Does a Roof Top Tent + rack count as "heavy vehicle loading"?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Electric Shepherd, Aug 20, 2024.
  1. Aug 20, 2024 at 5:23 PM
    Electric Shepherd
    Electric Shepherd [OP] Member
    Alan
    Los Angeles
    2017 Tacoma TRD OR DCSB 6sp-MT
    I have a roof-top tent with rack and am looking at the maintenance log which suggests that if you've been "driving while towing, using a car-top carrier, or heavy vehicle loading" you have to carry out additional maintenance including oil change, when one normally wouldn't be required.
    What's everyone's thoughts on whether or not RTT + rack counts as "heavy vehicle loading"?
  2. Aug 20, 2024 at 5:27 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Oil is cheaper than an engine. Always been my thought.
  3. Aug 20, 2024 at 5:32 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    As stated ... oil cheaper than engine. But unless hauling a trailer all day everyday probably just make oil a 5k affair instead of 10k. My limited experience ...
    I hope you have bed stiffeners to prevent flexing from the rack and RTT ... cheap insurance against future damage.
    Electric Shepherd[OP] and Chew like this.
  4. Aug 20, 2024 at 5:33 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    What is your GVWR compared to what is on the door sticker?
    Some RTT weigh 150-200 pounds, some weigh 500. It all depends. And is it on there all the time or only when camping?
    I only know my Gross Vehicle Weight by taking stuff to the dump which has a weigh-in weight and an exit weight and they charge you based on the weight of the crap you dumped on them. Without my camping gear in the bed I am off memory about 250 pounds under the GVWR of my DCLB with me IN the truck with a full tank of gas. With a passenger, and camping gear, I am 100% over. But I do just a few trips per year and I pack light.
    I do not do any extra maintenance but do take it to a dealer for every 5k service, because I know they live by those complimentary 22 point inspections and anything that is out of whack, they will point out. I am more concerned on bolts coming loose, etc., but I also have upgraded shocks, leaf springs, etc. to help with the weight.
    From the google: "GVWR stands for Gross Vehicle Weight Rating, and it's the maximum weight a vehicle can safely carry when fully loaded. This includes the weight of the vehicle itself, plus passengers, fuel, cargo, and trailer tongue weight. The manufacturer assigns the GVWR and it's regulated by the United States federal government."
    Electric Shepherd[OP] likes this.
  5. Aug 21, 2024 at 10:22 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Ontop of this is the tent mounted above or below the cab. The additional wind resistance can play a bigger part than the weight.
  6. Aug 21, 2024 at 10:35 AM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    TBH I would probably base it off how much mileage you're losing compared to stock, in addition to the GVWR aspect as mentioned above.
    For example, my truck gets about 13mpg with all the stuff I've done to it. which means between bigger tires, worsened aero, and wind resistance, my truck is being put through much heavier use to achieve the same trips.
    I do my oil changes every 5k along with a 5-tire rotation and greasing the driveline and suspension components.
  7. Aug 21, 2024 at 10:54 AM
    Electric Shepherd
    Alan
    Los Angeles
    Thanks for all the advice/input. It does sound like better safe than sorry is the best policy so I'll probably do the oil change.
    In answer to some of the questions, the rack and tent probably weigh around 200-250 lbs. It sits in-line the cab so wind resistance isn't a huge factor. I did get bed stiffeners.
  8. Aug 21, 2024 at 3:23 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Lol, you people need to find something else to worry about. If a few hundred pounds in the truck is really a concern, then I hope all the "plus size" people i see riding around are following the "heavy vehicle loading" oil change schedule too.
  9. Aug 21, 2024 at 5:49 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    this is why blackstone labs exists
  10. Aug 21, 2024 at 8:10 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    My RTT and racks weigh a heck of a lot less than I do so my vote is no.
  11. Aug 21, 2024 at 9:57 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    including the weight of it would be nice
  12. Aug 21, 2024 at 10:02 PM
    RIX TUX
    you should know if the truck drives different......works harder, less mpg, slower?
  13. Aug 21, 2024 at 10:33 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :rofl:
  14. Aug 21, 2024 at 10:38 PM
    RichochetRabbit
    Define "plus size" ... the line is getting fuzzy anymore ... :anonymous:
  15. Aug 22, 2024 at 1:59 AM
    PaulyFromLA
    PaulyFromLA Well-Known Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    dude if u have a rtt in a truck bed that means u gotta change the oil every 1k miles
  16. Aug 22, 2024 at 8:52 AM
    BattleKat
    San Diego
    That only applies if you actually use it.
