Does a stock Tacoma LSD bolt right into a non-lsd equipped tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raco.the.taco, Mar 9, 2017.
  1. Mar 9, 2017 at 5:32 PM
    raco.the.taco
    raco.the.taco [OP] Well-Known Member
    Chad
    Denver, CO
    Locked, Geared & 1/2 Long Traveled
    Pelfreybilt Front Bumper, All-Pro Rear Bumper & Sliders, 35's, Toytect Boss Coilovers, JBA UCA's, DTF SUA Kit w/ E30 Deavers, Wheelers superbumps, Front & Rear Locked, 4.56 Gears
    I am wondering if my 2007 standard 4x4 V6 taco will accept a 2006 4x4 stock LSD in the rear. Should bolt right in right? If anyone has done this or is in the know please help a brotha out.
    TXpro4X4 likes this.
  2. Mar 9, 2017 at 5:44 PM
    amRRussel
    amRRussel A guy with a truck
    Andrew
    2011 Access 4banger 4x4
    Driver Mod
    I would think that it would bolt in but the electronics would be where you get in to an issue. There are a lot of knowledgeable people on this forum, I'm sure someone will chime in with a more accurate answer.
  3. Mar 9, 2017 at 5:45 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    As long as you have a non e locker rear you can swap the third member. If you had the locker I doubt you'd want to install the lsd though haha
    raco.the.taco[OP] likes this.
  4. Mar 9, 2017 at 5:46 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Swapping thirds there are no electronics. They are all in the hubs at the end of the axle tube
    raco.the.taco[OP] and amRRussel like this.
  5. Mar 9, 2017 at 5:48 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    *unless you have an elocker but that's irrelevant to this thread
  6. Mar 9, 2017 at 5:57 PM
    raco.the.taco
    Chad
    Denver, CO
    Thanks! It's not electronic. Just a 3rd member. I'll buy it then :)
  7. Mar 9, 2017 at 5:58 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Assuming you have a v6 the gear ratio should
    Be the same. Just double check before you buy.
  8. Mar 14, 2017 at 8:25 PM
    raco.the.taco
    Chad
    Denver, CO
    I have learned a lot from google these last couple days... it seems like they are saying that a LSD is not what I want for off-road? I figured it'd be better than an open diff right?
  9. Mar 14, 2017 at 11:16 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Are you buying the entire 3rd, or just the LSD out of it?
    An LSD is better than an open diff off road, though not as good as a locker. But for trucks that are mainly driven on the street I find LSDs more useful for wet weather and snow, whereas the locker could only be used off road.
    If you are just buying just the LSD there will be significant install costs needing to be done by a gearing professional. In which case I would look for a better LSD than the subpar OEM unit, such as a Trutrac. If doing a complete 3rd swap for cheap, then it is a decent budget upgrade.
  10. Mar 15, 2017 at 5:40 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If you're going to buy an LSD and install it I would not recommend OEM. Really only because if you're going to go through the trouble of putting ANYTHING in there, do it once, and do it right. I'd recommend the Detroit TruTrac LSD if you're going the LSD route.
