Dobinsons 2016-2023 Taco Suspension Options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crikeymike, Feb 7, 2017.
  1. Feb 22, 2023 at 8:55 AM
    #1641
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    I didn't know this is what it was called, but I definitely get this too. I still have my swaybar attached so it's not due to the removal of that.
    CygnusX191 likes this.
  2. Feb 22, 2023 at 9:27 AM
    #1642
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    What numbers do I need to shoot for?
  3. Feb 22, 2023 at 9:28 AM
    #1643
    bulldog
    SW MO
    2023 Pro
    Same, still have mine.
  4. Feb 22, 2023 at 11:03 AM
    #1644
    Crikeymike
    Crikeymike [OP] ExitOffroad.com Vendor
    Jax Beach, Florida
    3-3.5* of caster. Low caster will allow the wheel to buck too easily, and give you that bump steer. Or if you're lifted really tall as well, due to the angle of the steering and lower arms, you'll end up with more of that than a lower height lift would have.
  5. Feb 28, 2023 at 9:40 PM
    #1645
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    Big thanks to Mike for answering a few questions for me and the fast shipping.
    Switched out my OME springs on my 5100s for the C59-352 springs to help with the weight of my bumper and winch.
    Ended up a little under the 2” mark.
    CygnusX191, Crikeymike[OP] and P8trit like this.
  6. Mar 1, 2023 at 7:07 AM
    #1646
    Crikeymike
    Jax Beach, Florida
    That's great, and you're welcome!!
    Nice garage floor too!!
  7. Mar 1, 2023 at 8:19 AM
    #1647
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Red.on silver.... :drool:
  8. Mar 1, 2023 at 9:01 AM
    #1648
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    I agree with Crikeymike that floor is AMAZING.
  9. Mar 1, 2023 at 3:08 PM
    #1649
    Dirt McGirk
    Phoenix, AZ
    19 TRD OR 4X4
    Thank you! Haha
    Took almost 2 years to remodel this house so I had plenty of time to finish the garage before I moved all my tools in.
    Crikeymike[OP] and CygnusX191 like this.
  10. Mar 3, 2023 at 9:31 PM
    #1650
    DodgeORama
    DodgeORama Well-Known Member
    Dodge
    Squamish, BC
    2017 MGM TRD Off Road DCSB
    @Crikeymike could you help with some independent advice? This thread’s been amazing so I hope you can…
    My local shop installed a pair of IMS59-50574s in the front of my Tacoma. It looks like they’re for 4Runners and FJs, and are slightly longer both extended and compressed than the 50220s… should I be going back and asking for the right struts or are they essentially the same?
    Thanks in advance
  11. Mar 4, 2023 at 5:44 AM
    #1651
    Crikeymike
    Jax Beach, Florida
    Those work fine. They're the same valving as the 50220 and the only other difference was the lower bushing width but they probably changed those out. Would be a good idea to extend the front bumps stops though.
  12. Mar 4, 2023 at 7:00 AM
    #1652
    DodgeORama
    Dodge
    Squamish, BC
    Thanks mate, really appreciate it.
    The invoice doesn’t show anything about bushings - how would I know if they had?
    I’m not keen on spending more on bump stops if the 50220 shouldn’t need them. I’ll shoot them a message and see what they say.
  13. Mar 4, 2023 at 12:51 PM
    #1653
    Crikeymike
    Jax Beach, Florida
    The bushings would have been too wide to fit in so they wouldn't have been able to install them
  14. Mar 6, 2023 at 11:01 AM
    #1654
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    They don't appear to be in Oregon.
  15. Mar 6, 2023 at 11:10 AM
    #1655
    Bunk Moreland
    Bunk
    It's complicated.
    @Crikeymike Thank you for answering my numerous questions and helping me to understand my component options over the phone. Varied advice coming in and I don't know enough to make an educated decision. What would you advise that I do for alignment? (I purchased a complete kit; order# 12356)
    CygnusX191[QUOTED] likes this.
  16. Mar 6, 2023 at 11:15 AM
    #1656
    Bunk Moreland
    Bunk
    It's complicated.
    I stopped going to them after they convinced me that I needed a full brake job that included replacing the rotors & calipers! Guess what? There was nothing wrong with the rotors or calipers! Les Schwab suckered me but good. I'll never give them another dollar.
  17. Mar 6, 2023 at 5:08 PM
    #1657
    bulldog
    SW MO
    2023 Pro
    0 everything out and get as much castor as possible.
  18. Mar 6, 2023 at 5:08 PM
    #1658
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Get a front end alignment :D
  19. Mar 7, 2023 at 6:03 AM
    #1659
    Crikeymike
    Jax Beach, Florida
    Yep, those are all correct!!
    Zero it out (starting from scratch) with maximum caster. Turn both rear cams all the way outward. Turn both front cams all the way inward. Both sides will now be even and the tires will be shifted as far forward as possible. Then dial in camber, then dial in toe. That leaves maximum caster, and camber and toe get set to factory.
  20. Mar 9, 2023 at 8:11 AM
    #1660
    Bunk Moreland
    Bunk
    It's complicated.
    Excellent. I'll now go scour the youtubes to figure out what all of that means. :)
