Dobinson Leaf Pack or Toytec AAL?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FL_TRD Sport, Jun 19, 2023.
  1. Jun 19, 2023 at 2:34 PM
    FL_TRD Sport
    FL_TRD Sport [OP] Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I'm sure this question has been asked before but I am a suspension noob so please bear with me. My truck has a new ARE CX series topper and it cut my rake down to just about 1 inch. Since I'm sure this will go down more over time with the constant weight I'm looking at options for the rear to deal with it. I went to my local shop and they gave me a couple of choices....sumo springs (or Timbren), Toytec AAL, or new Dobinson L59-112R leaf packs. The sumo option we pretty much ruled out as the least desirable, leaving the AAL or full leaf pack replacement. He said they've used the AAL as the first option in cases like mine where it's just the topper and no real additional weight or hauling on a regular basis, and it's worked well with the ride not being overly harsh. "Acceptable ride" were the words he used lol. The full leaf pack replacement is what he said would give the best ride result but there is about a $700 price difference between the two options. He actually didn't push me one way or the other, just laid out the options and said look at your budget and think about which you'd prefer. They will do either one.
    I don't ever plan on lifting the truck (it's a 4x2), and I don't want a stiff, harsh ride. Besides towing my Honda Goldwing on a UHaul trailer a couple of times a year and the occasional Lowes run I don't tow or carry a huge amount of weight. I'd welcome recommendations on which option to choose. Thanks! :)
  2. Jun 19, 2023 at 5:31 PM
    Tucker2020!
    Tucker2020! Well-Known Member
    AAL for you. Only reason I went from AAL to a full leafpack was because I over the course of time added an RTT, Decked drawers and an RSI SmartCap.
  3. Jun 19, 2023 at 7:14 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Makes sense. That's a lot more weight. How was the ride with the AAL?
  4. Jun 19, 2023 at 7:17 PM
    Bishop84
    Bishop84 Well-Known Member
    AAL, pack later when it gets flat.
    AAL's ride like factory as long as there's weight, even the topper negates the harshness.
    FL_TRD Sport[OP] likes this.
  5. Jun 19, 2023 at 7:19 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    AAL makes my wallet much happier :)
    auskip07 likes this.
  6. Jun 19, 2023 at 8:48 PM
    Tucker2020!
    Better than stock - didn't bounce as much but that may have been due to the 5100s. It wasn't stiff though.
  7. Jun 19, 2023 at 8:53 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I have a toytec aal. It’s a 3 leaf pack as opposed to just one leaf. Nice ride worked well with toppers, I had a smart cap, decked, and snugtop. But now it’s empty with a victory4x4 bed rack Still maintained good rake with a topper. But my front end is heavy, and has ome 886 up there
  8. Jun 19, 2023 at 9:15 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Forget ALL, it’s going to sag and leave you disappointed.
    After adding my shell, I had the same problem as you. I went with a dakar medium duty leaf pack, and it got me back to stock height but a few years later, keeping some weight in the bed, it sagged a bit.
    if I were you, I would just get dakar heavy duty springs, that way you can carry weight and it wont drag ass.
    I mean the dobbo springs are good too but their HD is for even more weight, true aussie overlander canopy weight, and i would expect it to ride rough if you’re not loaded out.
    edit:
    And I see you’ve got a long bed! Think you’d be happier with a leaf pack, even if you just go dakar mediums
  9. Jun 20, 2023 at 8:38 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I have the dobby 112s with only a diamondback cover and some odds and ends. I do have steel skids. And it is not rough riding at all! Quite a bit of rake so I just took a leaf out.
  10. Jun 20, 2023 at 9:37 AM
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    I think an AAL would work well for your application. If you were planning on adding more weight in the rear I would definitely recommend a pack, but since it's just a topper and some light towing AAL will be fine and wayyy cheaper.
