Dobinsons 2016-2023 Taco Suspension Options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crikeymike, Feb 7, 2017.
  1. Feb 21, 2024 at 5:16 PM
    #1861
    Crikeymike
    Crikeymike [OP] ExitOffroad.com Vendor
    Jax Beach, Florida
  2. Feb 21, 2024 at 6:04 PM
    #1862
    NachyoTaco91
    NachyoTaco91 Member
    22' TRD OR4
    aha missed that. thanks for reply
    Crikeymike[OP] likes this.
  3. Feb 22, 2024 at 6:17 PM
    #1863
    radbrad311
    radbrad311 Member
    2023 DCLB TRD OR
    Anyone running the twin tube ext travel (GS59-220) with stock springs to get an inch of lift in the front?
    @Crikeymike any reason not to use stock springs if I don't have any added weight?
    NachyoTaco91 likes this.
  4. Feb 23, 2024 at 6:46 AM
    #1864
    Crikeymike
    Jax Beach, Florida
    It would technically work, just make sure your Tacoma didn't come with taller struts to start with. Measure from the bottom end of the coil down to the lower center bolt. As long as it's 213mm, then these struts will add 1" of lift, as they're 226mm from base to lower mount.
    radbrad311[QUOTED] likes this.
  5. Feb 23, 2024 at 12:55 PM
    #1865
    AGTaco22
    AGTaco22 Well-Known Member
    Warren
    RVA
    2022 Tacoma TRD OR
    Hello all! I have a 2022 TRD Off-Road DCSB and I've been looking at swapping out my current setup to the Dobinson 0-3" extended travel IMS coilovers. Dobinson IMS rear shocks with an Icon add-a-leaf and Dirt King uppers.
    I'd like to run 285/75 16's. I have Fifteen52 Turbomac classics 16x8 0 offset 4.5" back spacing. Would 2" front and icon add-a-leaf rear work with the 285's? I don't have bumpers currently. I do have rock sliders. Does anyone have experience with this setup? Any advise would be greatly appreciated! Thanks!
  6. Feb 23, 2024 at 3:21 PM
    #1866
    Crikeymike
    Jax Beach, Florida
    That should work fine. Although tire clearance and fitment has a lot to do with the wheel alignment and how the tech positions your tires during that process. Usually with 33s you'll still have to do some plastic trimming but they should be able to move the tires forward to reduce the chance of a body mount. There are no guarantees though since alignment techs are entry level jobs in my experience.
    AGTaco22[QUOTED] likes this.
  7. Feb 24, 2024 at 11:41 AM
    #1867
    AGTaco22
    Warren
    RVA
    2022 Tacoma TRD OR
    Thanks, Mike! I'll definitely be ordering my kit from you when I'm ready. Would you recommend removing the overload leaf to get a leveled look?
  8. Feb 25, 2024 at 2:45 PM
    #1868
    Crikeymike
    Jax Beach, Florida
    I thought you were going to add leaves into the stock pack?
  9. Feb 26, 2024 at 4:40 AM
    #1869
    AGTaco22
    Warren
    RVA
    2022 Tacoma TRD OR
    I thought if you removed the factory overload and put the icon add-a-leaf in its place it would give you around a 1" lift. Is that incorrect?
  10. Feb 26, 2024 at 6:55 AM
    #1870
    Crikeymike
    Jax Beach, Florida
    I've never tried it or had a customer give me that info, so I can't confirm.
  11. Feb 26, 2024 at 8:03 AM
    #1871
    AGTaco22
    Warren
    RVA
    2022 Tacoma TRD OR
    Understood. Thank you.
  12. Feb 26, 2024 at 11:13 AM
    #1872
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    The path is correct, you remove the factory overload, replacing with the AAL pack. This nets generally 1.5" of lift (That was based on a fresh pack, so if leafs are well aged, this may net closer to 1")
  13. Feb 26, 2024 at 12:57 PM
    #1873
    AGTaco22
    Warren
    RVA
    2022 Tacoma TRD OR
    Okay, thank you for the info. Much appreciated.
  14. Feb 28, 2024 at 8:34 AM
    #1874
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    @Crikeymike , if I were to instal the Dobinsons 2 inch front coil overs and 2 inch block in the rear on my SR, I wouldn't need any other mods or have any issues other than needing to redo my alignment. Is that correct?
  15. Feb 28, 2024 at 8:41 AM
    #1875
    Crikeymike
    Jax Beach, Florida
    Yes, that's correct. It's not lifting it too much to require any other parts.
    not a charger[QUOTED] likes this.
  16. Feb 28, 2024 at 8:50 AM
    #1876
    not a charger
    NE Ohio
    Can I get away without the sway bar relocation at 2 inches, or would you recommend using it?
  17. Feb 28, 2024 at 8:52 AM
    #1877
    Crikeymike
    Jax Beach, Florida
    No, it's not needed at 2". More for a 3" front lift.
  18. Feb 28, 2024 at 8:53 AM
    #1878
    not a charger
    NE Ohio
    Thank you sir.
  19. Feb 28, 2024 at 9:00 AM
    #1879
    Crikeymike
    Jax Beach, Florida
    No problem!
  20. Mar 6, 2024 at 12:11 PM
    #1880
    TRDtako
    TRDtako New Member
    Rolly
    Edmonton Alberta Canada
    2020 Toyota Tacoma TRDOR 4V6
    Dobinson 2" front coilovers Radflo 12" Resi/shock relocation/hammer hangers C4 Fabrication Rock Runner Front and Rear Diode Dynamic Lights
    Hey @Crikeymike, I was looking through the Dobinson catalog, page 324 & 326, and noticed the 50mm and 75mm variations of the C59-314 share the same product number. Is there a different part number for the 75mm version so I know im ordering the right one?
