Does 4.0 V6 have MAP or MAF?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBirr, Feb 22, 2019.
  1. Feb 22, 2019 at 7:45 AM
    TacoBirr
    TacoBirr [OP] Member
    Greg
    SW Ontario
    05 Taco DblCab TRD Off Road
    Hi everyone, my check engine light is on and I have codes P0606 and P0106. My Car Scanner app is saying P0106 means the manifold absolute pressure sensor (MAP) is at fault. However when searching for parts I can only find a MAP for the I4 2.7 engine and a MAF for the 4.0.
    Can anyone please clear this up for me and perhaps recommend a supplier?
    Thanks very much and happy motoring!
  2. Feb 22, 2019 at 8:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It has a MAF.
    Norton, TacoBirr[OP] and 07 sport 4x4 like this.
  3. Feb 22, 2019 at 8:02 AM
    TacoBirr
    Greg
    SW Ontario
    Awesome, Torspd, I guess I need a new app.
    Thank you!
  4. Feb 22, 2019 at 8:58 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
  5. Feb 22, 2019 at 10:35 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    That ^
    07 sport 4x4 likes this.
  6. Apr 6, 2019 at 11:32 AM
    TacoBirr
    Greg
    SW Ontario
    There's more to the story. Code P0106 actually signals a problem with the MAP or Barometric Pressure Sensor (BPS). In our V6s, the BPS is incorporated into the MAF. So I changed my MAF for a new Denso one and the code cleared, check engine light is now off.
    desertrunner24 likes this.
