Dobinson strut assembly question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 23tacotrd, Nov 25, 2023.
  1. Nov 25, 2023 at 7:43 AM
    23tacotrd
    23tacotrd [OP] Member
    23 TRD OR 6spd
    So I just received my dobinson lift and the parts are gs59-221 strut with 314 springs reusing factory top mounts sense they have 2800miles. So they came with 12mm spacers separate from the semi assembled strut and we are unsure where they go. I know a normal assembly is strut then dust shield then large washer then bushing then tapered or coned washer then mount then bushing then large washer then locknut where does the 12mm spacer go? The other question is spring orientation. one side is larger and ground flat and the other is slightly narrower and not ground flat, still round at spring end. what is the proper direction the spring goes on strut? Just trying to clarify all this so there is no guess work when I assemble because I can only use lift and shop for a short amount of time. Thank you for your help
  2. Nov 25, 2023 at 7:58 AM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Where did you buy them from, maybe they can help?
  3. Nov 25, 2023 at 8:14 AM
    23tacotrd
    23 TRD OR 6spd
    Closed until Monday and wasn’t able to go through it all until after they closed yesterday
  4. Nov 25, 2023 at 8:15 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    908tacoma likes this.
  5. Nov 25, 2023 at 8:19 AM
    23tacotrd
    23 TRD OR 6spd
    Yeah I found that last night has no mention and doesn’t shows the 12mm spacer
  6. Nov 25, 2023 at 8:24 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Don't know of this helps.
    Passenger side
    Driver side
  7. Nov 25, 2023 at 8:30 AM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Could it be for driveline extensions for carrier bearing?
  8. Nov 25, 2023 at 9:47 AM
    23tacotrd
    23 TRD OR 6spd
    So I ordered the quick ride setup. One box was blocks and u bolts one box was rear shocks one box coil springs one box front struts with washers and bushing in place in proper order then capped and strapped together then 2 12mm spacers zip tied to one strut. Packing slip mentions all boxes and same line as strut and circled (include 2 12mm droop spacers)
  9. Nov 25, 2023 at 10:41 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    How's that handle? I thought you had to tighten them so much that that bushing expands to the width of the washer?
  10. Nov 25, 2023 at 10:51 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    It's been like that for 50K miles. No complaints what so ever. I'm not a suspension guru......so I may be doing it wrong :rofl:
    Edit: I just looked at some google pics......theirs are all flatish....so I may need to tighten them up :D
  11. Nov 25, 2023 at 11:02 AM
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    Photos of said 12mm spacers will be helpful.
  12. Nov 25, 2023 at 11:18 AM
    23tacotrd
    23 TRD OR 6spd
  13. Nov 25, 2023 at 11:48 AM
    23tacotrd
    23 TRD OR 6spd
    There is no were it could go on the lower control arm rough measurement would be would be 12mm tall 16mm around with 10mm hole. No other packaging in that box. Only other separate packaging is in the rear shock box with different size metal bushings for different applications. Like I said on the listed packing slip it is listed to include 12mm spacers with front struts. The only place it like it could go is in between the dust shield and lower bushing washer
  14. Nov 27, 2023 at 4:07 AM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    I m pretty sure Ive read they go on the strut shaft, I believe on the underside of the "top hat" to shift the shaft down and allow extended travel on the coilover down to the max. Im not sure if your arms will hold you up or not. Have you asked @Crikeymike ?
    Edit: Just read this and it sounds confusing.
    Remove all bushings and washers.
    Install the 12mm sleeve.
    Then reinstall washers and bushings.
  15. Nov 28, 2023 at 6:53 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    In case this comes up in the future, it adds droop to the strut. It goes on the strut shaft first, then the bushing sequence. It's suggested to be used when the lift height is higher so the strut doesn't top out as easily.
