Dobinsons 2016-2023 Taco Suspension Options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crikeymike, Feb 7, 2017.
  1. Nov 27, 2022 at 10:53 PM
    #1621
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    @sbx22 :notsure:
    Although related to front coilovers, more great info fromTinker (yes, I'm a fanboi)
    sbx22 and CygnusX191 like this.
  2. Nov 28, 2022 at 8:02 AM
    #1622
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I like his video too. It's not my daily so I may just play around with it, build up some custom spacers or so.
    CygnusX191 and RyanDCLB like this.
  3. Dec 31, 2022 at 8:56 PM
    #1623
    6host
    6host Active Member
    @Crikeymike i was about to call you when I pulled the factory setup out and notice my IMS set at 3” was the same length. My gut told me to trust it and after install I sat it down to measure and sure enough right at 3” perfectly.
    IMS with 314 springs set at 3” SPC UCA
    AC713FD0-3AA4-44C2-B0BA-4450BF0E5FBA.jpg A63CA1BE-04DE-46AD-BEE9-6144B140B560.jpg
    U bolt flip and ICON AAL with factory overload left in
    Front measures 38” ground to fender rear is at 39” on stock wheels and tires. 3” all around.
    SEMA PRO knock offs 17x8 +5 with 285/70/17 Maxxis RAZR AT. No rubs and room for days
    Mike, I couldn’t be happier. It rides just like I wanted it to the lift is perfect and I had zero headaches. Minus the upper control arm bolts. I can’t thank you enough.
  4. Jan 1, 2023 at 3:23 PM
    #1624
    Crikeymike
    Crikeymike [OP] ExitOffroad.com Vendor
    Jax Beach, Florida
    That's great!!
    The length a coilover sits in the box doesn't dictate the lift height at all. It's spring rate, length and coil seat height that do that.
    Glad it has worked out so well!!
    6host[QUOTED] and CygnusX191 like this.
  5. Jan 1, 2023 at 4:39 PM
    #1625
    6host
    6host Active Member
    I figured as much. In my head I thought there would be a noticeable difference in the two side by side.
    I really like the way it drives with the new suspension. Super glad I went with this kit.
  6. Feb 9, 2023 at 9:34 PM
    #1626
    MrWortWort
    MrWortWort Well-Known Member
    2021 SR Access Cab Tacoma
    Nice bumper
    What brand is it?
    CygnusX191 likes this.
  7. Feb 10, 2023 at 5:28 AM
    #1627
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
  8. Feb 10, 2023 at 6:10 AM
    #1628
    Crikeymike
    Jax Beach, Florida
    C4 I think
  9. Feb 10, 2023 at 6:19 AM
    #1629
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Looks good! What are the specs of your set up?
  10. Feb 10, 2023 at 9:54 AM
    #1630
    bulldog
    SW MO
    2023 Pro
  11. Feb 10, 2023 at 5:26 PM
    #1631
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Nice!
    I'm actually near your neck of the woods ATM..... :anonymous:
  12. Feb 10, 2023 at 7:08 PM
    #1632
    RyanDCLB
    4/19 DCLBOR
    Figure I'd post this here too:
    Adjusted the 3-way Dobinson MRA suspension.
    Found out that the rebound on the passenger side adjuster was missing the little metal ball bearing :frusty: Thankfully, I was saved by my kid's magnetic toy! These work perfectly! :cheers:
    See them at Walmart here Speks Magnetic Balls 2.5MM
    Removing rebound adjusters on a front Dobinsons MRA strut / coilover:
    @Crikeymike :thumbsup:
  13. Feb 16, 2023 at 2:39 PM
    #1633
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    I just ordered a Dobson's full suspension kit and need to know if anyone has a recommendation for where to take it for a 4 wheel alignment. I'm west of Portland, OR. Thank you.
    CygnusX191 and P8trit like this.
  14. Feb 17, 2023 at 5:30 AM
    #1634
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Les Schwab is always an option.
  15. Feb 17, 2023 at 10:34 AM
    #1635
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Can't get a 4 wheel alignment on a truck with a solid rear axle. Don't let a shop tell you otherwise, they're just taking your money at that point.
    econwatch and Crikeymike[OP] like this.
  16. Feb 17, 2023 at 3:33 PM
    #1636
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    Replaced my front with new spring/shock, about 1" lift.
    Just mark the alignment cams with a paint pen and get them back to that measure.
    Post install alignment shop didn't change a thing.
  17. Feb 20, 2023 at 6:33 PM
    #1637
    MoonRockToyota
    MoonRockToyota Member
    2022 Lunar Rock TRD Off Road
    I took my truck to Big Brand tire after I installed everything, and a year later everything is still good. Think i paid like $50.
  18. Feb 21, 2023 at 6:43 AM
    #1638
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's a heckuva deal!
  19. Feb 21, 2023 at 7:40 PM
    #1639
    bulldog
    SW MO
    2023 Pro
    Anyone get bump steer after your lift? I have a bad case of it. Any suggestions?
  20. Feb 22, 2023 at 5:53 AM
    #1640
    Crikeymike
    Jax Beach, Florida
    Needs a better alignment with more caster most likely.
