Documenting DIY Oil Changes
Discussion in '4 Cylinder' started by The Shape, Oct 10, 2010.
  1. Oct 10, 2010 at 4:21 PM
    The Shape
    The Shape [OP] Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    If you just save all your receipts will it avoid any warranty issues.
  2. Oct 10, 2010 at 4:23 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    i havent documented any of my oil changes lol i guess im screwed
  3. Oct 10, 2010 at 4:23 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    merely keeping a written log should be fine.
  4. Oct 10, 2010 at 4:30 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    As far as I know you need to save your receipts for the oil and filters and keep a log of when you do the changes, mileage and dates. Keep in mind you need to use the proper grade oil and the OEM filter and change it according to the intevals mentioned in the owners manual...
    Another thing I do is update my service records at the Toyotaownersonline web-site. All work the dealer does to your truck is documented here and you can add any work you do yourself.
  5. Oct 10, 2010 at 4:34 PM
    The Shape
    Forrest City, AR
    OEM filter? I can't just pick up a WIX at the parts store?
  6. Oct 10, 2010 at 4:38 PM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    having to use an OEM filter to avoid warranty issues sounds a bit overkill.
  7. Oct 10, 2010 at 4:47 PM
    The Shape
    Forrest City, AR
    That's what I am thinking.
  8. Oct 10, 2010 at 4:49 PM
    The Shape
    Forrest City, AR
    Speaking of DIY oil change. I bought Motocraft Synthetic blend. Decent oil????
  9. Oct 10, 2010 at 4:58 PM
    OffroadToy
    4X4 Offroad
    It might be and I'm not really positive if useing another brand would cause any problems other that reading a few stories about guys having oil related problems and the dealer pointing the finger at a aftermarket filter. I figure why take the chance while the truck is under warrenty.
  10. Oct 10, 2010 at 5:09 PM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    Manusson Act---you can use any oil filter or oil that meets or exceeds oem. But you got to meet the schedule intervals pretty close....
  11. Oct 10, 2010 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I keep logs in a note book of whats done, at what milage....Mostly for myself. Many times I have thought I needed an Air filter, only to find I had replaced it 3K miles earlier....:eek:
  12. Oct 10, 2010 at 5:28 PM
    OffroadToy
    4X4 Offroad
    Here's a great way to log your information and keep track of everything. I downloaded it and put all the pages in plastic so they can be stored in a binder. I've added numerous pages from some of the write up's I've read here like greaseing the driveline and changeing the front and rear differencial and transfer case fluids.:)
    http://www.lieblweb.com/images/tacoma/Service_History_Guide.pdf
  13. Oct 10, 2010 at 5:34 PM
    SOSHeloPilot
    SOSHeloPilot My Favorite Song :)
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    I do my oil changes every 3,000 or 4,000 miles (with synthetic oil) and have misplaced my receipts in a move and am concerned too.
    Having about 17,500 miles on the vehicle now ... my saving grace is that I have photographed & videoed some of my service on my iPhone.
    Not having the hard copy receipts has been a concern though.
    Yesterday, I did an oil & filter change (K&N filter & Royal Purple) and OEM air filter and OEM cabin filter and I photographed & videoed that service.
  14. Oct 10, 2010 at 8:54 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    If you did have an issue, is it possible for you to simply send your oil sample in for an analysis? That could show that the condition of the oil was not the cause of the problem...just another way to back up any log you may keep...especially if you happen to lose your receipts.
  15. Oct 10, 2010 at 9:14 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
