Does a CB Radio...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spikele, Oct 5, 2010.
  1. Oct 5, 2010 at 12:46 PM
    spikele
    spikele [OP] Well-Known Member
    I know I'm going to get flamed from this but...I was just curious if a CB radio would still work if there was no antenna. The reason I'm asking is because we're going camping and as opposed to a hand-held walkie, someone has a CB radio but no antenna.
    All we need it for is...to maintain contact while we're driving through the passes behind each other.
    Can anyone help?
  2. Oct 5, 2010 at 12:49 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Nope, gotta have an antenna unless it's one of those handheld ones with the antenna built in.
  3. Oct 5, 2010 at 12:51 PM
    spikele
    Thanks Colton! Dude, I swear if you're not a technician, you could be one. I think I've seen you almost comment on every post that I've searched on.
  4. Oct 5, 2010 at 1:53 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    No, you will fry your radio.
  5. Oct 5, 2010 at 1:57 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    ^^that's the important part
  6. Oct 5, 2010 at 2:14 PM
    TampaDude
    TampaDude Well-Known Member
    Riverview, FL
    '06 Silver 5-Lug Access Cab
    Yup...never key up the mic on a CB without a load on the antenna output, or you'll cook your transmitter circuit.
  7. Oct 5, 2010 at 6:11 PM
    TacomaMan07
    TacomaMan07 Well-Known Member
    Chandler
    Tuscaloosa, Alabama
    07 PreRunner SR5 DC
    Black Toolbox; Bed Mat; BFG ATs 265/75/16
    So, how exactly do you hook up the antenna to the CB Radio. I honestly know NOTHING about these. I just started looking at them about 10mins ago. TIA
  8. Oct 5, 2010 at 6:14 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    coax cable that you buy runs from the back of your cb to the spot you want to mount the antenna buy a bracket and screw the antenna into the coax cable
  9. Oct 5, 2010 at 6:28 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    08, Double cab, 4WD, Off Road, Tow,
    They still sell magnetic mount antennas too. Just stick on roof or any metal surface and hang cord through a window. REPEAT NEVER key the Mic without some sort of antenna on the radio. Depending on how far apart you will be, the long range family radios work pretty darn good.
  10. Oct 5, 2010 at 6:36 PM
    Incognito
    VA
    I help where I can... :D
