does 3inch lift w 33" tires need regearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dsmooth87, Sep 10, 2011.
  1. Sep 10, 2011 at 11:17 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    do you need to regear with 33's? has your mileage dropped significantly? an if you do regear will your freeway rpms change?
  2. Sep 10, 2011 at 11:21 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    If you get 255/85/16 (a skinny 33) you will not notice much with the V-6. My MPGs did not change. I have not re-geared and defiantly do not need to with my size of tire.
  3. Sep 10, 2011 at 11:21 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    It is advised to re-gear with 33s. MPG and Power loss is inevitable. Its not necessary but will give you what you lose back. 4:10s should be fine, if your gonna run 35s in the future check out 4:56
  4. Sep 10, 2011 at 11:22 PM
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    could use it. yes. yes they are higher.
  5. Sep 10, 2011 at 11:30 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i have 33's and my 4 banger just fine, even with the added weight with winch and plate bumper, sliders, etc.....i haven't noticed much of a drop in mileage, a slight loss of power going up hills but hey the 4 banger isn't a power house.
  6. Sep 10, 2011 at 11:33 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    I wouldnt bother for 33's
  7. Sep 11, 2011 at 2:27 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Your MPGs did not change at all? What size tire did you run before them?
  8. Sep 11, 2011 at 1:20 PM
    Sprink669
    Sprink669 Well-Known Member
    I have 285/75/16's, ARB bumper and winch. My mileage with a 4.0 v6 is around 15 not a hair over though. I would like to hear from someone with this set up that has re geared and see what their mpg's are? It would be nice to get a little more power, and I even have a TRD intake and exhaust.
    JMY24 likes this.
  9. Sep 11, 2011 at 1:22 PM
    sean266
    sean266 Mr. Clean Moderator
    I have 285/75/16 with a 3" lift. No need to regear
  10. Sep 11, 2011 at 1:25 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    Does it "Need" to be re geared... No but it will help and improve your overall ride quality. You'll notice a difference in 4LO for sure and also driving around in the city. Add armor and you'll notice the difference even more. I haven't re geared but I will once I get everything done. You can drive just fine without them but they will be nice if you do it later down the road. 35's will really need taller gears though.
  11. Sep 11, 2011 at 1:45 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I run 305/65/17's and haven't noticed any real differance in power or MPG as to running the stock tires & rims {which I do in the winter} MPG's are averaging 17 overall
  12. Sep 11, 2011 at 2:15 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    I have 4.10s stock :)
  13. Sep 14, 2011 at 5:22 PM
    BrianC98TR5
    BrianC98TR5 New Member
    Brian
    Linden,TX
    what gears would a 98 V6 4x4 5spd have? 4.10s or 3.73s? It has the TR5 and TRD packages.
