Dobinsons 2016-2023 Taco Suspension Options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crikeymike, Feb 7, 2017.
  1. Sep 24, 2020 at 7:46 AM
    #801
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :stayontopic:
    BUT since I'm now in an identical truck that is black, I'm following this thread to plan my suspension build :D
    tacoma04[QUOTED] likes this.
  2. Sep 24, 2020 at 7:49 AM
    #802
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Back on topic.....I highly recommend Dobinsons and @Crikeymike. I am very happy with the suspension on my truck.
  3. Sep 24, 2020 at 9:52 AM
    #803
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I second that! Mike was super helpful during the purchase, and continues to be helpful long after the installation! :thumbsup:
  4. Sep 25, 2020 at 8:20 AM
    #804
    Crikeymike
    Crikeymike [OP] ExitOffroad.com Vendor
    Jax Beach, Florida
    I know a lot of Dobinsons coils are sold out right now, but there's a price increase next week, October 1st, on all coils!! Any orders placed until then, even if they're on backorder, will still get the current pricing.
    Just a heads up!!
  5. Sep 25, 2020 at 2:07 PM
    #805
    McStudMuffin
    McStudMuffin Well-Known Member
    2018 TRD OR DCLB
    Bilstein 5100's, OME 888, Dakars, Leer Canopy
    I have a 2018 double cab long bed 4x4. I have rock sliders. No other weight up front. I currently have Bilstein 5100's paired with ome 888 to get 3 inches of lift. The coils have sagged, so I ordered c59-352 coils. With the Bilstein 5100's set at 0, will this setup give me 3 inches of lift, or should I set the 5100's on the first notch? Thank you.
  6. Sep 25, 2020 at 2:30 PM
    #806
    Crikeymike
    Jax Beach, Florida
    Whichever notch is 1/2" taller than the bottom to add 1" to the lift height is what you'd need for 3"
    CygnusX191 likes this.
  7. Sep 25, 2020 at 2:39 PM
    #807
    McStudMuffin
    2018 TRD OR DCLB
    So the coil alone will not provide 3" of lift? Is this why the coils are often paired with specific struts from Dobinsons? What is the difference between the Dobinsons struts? Just trying to figure out if I should order different struts as well. I've been advised not set the Bilsteins above 0 if I have aftermarket coils.
  8. Sep 25, 2020 at 3:28 PM
    #808
    Crikeymike
    Jax Beach, Florida
    Per post #1, those are 2" lift with ~200lbs of front weight on them. Might be about 2.25" to 2.5" without a bumper with a stock coil seat height. The Dobinsons 220 struts have a taller coil seat that when combined with the 2" coils gives 3" of lift.
    Yeah, Bilstein doesn't advise using non stock coils on their struts yet so many people do it.
  9. Sep 27, 2020 at 6:50 AM
    #809
    Arcteryx 79
    Arcteryx 79 Well-Known Member
    RJ
    Waukesha WI
    2020 Black TRD Sport DCLB
    been reading this thread and looking for some help on set up for a lift. Bare with me as this is my first tacoma and looking to kit it out and start off roading. And Doninson kits look legit after tons of research. Baby steps
    I have a DCLB and want to go 3" lift all around. First for looks but Off road functionality very soon. I don't want to level and want to have a slight rake. Currently front and rear fenders measure 35" from ground. Thought all trucks have a rake but guessing I dont. No plans on bumper upgrade but tow a camper and always have a load of some sort so don't want sag in the rear. Would like 33" but a CMC is out of the question so 275's are probably going to happen.
  10. Sep 27, 2020 at 7:16 AM
    #810
    tacoma04
    Bruce
    Tennessee
    @Crikeymike is the man to help you with this!
    Crikeymike[OP] and CygnusX191 like this.
  11. Sep 28, 2020 at 9:11 AM
    #811
    Crikeymike
    Jax Beach, Florida
    Hey bud. Maybe yours came with a front spacer lift from the dealer? It's pretty common in some areas of the country.
    The standard for measuring a lift height is from the center of the hub up to the fender. Stock/new is usually 20" front and 22" rear.
    3" front is no problem, but the rear springs aren't spec'd to give 3", not unless you run a heavier spring that's rated for more constant weight, and you don't have that weight on there. That would be the L59-112-R.
  12. Sep 28, 2020 at 9:51 AM
    #812
    Arcteryx 79
    RJ
    Waukesha WI
    Thanks Mike. I just remeasured hub to fender and both are sitting 21". I do not see a spacer on the front. Only concern is going full 3" on front and having the front sitting higher than the rear. Not sure if it's a 2020 Sport setup. Maybe the 2" in front and whatever I can get in the rear to give a little rake. Will the heavy duty leafs give 2" or slightly more?
  13. Sep 28, 2020 at 10:29 AM
    #813
    Crikeymike
    Jax Beach, Florida
    Maybe so. Double cab fronts are 20", and extra cabs are 21", so they must have done something new for the 2020's, and the rears are usually 22", regardless of the cab.
    The leaf springs give the specified lift height with the max amount of constant weight listed on them, so with less weight, they give more lift. Long beds need the 111's or 112's though, since they're a little heavier. Based on where you're starting from, I don't think you'll get 3" out of the 112R's.
    There's all sorts of guys in this thread running different combinations. Hopefully some with double cab long beds will chime in with what they're running and their settled hub to fender measurements so you can use that as examples for what you'll get.
    FashTaco and CygnusX191 like this.
  14. Sep 29, 2020 at 2:57 PM
    #814
    MedTechBrew
    MedTechBrew Well-Known Member
    NC
    2017 Quicksand TRD Sport DCSB 4x4
    Just completed my order for a lift kit with Exit Offroad. Crikeymike was incredibly helpful. Can’t wait to get it installed. Will post pics before and after. :taco:
  15. Sep 29, 2020 at 3:26 PM
    #815
    Arcteryx 79
    RJ
    Waukesha WI
    I was waiting until tomorrow to order my set up when my bonus hit. The springs I want are sold out. :annoyed:
  16. Sep 29, 2020 at 3:30 PM
    #816
    MedTechBrew
    NC
    Can still beat the price hike though. :turtleride:
  17. Sep 30, 2020 at 5:08 PM
    #817
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    Such a nice truck. Do you have the specs posted anywhere?
  18. Oct 1, 2020 at 9:41 AM
    #818
    RyanDCLB
    4/19 DCLBOR
    Thanks! :thumbsup: Most of the suspension parts are listed here. Although, through trial and error, I pulled the Dobinsons gresable shackle bolts because they didn't work with the Hammer Hangers. One of these days I'll get around to making a build thread. :wink: Some install pics can be found in the next two posts here
    9mmMike[QUOTED] and CygnusX191 like this.
  19. Oct 8, 2020 at 4:05 AM
    #819
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    @Crikeymike Do the GS59-220 struts that give 1” of extra lift, preload the coils to give lift, or are they 1” longer overall with the higher coil seat?
    Arcteryx 79 and CygnusX191 like this.
  20. Oct 8, 2020 at 8:46 AM
    #820
    Crikeymike
    Jax Beach, Florida
    They are longer in extended length to compensate for the taller coil seat height, so it doesn't end up adding any additional preload. The coil just sits in a higher position on the strut.
    This also makes them less prone to topping out (hitting full extension), whereas the regular GS59-221 struts would top out if too much lift was added to them, like 3" or more.
