Does a 4-5 inch lift exist that is not a DB lift?
Discussion in 'Suspension' started by AllMountainToy, Nov 15, 2011.
  1. Nov 15, 2011 at 7:44 PM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    I searched the threads for a 4" lift. I need more than 3 but want less than 6". I read in the forum that any lift over 3" will be a drop bracket lift like RCD Is this true? Any recommendations? And it is for a 4wd and not 2wd
  2. Nov 15, 2011 at 7:49 PM
    99PreRunner.
    99PreRunner. ^ I no longer have a Tacoma
    Alex
    Mobile, AL
    2008 GMC 3500 Duramax 4x4 - CCLB
    You could always do a SAS :D
  3. Nov 15, 2011 at 7:49 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Body lift
  4. Nov 15, 2011 at 10:55 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    It's because of the front diff, no way around it. What do you need a 4" lift for?
  5. Nov 15, 2011 at 10:57 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    4" spindle if you were 2wd
  6. Nov 15, 2011 at 10:58 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    x2
  7. Nov 15, 2011 at 11:01 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    It is true.
    anything over 3" is puts too much strain on your suspension and your front diff. Hence why the reason DB lifts exist in the first place
  8. Nov 15, 2011 at 11:19 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    nope. Engage is the tallest 4wd LT kit I think - it'll give u the height ur lookin for.
    Just go 3" c Kings or ICON c UCAs.
  9. Nov 16, 2011 at 5:54 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    3" suspension + 3" body
  10. Nov 16, 2011 at 6:11 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    when I was thinking about the all pro LT kit sarah said she was at 4". But yeah, only LT would get you higher than 3"
  11. Nov 17, 2011 at 12:12 PM
    AllMountainToy
    Northern California
    I think I am asking for too much. I have a 2.25" Procomp strut spacer now with the TSB in the rear. I have 285/70/17 BFG ATs. The cab mount is cut, the front fenders wells are trimmed.
    Extreme Flex Rock Crawling = the front is fine, it is the rear that rubs the fender flares. even popped one out and hat to pop it in. Not so worried about this since I had a ton of wight from camping gear in the back.
    Full travel (even when going in and out of a driveway/parking lot "fast") = The front tires rub the fender flares. I don't even need to be 4Wheeling.
    I don't think a 1/4" more will fix this. by removing the front strut spacers and going with the Billies at 2.5". And by doing this, my ride is compromised.
  12. Nov 17, 2011 at 12:26 PM
    TexasTacoma37
    If you are doing extreme-flex rock crawling with a top plate spacer you should be way more worried about damaging your ball joints at full droop with the spacer than with stiffening the ride with billys.
    As for the rubbing, what is the width and backspacing of your wheels?
    Stuffing 33's is a lot to ask from only 2.25" of front lift.
  13. Nov 17, 2011 at 12:51 PM
    AllMountainToy
    Northern California
    great question on the back spacing. I will have to check. I don't know off hand since the dealer went the 4WPs to have it installed. I bought it from the dealer like this. I agree with the "stuffing" comment.
  14. Nov 17, 2011 at 1:02 PM
    98tacoma27
    Ben
    Not Beech Creek
    ......and the fact that the down travel of the stock shock is now limited.
  15. Nov 17, 2011 at 8:51 PM
    AllMountainToy
    Northern California
    I didn't think with strut tower pacers you lost down travel. They aren't coil spacers
    Thanks for all the feedback guys
  16. Nov 18, 2011 at 5:41 AM
    TexasTacoma37
    You don't lose down travel on the shock itsself, but by just lengthening the entire shock assembly like top plate spacers do, you allow the suspension to droop 2.25" lower than it was designed to do, which binds the ball joints.
  17. Nov 18, 2011 at 11:17 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Your profile suggests you have a prerunner so I suggest spindle lift with AP expo leafs. Your truck would look bad ass!
  18. Nov 18, 2011 at 11:43 AM
    TexasTacoma37
  19. Nov 20, 2011 at 10:55 AM
    NC15TRD
    Nick
    PA
    Ah I didnt read that!
  20. Nov 20, 2011 at 11:19 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    or you can do a 3" lift with 1" bl.
