Dobinsons 16+ Taco Suspension
Discussion in '3rd Gen. Tacomas (2016+)' started by Crikeymike, Feb 7, 2017.
  1. May 15, 2021 at 8:24 AM
    #1081
    fflo81615
    fflo81615 Well-Known Member
    2017 Tacoma TRD OR
    Does this go for the black 940 rear shocks as well?
    CygnusX191 likes this.
  2. May 15, 2021 at 9:46 AM
    #1082
    Crikeymike
    Crikeymike [OP] Well-Known Member Vendor
    Jax Beach, Florida
    Those haven't even left the factory yet.
    FYI, the leaf springs were made in January, just to give you an example of how long it takes parts to get shipped from overseas right now.
  3. May 16, 2021 at 6:46 PM
    #1083
    awynne56
    awynne56 Well-Known Member
    Andy
    2019 Taco trd sport
    front grill pro
    I have 221 springs and shocks from dobinson
  4. May 22, 2021 at 3:49 PM
    #1084
    thefreshtaco
    thefreshtaco Well-Known Member
    Indianapolis Indiana
    2016 White TRDOR DCSB M/T Tech
    Anyone have any MMR settings they feel are good? Manual says to start all at one and move on from there. Anxiously waiting for the rest of my stuff to come in, but managed to get the archive garage hammer hangers installed today.
    RyanDCLB and CygnusX191 like this.
  5. May 22, 2021 at 6:39 PM
    #1085
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Is there an estimated lead time?
  6. May 23, 2021 at 8:27 AM
    #1086
    thefreshtaco
    Check the top of exitoffroad.com it's updated there.
  7. May 31, 2021 at 9:14 PM
    #1087
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coil overs w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, Bushmaster bolt on wheel well flares CaliLED DOM Steel Rock Sliders, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro rear monotube shocks, Factory TRD Pro front aluminum skid with RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY) & a ProComp switch panel control module, Valley Runner custom ECU tune... as of today. The more I play with it, the bigger it gets!
    I have a 2020 TRD Pro, just put on the Dobinsons MRA/MRR coil overs in the front and after flexing the suspension on a quite a few runs they have settled in to a 5/8" difference between left and right... Still have the Tacoma droop. Of course I do have a Group 31 Odyssey AGM Battery, Steel front & rear bumpers w/12k winch and full steel skids nose to tail including gas tank... So definitely more weight on driver side. The new coil overs really, really articulate well, took them on the Rubicon this weekend and they are performing much better than the stock TRD Pro Fox Factory 2.5 did... Huge fan of Dobinsons Products, I even have their heavy duty rear leaf pack, just saving my pennies for the rear MRA extended travel shocks to match the fronts & the leafs...
  8. Jun 1, 2021 at 8:04 AM
    #1088
    Crikeymike
    Jax Beach, Florida
    Wow, on the Rubicon??!! Now you've gotta share some photos of that!!
    Glad to hear they're performing well for you!!
    MountainManGuy and CygnusX191 like this.
  9. Jun 1, 2021 at 2:31 PM
    #1089
    Sierra Trail Pro
    Kelly
    Cameron Park, CA
    Here you go!
  10. Jun 1, 2021 at 2:42 PM
    #1090
    Crikeymike
    Jax Beach, Florida
    That's awesome!! Thanks for sharing
    Dirk Diggler and CygnusX191 like this.
  11. Jun 3, 2021 at 12:45 AM
    #1091
    Sierra Trail Pro
    Kelly
    Cameron Park, CA
    Hey brother, do you happen to have the DOBINSONS HIGH CLEARANCE OUTER CV STRETCH BOOT KIT in stock by any chance? I tore the outer boot on my passenger side... If I'm going to replace it, I'd rather use the Dobinsons kit than the OEM...
  12. Jun 3, 2021 at 3:45 AM
    #1092
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I cut 2 of mine on the shackle mounts to clear, now grease just pours out the backside, guess the grease channel goes further than I thought... luckily I greased the bolt before installation.. have to order 2 new greasable bolts from you soon @Crikeymike....
    Crikeymike [OP] and CygnusX191 like this.
  13. Jun 3, 2021 at 3:54 AM
    #1093
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    I am running the standard length MRA/MRR and have found on the lower end of the spectrum is decent.. I have not messed with rebound much, and believe I should for the rear.. I do find in certain high speeds the rear becomes unsettled.. and wants to overpass the front (little squirrly)... I typically run on the softer side 1-4 on high and low speed compression settings. still have yet to mess with rebound control. currently running the 111R rear leafs, and the heavy load front coils. 2.5" lift with JBA high castor UCA's. I have since this pic gone to a 285/70/17 grabber atx, these are 265/70/17 duratracs. Unimog on 42's for comparison... this is the NMW north Maine woods.. thousands of miles of logging roads/trails typical speeds are 30-55mph up here depending on road conditions/culverts, and washouts....
    JAStaco, mabepossibly and CygnusX191 like this.
  14. Jun 3, 2021 at 6:42 AM
    #1094
    Crikeymike
    Jax Beach, Florida
    All sold out sorry, waiting for more to come in July.
    Sierra Trail Pro and CygnusX191 like this.
  15. Jun 15, 2021 at 9:12 PM
    #1095
    tmfb16
    tmfb16 Well-Known Member
    3G DCOR
    Just miles
    Do you know if dobinsons is going to release those IMS rear shocks anytime soon?
  16. Jun 16, 2021 at 7:04 AM
    #1096
    Crikeymike
    Jax Beach, Florida
    We're just waiting for them to come out of production and shipped to the USA. I'll be letting everyone know as soon as that time comes.
    cornbread_wy, tmfb16 and CygnusX191 like this.
  17. Jun 19, 2021 at 6:36 PM
    #1097
    LRockPro
    LRockPro Well-Known Member
    LRock
    Hello.. Can anyone provide some pics of 110's rear lift? Can’t decide with icon rtx option 1(1.85 no load height) or 110's(2.2 no load height) and also how is the ride with the 110 over stock? Thanks..
  18. Jun 20, 2021 at 7:13 AM
    #1098
    trailbound
    trailbound Well-Known Member
    Rob
    Reno, NV
    2016 DCSB TRD OR 4x4
    Here is my truck with the 110's. I'm still very happy with them. The ride over stock is day and night. The stock leafs suck.
    https://www.tacomaworld.com/threads/dobinsons-16-taco-suspension.474308/page-15#post-21531533
    This was after adding 285's and different shell.
  19. Jun 20, 2021 at 1:05 PM
    #1099
    jstemp
    jstemp Well-Known Member
    Wisconsin
    2020 DCSB Offroad MT, OV Tuned
    I had the Icon RXT in option 1 and 2 and switched to the Dobinsons 110. In my opinion the 110's are the better leaf pack. The ride is better with the 110's, and with the RXT's I always had a shutter on take off even after measuring driveline angles and correcting with a 2 degree shim. The Icons also started squeeking early on and the Dobinsons have been very quiet. Lift wise I got about 2.25 inches of lift with the 110's.
  20. Jun 21, 2021 at 3:48 AM
    #1100
    motofish84
    motofish84 Well-Known Member
    Tyler
    @Crikeymike do you guys have a pair of the Dobinsons UCA's in stock?
