Does a 08 2.7L 4x4 have a rear LSD?
Discussion in '4 Cylinder' started by akwagon, Sep 10, 2010.
  1. Sep 10, 2010 at 2:30 AM
    akwagon
    akwagon [OP] Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    Dad has a 08 4x4 Access Cab sr5 4x4 2.7L. Does it have a rear LSD? Couldn't tell from owners manual
  2. Sep 10, 2010 at 2:42 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    fastest way to tell is look at the rear diff., if its LSD there "should" be a sticker that says LSD oil
  3. Sep 10, 2010 at 6:14 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    My base model 4x4 doesnt. As far as i know ther arent any LSDs in the 08s , the TRD uses software to limit slip. I'm not 100% sure though
  4. Sep 10, 2010 at 7:32 AM
    Niknaq
    Niknaq Phightin Phils 2008 Champs
    Nick
    FLA
    2009 4wd 2.7L Regular Cab
    Dumped exhaust, 35 % factory tint, kobalt slim line toolbox, afe pro dry, toyota all weather mats, fog lights soon.
    I believe all 2009 and up Tacomas have LSD rears including 2wds.
  5. Sep 11, 2010 at 1:38 AM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    no sticker......
  6. Sep 11, 2010 at 1:50 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    "2005-2008 have mechanical LSD only on V6 models. So open diff on all I4."
    NOT!
    I owned a 2005... open differential with an E-locker... It was a 4WD Off Road.
    I believe only the SPORT TRDs had the LSD.
    In 2009, instead of the inside clutch LSD, Toyota went to the TRAC system to limit wheel spin using sensors at each powered tire and the brake system to slow spinning tires.
