Dobinsons 2nd Gen Tacoma Suspension Options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crikeymike, Oct 28, 2016.
  1. Jan 12, 2020 at 4:44 PM
    #181
    Cred92
    Cred92 PAID4MOD
    Caleb
    Jasper Al
    Indigo Ink Sport DCLB/White RC I4 5MT
    BLACK AND BLUE STUFF
    That’s pretty sweet, I guess exit offroad is your new Dobinsons store. Look forward to sending some business your way hopefully
  2. Jan 15, 2020 at 8:53 AM
    #182
    Crikeymike
    Crikeymike [OP] ExitOffroad.com Vendor
    Jax Beach, Florida
    Lord Helmet and POOLGUY like this.
  3. Jan 20, 2020 at 11:09 AM
    #183
    Crikeymike
    Jax Beach, Florida
    Hey Everyone. Just updated post #1 with the new Dobinsons MRA 3-way adjustable struts and shocks that are coming out soon.
    MRA59-A220 - 3-way adjustable MRA struts w/resi - For 0-3.5" Front lift - longer travel
    MRA59-A940 - 3-way adjustable MRA shocks w/resi - For 0-3" lift - Rears are not a piggyback style. Resi mounts on frame
    **Product shipping date ETA is March 2020, available to preorder now**
    The time has come everyone, time to list the features and details of the long awaited Dobinsons MRA.
    Now first up, are they called MRR, MRA, or what?
    Well here's the thing - Dobinsons MRR's have been sold out of Australia for many years now, and they have been going thru a constant evolution of upgrades. First they had no valving adjustment at all, and the standard MRR's still do not but they are being phased out, which is also why they weren't ever fully stocked in the USA. So the new 3-way adjustable versions have been nicknamed "MRA" in part numbering for "MRR Adjustable" essentially and so that it's easy to keep track of. So you can call them MRR Adjustable, MRA's, or whatever you like, but for ease of keeping a separation between the regular MRR's and the new adjustable ones, I'll call them MRA's.
    3-Way Adjustable - what does that mean?
    First, on the external reservoir, it has high speed and low speed compression adjustability. 10 High Speed Compression Adjustments and 20 Low Speed Compression Adjustments.
    On struts, the rebound is adjusted at the very top of the strut, via a shaft that goes all the way down inside the strut thru the piston rod. This is done by hand, turning a small knob. On the shocks, the rebound is adjusted at the base of the shock, via a shaft that goes up thru the piston rod. 15 Rebound adjustments. This is done with a small adjuster tool that's basically like a flat head screw driver to reach into the shallow recess to adjust them.
    On the reservoir, the high and low speed compression can be adjusted by hand, however the "all-in-one adjuster tool" that comes with the shocks and struts has cut outs to adjust them too if it's hard to reach inside there.
    Also, all MRA front struts have a fully threaded body for height adjustment. This isn't included as part of the "3-way" method, but a standard feature of the monotube lineup that Dobinsons has.
    More from the engineers:
    Built on the Back of the Race Winning Monotube Remote Reservoir (MRR) Shock Absorbers, Dobinsons new range of MRR Adjustable Shock Absorbers combine the best in high performance race-bred Monotube Technology, with an all new 3-way dampening adjustment system to turn your 4×4 into the ultimate off-road machine. Each component of the MRR Shock Absorber has been refined and improved to offer a higher level of ride quality, vehicle control and shock absorber performance.
    The new 6063 honed Aluminum reservoir, revised light-weight floating piston, Carbon Fiber / PTFE / Disulphide composite wear band, improved 3 stage sealing system, and the ability to run lower gas pressure with the addition of the reservoir compression adjuster; have combined to provide massive reductions in shock absorber friction, resulting in an improved vehicle ride and dampening performance. The revised sealing design now provides a 3 stage FKM-HNBR shaft seal system that, when combined with the reduced operating frictions, provides a vastly increased service life with reduced wear.
    The Micro Polished, Hard Chromed and Heat Treated shock shaft, revised CNC aluminum high flow race piston, and DOM seamless tubing body provides the ultimate in performance and off-road durability. The 3 Way adjustment design reduces the main piston working load, distributing heat more evenly between the main piston and the reservoir piston for reduced operating temperatures, and allows quick and easy damping changes for the ultimate in shock tunability in varying terrain and vehicle loads, to keep you controlled and comfortable.
    Attached is the component sheet showing the main features of the MRA's, however here are some quick main points I want to pull out of there.
    • 3mm DOM (steel) thick main body
    • 6061 Aluminum spring seat and reservoir
    • Fully rebuildable design (No set rebuild mileage or timeframe!!)
    • Uses existing range of Dobinsons coils and top mounts
    • Direct bolt on design, no vehicle mods required for strut and shock fitment
    • Maintains rubber lower and upper bushings for maximum NVH dampening
    As far as resi mounts, we're waiting for the struts and rear shocks to arrive to verify resi placement on the 2nd and 3rd Gen Tacomas, to determine if our vehicle specific mounts for the Hilux will suit them, or if it will be necessary to run the standard universal resi mounts that will come with the struts and shocks. Just be aware - it's best to have a professional with the correct tools on hand to mount reservoir suspension. Drilling, trimming, adding nutserts, and hose routing all need to be taken into consideration for proper resi fitment.
  4. Jan 30, 2020 at 8:44 AM
    #184
    Crikeymike
    Jax Beach, Florida
    Hey Guys
    For the month of February 2020, Dobinsons is running a free Air Compressor deal with a full suspension kit purchase. While stock lasts. Here are the details.
    Purchase a full Dobinsons suspension with twin tube struts and shocks, and receive an AC80-3808 Air Compressor free with your order. $145 value
    https://exitoffroad.com/product/dob...ressor-kit-with-bag-hose-and-gauge-ac80-3808/
    Purchase a full Dobinsons suspension with new Monotube (resi or non-resi IMS) struts and shocks, and receive an AC80-3846 Dobinsons Zenith Air Compressor. $325 value
    https://exitoffroad.com/product/dob...ressor-kit-with-bag-hose-and-gauge-ac80-3846/
    The free item will automatically be added to your order, no coupons or anything required.
    Regarding the IMS (non-resi) and MRA (3-way adjustabl w/resi), ETA's are variable on those products, so your order won't ship right away, but you'll still get the deal. You will be emailed an ETA when the order is placed, or can ask up front.
    kidsmoke and Cred92 like this.
  5. Feb 4, 2020 at 9:42 AM
    #185
    Crikeymike
    Jax Beach, Florida
    Just updated the full kit pages so that you can select from Twin Tube, IMS (internal reservoir, no adjustment monotubes) or MRA (3-way adjustable with external reservoir) in the drop down menus. Not long until these come in!!
    Full suspension with quick ride rear (blocks instead of leaf pack): https://exitoffroad.com/product/dob...toyota-tacoma-2005-2015-with-quick-ride-rear/
    Full suspension with choice of rear leaf pack: https://exitoffroad.com/product/dob...-kit-for-2005-to-2020-tacoma-4x4-double-cabs/
  6. Feb 4, 2020 at 10:00 AM
    #186
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Hey Mike, the 'full with leaf' link specifies DC's. For the AC, do the springs simply give a little more lift than listed? I don't know the actual weight difference between the DCSB and ACLB. I've got no extra weight on a ACLB and want to go the w/leaf route...
  7. Feb 4, 2020 at 10:04 AM
    #187
    Crikeymike
    Jax Beach, Florida
    Sorry, I haven't figured out a good way to specify the difference on the page there. Yes, the front will lift just a little bit more. The rear though with a long bed will lift less, so it's suggested to go up one spring level for a long bed to achieve the 2" of rear lift. For example, the standard rear L59-110-R only give about 1" lift on a long bed, but the L59-111-R give 2" with stock/mild weight.
    Micbt25 and kidsmoke[QUOTED] like this.
  8. Feb 4, 2020 at 10:06 AM
    #188
    kidsmoke
    Flyover Country
    Understood. Thanks.
  9. Feb 4, 2020 at 10:21 AM
    #189
    kidsmoke
    Flyover Country
    so for an ACLB no extra weight and 2" of lift:
    302/221/111R/940
    Sound about right?
    And you even get to pick your colors. Damn, son.
    Micbt25 likes this.
  10. Feb 4, 2020 at 10:28 AM
    #190
    Crikeymike
    Jax Beach, Florida
    Yep, that would be my suggestion.
    Yeah, choice of coil colors and strut/shock colors too. Very hard to keep all the options in stock, but nice to be able to offer them.
  11. Feb 4, 2020 at 5:52 PM
    #191
    Trail and error
    Trail and error Well-Known Member
    Riley
    Omaha, NE
    2021 Tacoma TRD Offroad 4x4.
    So I'm pretty much looking to buy an entire kit, I need everything besides the leaf springs is there any way I could get the struts built if I am ordering all of the parts on their own?
  12. Feb 4, 2020 at 6:25 PM
    #192
    Crikeymike
    Jax Beach, Florida
    Yep. I can manually add that to the order before you pay. It's $90 for strut assembly. Once you've got the cart fully loaded, click the pay now via PayPal button, but don't pay. Send me a message and I can add in the assembly and email you the link to complete the order
  13. Mar 11, 2020 at 9:36 AM
    #193
    Crikeymike
    Jax Beach, Florida
    Here's a good example of the different color combinations of teal, black or red coils with the yellow or black struts.
    POOLGUY, '14RC and King76 like this.
  14. Mar 21, 2020 at 12:34 PM
    #194
    Crikeymike
    Jax Beach, Florida
    Lord Helmet, POOLGUY and Cred92 like this.
  15. Mar 23, 2020 at 8:10 AM
    #195
    Crikeymike
    Jax Beach, Florida
    POOLGUY likes this.
  16. Apr 30, 2020 at 6:35 PM
    #196
    Crikeymike
    Jax Beach, Florida
    '14RC and POOLGUY like this.
  17. May 7, 2020 at 11:42 AM
    #197
    El Taco Sucio
    El Taco Sucio Well-Known Member
    SoCal (805)
    Silver TRD Sport 4x4
    Mod list... Well, my paint is factory.
    $60 + $20 shipping for 4 bolts???
  18. May 7, 2020 at 12:05 PM
    #198
    Crikeymike
    Jax Beach, Florida
    Yes. Or you can pick it up for free.
    They ship by 2 day air Fedex
  19. May 14, 2020 at 5:58 PM
    #199
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    For those of you who have installed a Dobs lift kit on your Taco, how do you like it? If you have prior experience with OME, how does it compare? @C7mb, @FishingInSand, @Wixo, @TigerTacoma, and anyone else...
  20. Jun 18, 2020 at 8:29 AM
    #200
    Crikeymike
    Jax Beach, Florida
    New 3-way adjustable MRA's installed on a 3rd Gen. Same front parts, so I figured I'd share it here.
    POOLGUY likes this.
