Dobinson vs Dakar leafs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JacNus22, Jul 15, 2023.
  1. Jul 15, 2023 at 12:46 PM
    JacNus22
    JacNus22 [OP] Member
    Jacob
    2013 Mag grey Tacoma
    Hello! Looking to upgrade the stock leafs in my 2013 DCLB. 24/7 have a RTT + bed rack. Looking to upgrade rear bumper in future as well. From my understanding the heavy pack would be the way to go? Therefor I’m torn between these 2 packs I see on here a lot. Any and all input is greatly appreciated :) thanks in advance!
    https://exitoffroad.com/product/dobinsons-rear-leaf-springs-pair-for-toyota-tacoma-2005-to-2023-l59-111-r/
    VS
    https://www.extremeterrain.com/old-...-rear-leaf-spring-for-275-in-lift-el096r.html
  2. Jul 15, 2023 at 12:50 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Icon RXTs. OMEs are known for squeaking.
    Oreo Cat and JacNus22[OP] like this.
  3. Jul 15, 2023 at 12:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    My Dakars are squeaky af
    Looking at Deavers soon
    Superdave1.0, PNW15 and JacNus22[OP] like this.
  4. Jul 15, 2023 at 2:19 PM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    my deaver stage 2's squeak
    b_r_o likes this.
  5. Jul 15, 2023 at 3:09 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Just installed Dobinsons L59-111r on my 09 Access Cab got about 3" lift but that's about what I wanted. I don't drive much right now either, so should settle. No squeek yet! I put their greasable bolts in the leafs also and replaced shackle hangers too. With all this said I replaced my whole suspension with Dobinsons and SPC UCA's got 3" lift all around.
    RCRcer likes this.
  6. Jul 15, 2023 at 3:10 PM
    Tiedie
    David
    WFOY
    Exit Offroad for the win. @Crikeymike will set you up. Hit him up
    Hayden334 and Crikeymike like this.
  7. Jul 15, 2023 at 10:04 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    I’ve got the Dakar pack. Squeaked initially. Greased up the plastic pads some more and nothin since. You planning to upgrade shocks too?
    pahaf and Superdave1.0 like this.
  8. Jul 15, 2023 at 11:01 PM
    JacNus22
    Jacob
    Probably but not 100% sure what to upgrade with yet. Currently running billy 5100’s
  9. Jul 15, 2023 at 11:14 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    All leafs squeak. Even stock. Deaver FTW as far as performance and longevity.
    PNW15 and b_r_o like this.
  10. Jul 16, 2023 at 2:30 AM
    TacoTuesday1
    SD CA
    RXT or Deaver.
    RXT is customizable and handles most things. They yield ride improvement.
    Deaver costs a bit more and is probably a bit better, by how much I don't know.
    I know one reason people get Deaver is because they have to for their build and don't have a choice.
    Like if the truck carries basically a house on the back, RXT won't handle that and custom Deaver will be needed.
    RCRcer and Superdave1.0 like this.
  11. Jul 16, 2023 at 2:53 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Have the OME HD on since 2015 and never an issue raised rear about 3". Only had to change the rear hanger polys (yellow OME) after 6 years probably the sand and salt eat them. They came with rubber fronts and they are still OK. They are stiff but when towing up near max the back is level. Rear 5100s and front 5100s on 3rd notch stock springs up about 2". So unloaded or no tow has a slight rack OK with me. Many opinions just my info FYI.
  12. Jul 16, 2023 at 2:59 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Dobinson for sure in your case. Chevy 63s are the true upgrade at the end of the day though.
  13. Jul 16, 2023 at 2:17 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    About everyone saying the deaver squeak.
    They do, that is true.
    When they Seqeak, I just pressure wash the dirt and grime off, and add grease between the pucks. And it’s silent for another 2 years
    GilbertOz and RCRcer like this.
  14. Jul 16, 2023 at 2:22 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    That's inherently not true. My ATS leafs have never made a sound. Highly recommend. They'll happily build you a custom pack to whatever you want and cheaper than most other brands
  15. Jul 16, 2023 at 8:38 PM
    Superdave1.0
    SoCal
    *yet
    Lt. Dangle likes this.
  16. Jul 16, 2023 at 8:40 PM
    Wyckedan
    Dan
    Woodinville WA
    They're 2.5 years old. How long do I have to wait?
  17. Jul 16, 2023 at 9:13 PM
    Superdave1.0
    SoCal
    Until they squeak. :thumbsup:
    SIK99Tacoma and TireFire like this.
  18. Jul 17, 2023 at 5:02 AM
    Weissenheimer
    Weissenheimer Well-Known Member
    Bryan
    Southern Maine
    05 TRD O/R (desert sand mica)
    FN FX wheels, Dobinsons suspension, air bags, other bells and whistles
    My vote is for Dobinson. I did a lot of research and they were the happy medium where Deavers are the ultimate upgrade but a little out of my price range. I quickly ruled out Dakars due to the squeaks and also the fact that many people who really use their trucks said they go flat very quickly. And that is no good. Been almost 2 years running Dobinsons with NO issues. 112s in the back, 2.5" lift coils (IMS struts and "stock" rate coils (still stiffer than actual stock but just right IMO). I haul a 1600 lb slide in camper and take that on logging roads often. I am very happy with it.
    SIK99Tacoma and Tiedie like this.
  19. Jul 17, 2023 at 5:09 AM
    TacoTuesday1
    SD CA
    Chevy 63 looks cool and has lots of travel
    but isn't it not the best due to supposedly not handling weight added to the truck?
    ie 200lb shell, etc.
  20. Jul 17, 2023 at 7:43 AM
    sbMT
    sbMT Active Member
    Montana
    ‘09 Off-Road Access Cab
    I upgraded my leafs to the Dakar heavy packs about a year ago. 2009 access cab. Keep a pop-top shell and drawers in the bed 24/7, maybe 450-500 lbs extra weight without gear. I’ve been happy with the setup, especially at this price point. Greased up the bushings and plastic pads at install and squeaking has been minimal over the past year and ~15k miles, mostly hard loaded miles in the mountains and desert.
