Dobinsons 2016-2023 Taco Suspension Options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crikeymike, Feb 7, 2017.
  1. Mar 13, 2023 at 10:44 AM
    #1681
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Then that answers the question of why you don't have much flex on the front. Sorry dude. That's just your sway bar doing its job.
  2. Mar 13, 2023 at 10:47 AM
    #1682
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    There's no way to increase flex at all without removing the sway bar? I find that hard to believe.
    CygnusX191[QUOTED] likes this.
  3. Mar 13, 2023 at 10:59 AM
    #1683
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    The sway bar is designed to stop flex, removing it is the only way to stop it from doing it's job.
    Lot's of people daily drive without a sway bar. You just can't corner the truck as hard.
    CygnusX191 likes this.
  4. Mar 13, 2023 at 11:38 AM
    #1684
    Crikeymike
    Crikeymike [OP] ExitOffroad.com Vendor
    Jax Beach, Florida
    It's a great way to increase articulation at each wheel. Also changing to aftermarket UCAs will increase droop travel as well as extended travel struts/coilovers. The sway bar can still inhibit the full travel range though.
  5. Mar 13, 2023 at 1:44 PM
    #1685
    2019 TRD Off Road
    Already have SPC UCAs, I should have mentioned. There’s no longer travel option than OME?
    Either way that’s not my main concern. I want to know suggestions on Dobinsons part combos to lift the front relative to rear and maximize ride comfort.
  6. Mar 13, 2023 at 6:32 PM
    #1686
    Jeremy2020taco
    Jeremy2020taco Member
    Is anyone running the 314’s with weight up front? I’ve had the 221 with the 314 struts for a couple years and love the way it rides. I’m about to instal cali raised bumper and a winch estimated 150 pounds. Wondering if I should go ahead and order the 352 or wait and see how it rides. Also I have aluminum skids and full slider steps.
  7. Mar 14, 2023 at 7:13 AM
    #1687
    Crikeymike
    Jax Beach, Florida
    The IMS59-50220 struts are extended travel, longer than the OME. You can reuse the same coils if they're working ok for you, or change over to Dobinsons C59-314 and set the coil seat height
  8. Mar 14, 2023 at 11:52 AM
    #1688
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Hey all, I’m chasing a vibration. I put a 1 piece driveshaft in yesterday thinking that would fix it and it did not. I do have a diff drop and did the EGS bearing too and 4.88 gears all done at the same time.
    Seems to happen the worst at 20-30. It’s a whaaa whaaa sound that you can feel in the floor below you feet. Everything looks good, not a wheel bearing, so I’m not sure what it is. Any advice?
  9. Mar 14, 2023 at 12:49 PM
    #1689
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Check all your u joints?
  10. Mar 14, 2023 at 12:53 PM
    #1690
    bulldog
    SW MO
    2023 Pro
    Ya I even put a Tom Woods 1 piece In yesterday.
  11. Mar 14, 2023 at 12:54 PM
    #1691
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Good crawler shafts, but they do have recommended RPM limits.
    Shouldn't be hitting it at 20-30 mph though
  12. Mar 14, 2023 at 12:55 PM
    #1692
    Crikeymike
    Jax Beach, Florida
    How much rear lift do you have? Maybe too much and a bad pinion angle perhaps?
    Since a lot of other work was done, I wonder if something wasn't tightened up all the way
  13. Mar 14, 2023 at 12:55 PM
    #1693
    bulldog
    SW MO
    2023 Pro
    Ya it’s doing it that same as the 2 piece was.
  14. Mar 14, 2023 at 12:56 PM
    #1694
    bulldog
    SW MO
    2023 Pro
    just the regular Dobinson springs.
  15. Mar 14, 2023 at 12:56 PM
    #1695
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Might be on to something, an axle shim could possibly help offset the new angle
  16. Mar 14, 2023 at 12:58 PM
    #1696
    bulldog
    SW MO
    2023 Pro
    Maybe, I really thought the 1 piece would have fixed that but maybe not.
  17. Mar 14, 2023 at 2:27 PM
    #1697
    DosTacosPorvor
    DosTacosPorvor Well-Known Member
    Brad
    Midwest
    19’ TRD Sport Dbl Cab M/T
    5100’s w/AAL, Dobinson's 314 coils. 285/70-17 BFG KO2's, 17X8 Pro-Comp 89's 0 offset, BA Highline Front Bumper, K&N FIPK CAI. N-Fab Podium steps, Gatorz Low Profile Hard tri fold Bed Cover.
    How’s the 352’s ride on the 5100’s? I have a bumper but no winch.
  18. Mar 14, 2023 at 6:31 PM
    #1698
    P8trit
    P8trit Well-Known Member
    Just had the the mrr 3ways installed with 352 and 111r leaf pack on my 2022. Love the look and seems smoother then the pro life before but im new to adjustments. Where do I start to make sure they are starting at a good point.
    Looking for a good daily starting point and then what to adjust for slow offroad.
    RyanDCLB and CygnusX191 like this.
  19. Mar 14, 2023 at 7:54 PM
    #1699
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    I love it, I had the eibach pro kit on my last truck and this feels exactly like that.
  20. Mar 15, 2023 at 6:43 AM
    #1700
    Crikeymike
    Jax Beach, Florida
    Awesome!! Nice canopy by the way.
    Start at 1 on all settings on all 4 corners (sofest, anti clockwise on all adjusters) until the suspension settles in. The new coils and parts will take about 500 miles to settle in. LSC usually stays low, 1-3, and HSC would go up to 5-6 depending on terrain and rebound at 8 or so. With strong front coils, you may need to increase the front rebound more so the front doesn't try to bounce back up so much after hitting full compression.
