if this is what you call “axle wrap”. I had an 06 that did something similar, but not quite the same. It turns out the valve body was going out on the 06 but I’m pretty sure that’s not what’s going on with this one. I’m just wondering, How I can fix this? Also, like many others here, my brakes are kind of mushy. I recently had the brake fluid flushed and I’m thinking about checking the rear brakes for adjustment, does anyone have any advice. Or has anyone encountered this before?
  2. Jun 7, 2010 at 10:17 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    My truck is stock and once I park it, engage parking brake, release the brake mine rolls forward at least an inch. I don't think it's lift related but I too would love to learn why this happens.
  3. Jun 7, 2010 at 10:27 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    No difference in brake action with 2.5 lift. No mushy brake pedal either & fixin to be lot less of nonmushy pedal when the extended rear ss brake lines go on the truck. Brake wear has been excellent and even on all 4 corners - stock rotors/pads.
  4. Jun 7, 2010 at 11:31 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    You may need to have the dealer recal. your VSC.:thumbsup:
  5. Jun 7, 2010 at 12:19 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    HOW do you do this? I've never heard of it. Is there a TSB for it? Have you any idea what the cost is? is VSC the same as ABS?
  6. Jun 7, 2010 at 12:22 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    No need to show off :(
  7. Jun 7, 2010 at 12:29 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    not since my lift but since I put 285s on yes. look at wheelersoffroad for the extended braided brake lines. probably one of the best $100 iv spent on my truck
  8. Jun 7, 2010 at 12:37 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Was it a huge difference? What would you rate it between 1and 10, 10 being the best.
  9. Jun 7, 2010 at 12:44 PM
    toku58
    Mall Crawler!
    It's something the dealer needs to do. Others have had issue when they lifted their trucks with VSC. The lift makes it go out of wack. I don't remember if it was here or on TundraTalk that I was reading about the dealer recalibrating the VSC, after a lift is installed.
    I'm glad my truck doesn't have that.
    The stainless brake line give your brake pedal a firm feel. I run 35" tires and my brakes work just fine. It's all stock.
  10. Jun 7, 2010 at 12:44 PM
    dylandercole
    Dylan
    hmmmm I would say it doubled my stopping power and overall feel of the brakes. Im going to rate it an 8
  11. Jun 7, 2010 at 12:47 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    If you have an 06 you probably don't have the VSC.
  12. Jun 7, 2010 at 12:49 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Nice! How hard was it to do? Would a novice shade tree mechanic like myself be able to do it? I always do my own brakes, and I did my own brake fluid on my truck.
  13. Jun 7, 2010 at 12:52 PM
    toku58
    Mall Crawler!
    If you know how to bleed the line? It's easy!;)
  14. Jun 7, 2010 at 12:55 PM
    toku58
    Mall Crawler!
    Yeah you're right! I miss read his OP. I know he said he had an 06' but I did catch the part about the present truck being an 06'.
    I was thinking he had a 2010.
    Sorry about that!
  15. Jun 7, 2010 at 12:56 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    No worries, thanks for the advice either way.
  16. Jun 7, 2010 at 2:00 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i dont get it. when you release the brake..isnt the truck suppose to move?
    i also have an '06. no brake issues with my minor lift.
  17. Jun 7, 2010 at 2:03 PM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    I run 35's with everything stock too, stops fine
  18. Jun 7, 2010 at 2:10 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Yea, but it jerks right when I release the break. It's hard to explain.
  19. Jun 7, 2010 at 2:51 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Just throwing this out there: look into "slip yoke binding" in the driveshaft. Mine did the same, also "thumped" when coming to a stop. Dealership greased the slip joint and the problem was gone. Seems to be a fairly common problem from what I could read. My thump is coming back though so I'll tear it apart and grease it with Molykote... I dont think the dealership used molybdenum grease on mine.
  20. Jun 7, 2010 at 3:41 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    I had this in my 06 and servicing the tranny worked. Mine is an auto and from what i hear the slip yoke is inside the tranny so it cant be greased up. Is there a write up on this somewhere?
