Does 2011 have the tsb situation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hockeydad, Jun 7, 2011.
  1. Jun 7, 2011 at 10:29 PM
    Hockeydad
    Hockeydad [OP] Member
    So Cal.
    11 TRD Off Road Prerunner
    5100's and tint so far.
    Does anyone know if the 2011 has the tsb situation too.
  2. Jun 7, 2011 at 10:33 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Welcome to tacomaworld....which TSB you talking about???
  3. Jun 8, 2011 at 4:46 PM
    Hockeydad
    So Cal.
    The rear leaf springs
  4. Jun 8, 2011 at 4:48 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Why wouldn't you want your 3-leaf replaced by a 4-leaf for free? :D
  5. Jun 8, 2011 at 6:41 PM
    trot
    trot Dang.
    Aberdeen Proving Ground
    18 SW TRD OR DCSB P&T
    Yes. I mentioned a few slaps on the bump stops while getting my free 5K oil change and checkup. They ordered the parts and had me set up with new leaf pack a few days later. To me, the truck rides a tad tighter and sits a tad higher. Search the forum for a few "complaints" about the rear leaf fix.
  6. Jun 8, 2011 at 6:49 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    It's a pain in the ass. If you plan on getting a lift, just aal and call it a day.
  7. Jun 8, 2011 at 6:53 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    It isn't a problem for everyone. My '05 needed it but my '10 didn't. Both have three leaves... only the '05 bottomed out with a load... the '10 does not. Better springs for sure on my '10. I am surprised that they are still using 'soft' 3 packs, when there are firm 3 packs?
  8. Jun 8, 2011 at 6:56 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Does your "firm" leaf pack happen to have the exact same part number as the "soft" ones?
  9. Jun 8, 2011 at 6:58 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    4 leaf pack ftw
  10. Jun 8, 2011 at 7:02 PM
    David K
    Sorry man, but my '10 doesn't bottom out with a heavy load... my '05 did.
  11. Jun 8, 2011 at 7:03 PM
    David K
    It couldn't because they aren't 'soft ones'...
    I have a photo of the part # for my '10... do you have one of the soft spring part #?
  12. Jun 8, 2011 at 7:06 PM
    KPT
    09 Prerunner
    I do not, but I have an 09 anyways.
    I'm suspicious that there is only one set of 3 leaf springs installed by Toyota, and that while they may be suitable for your needs, they are not for some others. Therefore leading to the perception that some are soft and sone are not.
  13. Jun 8, 2011 at 7:23 PM
    David K
    Here is a photo of the left side 2010 leaf spring that doesn't bottom (and on Memorial Day we had a super heavy load of two packed ice chests and gear and 3 adults going to Baja). Do yours that do bottom have the -K in the number?
  14. Jun 8, 2011 at 7:24 PM
    KPT
    09 Prerunner
    Got my TSB a year and half ago so I don't have the part numbers around. I will let someone with a 2010 chime in to help us resolve this mystery.
  15. Jun 8, 2011 at 10:57 PM
    JKD
    JKD Well-Known Member
    I've loaded my '09 with up to about 500 pounds of appliances + driver/passenger + stuff in the cab and driven over rough country roads without bottoming out. Same thing with several hundred pounds of wood and yard waste in the bed.
    I documented the apparent spring rates here, showing that the springs appear to have a rate of about 300 pounds per inch of suspension deflection (each).
  16. Jun 9, 2011 at 7:46 AM
    David K
    On my '05 it was enough.. actually less weight would cause it to bottom-out. If I just had two adults in the back seat (and 2 up front), nothing in the bed, the truck (2005 DC) would bottom-out on pot holes.
    The 2010 stock 3-pak springs I have do not allow the truck to bottom-out. I kept my Ride-Rites (air bags) off my 2005 in case I would need them on the new truck... so far, I don't.
  17. Jun 9, 2011 at 7:53 AM
    David K
    It would be interersting if those who have 'soft' 3-pak springs (that allow it to bottom-out) would post their spring numbers... I have posted the 'better' 3-pak numbers photo to compare. I guess I got lucky with my 2010 Tacoma?
  18. Jun 9, 2011 at 8:00 AM
    David K
    Why not? Isn't odd that I have a 3-pak that doesn't bottom-out, but others have ones that do? If their springs have a different part number, then that would explain a lot.
  19. Jun 9, 2011 at 10:38 AM
    JKD
    Yes it would, since people were saying the 2009 suspension was improved, and that's exactly what several of us with 2009+ vehicles have experienced.
  20. Jun 9, 2011 at 10:41 AM
    JKD
    I wondered that, which is why I did the controlled test to look at spring rates, finding 300#/in per side (600#/in overall).
