Dobinsons 2016-2023 Taco Suspension Options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crikeymike, Feb 7, 2017.
  1. Nov 30, 2020 at 3:51 AM
    #841
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    I’m thinking of going with this same setup. What leafs are you running? Also, what size tire are you running in that pic?
    SailorWA and CygnusX191 like this.
  2. Nov 30, 2020 at 8:08 AM
    #842
    bmxtaco
    bmxtaco Well-Known Member
    Planet Florida
    2021 TRD OR 6MT
    Nice truck! Looking at going with pretty much the same setup.
    This is an obnoxious question but when you do end up measuring would you mind also measuring roughly from the ground to top of the cab? Looks a little higher than I'd imagined, was hoping to not have an issue with garage clearance.
    CygnusX191 likes this.
  3. Nov 30, 2020 at 8:24 AM
    #843
    McStudMuffin
    McStudMuffin Well-Known Member
    2018 TRD OR DCLB
    Bilstein 5100's, OME 888, Dakars, Leer Canopy
    I am running the Dakar heavy duty leaf pack in the rear with Bilstein 5100's. Originally I had Bilstein 5100's with OME 888 in the front but I lost some lift and ride was too soft for me.
    Tire size is 275/70/17. I had 285's initially but they rubbed with my old set up.
  4. Dec 1, 2020 at 7:41 PM
    #844
    brtnstrns
    brtnstrns Well-Known Member
    Seattle
    2020 Voodoo Blue TRDOR DCSB
    Just got the truck aligned today. I'll try to get some new measurements on flat ground to see what everything ended up at and post them here. I'll try to remember to get the top of the cab as well.
  5. Dec 4, 2020 at 12:01 PM
    #845
    Crikeymike
    Crikeymike [OP] ExitOffroad.com Vendor
    Jax Beach, Florida
    NEW PRODUCT ALERT!!!
    DOBINSONS 3-WAY ADJUSTABLE MRR (MRA) LONG TRAVEL REAR SHOCKS FOR 2005-21 TACOMA
    • 3-way Adjustable shocks provide maximum adjustability to provide the perfect ride quality for you
    • 10 Stage High Speed Compression – For aggressive, high speed offroading through ruts and holes
    • 20 Stage Low Speed Compression – For creepy crawling and cornering
    • 15 Stage Rebound – Control your coils, prevent bucking
    • 50mm CNC Machined High Flow Billet Aluminum Race Piston
    • 3mm Thick Heavy Duty DOM Seamless 56mm (2.2″) O.D. shock Body Precision Honed to +/- 0.04mm
    • Upgraded 3 Stage FKM‐HNBR Sealing System
    • TSUGAMITM CNC machined components for precise tolerances
    • Parker Braided High Pressure Hoses
    • 5140 HV900 Hard Chrome Plated, Heat treated 18mm Micro-Polished high strength Shock Shaft with a minimum tensile strength exceeding 700MPA
    • Carbon-Fibre/PTFE/Disulphide composite wear band for the ultimate in low-friction, low‐wear performance
    • 60mm Full 6063 aluminum remote reservoir, Lightweight CNC Machined Low Friction floating piston
    • High Quality O.E.M. Grade Natural Rubber Bushings
    • Single Piece Lower Leg, CNC TIG Precision Welded Body End Mounts
    • EDP Surface Protection, Direct Bolt-On Design
    • Fully Rebuildable Design, Full 2 year limited warranty, no set rebuild time period
    • 16.5″ compressed length, 26.9″ extended length
    • These shocks require 24″ brake lines and 2″ bump stop extensions
    Part number MRA59-A941, in stock and shipping now. Current price is $900/pair
    https://exitoffroad.com/product/dobinsons-mra59-a941-long-travel-rear-tacoma-shocks/
  6. Dec 17, 2020 at 9:07 PM
    #846
    justrussell
    justrussell Well-Known Member
    Russell
    Sacramento
    Can you get the 3” lift with these paired with the 112 leafs?
  7. Dec 24, 2020 at 1:49 PM
    #847
    recomr
    recomr Well-Known Member
    2007 Access Cab 6spd
    5100's. Eibach. ST Maxx 255/85. Bestop. Pro Comp 252.
    I know I’m on Tacomaworld... but any chance these come out for a gen 1 tundra?
  8. Dec 24, 2020 at 1:53 PM
    #848
    justrussell
    Russell
    Sacramento
    Go on the Dobinson direct . Com. They have lifts for gen 1 Tundra but not the MRR version.
    CygnusX191 and recomr[QUOTED] like this.
  9. Dec 24, 2020 at 1:55 PM
    #849
    recomr
    gotcha. Just wasn’t sure if they are in the works or not
    justrussell[QUOTED] likes this.
  10. Dec 24, 2020 at 2:18 PM
    #850
    justrussell
    Russell
    Sacramento
    I’d guess eventually but they don’t even offer the MRR for the tundra front end yet. Dobinsons is awesome, I just upgraded from their regular lift shocks to the MRR just for the adjustment ability. No complaints about the non MRR system.
    Greatdane01 and CygnusX191 like this.
  11. Dec 24, 2020 at 2:30 PM
    #851
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    First gen Tundra is basically the precursor to the second gen Tacoma anyway :D
    Crikeymike[OP] likes this.
  12. Dec 28, 2020 at 12:51 PM
    #852
    Crikeymike
    Jax Beach, Florida
    recomr[QUOTED] and CygnusX191 like this.
  13. Dec 28, 2020 at 12:55 PM
    #853
    Crikeymike
    Jax Beach, Florida
    Yes, that's not a problem. They're the same price, so just put a note in your order if/when you do order that you want the LT rear shocks instead of the standard ones. Just gotta make sure you add the right parts to go with them (brake lines, bump stops)
    Toyotico and CygnusX191 like this.
  14. Dec 28, 2020 at 1:15 PM
    #854
    recomr
  15. Dec 28, 2020 at 1:37 PM
    #855
    Crikeymike
    Jax Beach, Florida
  16. Dec 28, 2020 at 2:26 PM
    #856
    recomr
    Nice- thanks for the help! Do you think MRR in rear and the aforementioned IMS in front would be a good pair? Perhaps the front would be lacking in performance compared to the rear.
    Anybody know how these do in terms of corrosion resistance in comparison to King/ADS? (Elka obviously the best for corrosion resistance).
  17. Dec 28, 2020 at 3:00 PM
    #857
    Crikeymike
    Jax Beach, Florida
    Had 2nd and 3rd Gen Tacoma guys get that setup, as they're looking for adjustable ride in the rear when the weight in the bed changes, or they tow, and haven't had a single complaint. The main difference is that the front just isn't adjustable, but everything about the IMS is the same as the MRA, is just doesn't have the external resi and hose and the 3 levels of adjustment. The piston, IFP, size and everything is the same.
  18. Dec 30, 2020 at 7:38 AM
    #858
    Crikeymike
    Jax Beach, Florida
    Hey mate, any chance you can edit that old post to my current email address? exitoffroad@gmail.com
    That old address is dead and doesn't go anywhere and others keep trying to use it.
    JasonLee and CygnusX191 like this.
  19. Dec 30, 2020 at 1:20 PM
    #859
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Done Sir :thumbsup:
  20. Dec 30, 2020 at 1:21 PM
    #860
    Crikeymike
    Jax Beach, Florida
    Thanks man!! I'll buy you a Mtn Dew next time I see ya!!
