Does a Tacoma become a Rattle Trap with Time and Mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saf023, Jan 10, 2010.
Does a second generation Tacoma become a rattle trap with time and mileage?
  1. I have less than 25K miles and it rides and handles as tight and solid as ever.
    453 vote(s)
    32.4%
  2. I have between 25K and 50K miles on my Tacoma and it rides and handles as tight and solid as ever.
    271 vote(s)
    19.4%
  3. I have between 50K and 75K miles on my Tacoma and it rides and handles as tight and solid as ever.
    160 vote(s)
    11.4%
  4. I have between 75K and 100K miles on my Tacoma and it rides and handles as tight and solid as ever.
    145 vote(s)
    10.4%
  5. I have over 100K miles on my Tacoma and it rides and handles as tight and solid as ever.
    160 vote(s)
    11.4%
  6. My Tacoma does not ride and handle as tight and solid as it used to.
    210 vote(s)
    15.0%
  1. Mar 23, 2015 at 8:07 AM
    #281
    Mulloyjr
    Mulloyjr Member
    Lomita CA
    06 Tacoma
    My rear end when it's cold rattles big time. Chased it to the rear fenders and or rear wheel wells. Stuffed some rolled up rags between the layers of plastic in the wheel well. It helps but still there. Embarrassing feels like the entire world is starring at me. Going to the dealer today to do some recall work. Will ask them if there is anything can be done to fix the rattle. Will post the outcome. You can hear the rattle by taking your fist on banging on the rear fender. Had the rattle since bought new in 2006.
  2. Mar 23, 2015 at 8:13 AM
    #282
    Bawlmore
    Bawlmore Bite my shiny metal bumper.
    Tim
    Kingsville, MD
    2011 TX Pro 3" OME Lift with sliders, armor, and Yoko 33s
    Just broke 50K on my 2011 and I have have 2 distinct rattles in my dashboard, one by the steering column and one by the glove box... there is also one forming in the driver door. Planning on ripping the cabin apart when it gets warmer and figuring out what is going on... only rattles on cold (below 20 degrees) days.
  3. Mar 23, 2015 at 8:40 AM
    #283
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    the rear leafs do tend to yield over time on large bumps so i would have to say yes the truck isn't what it was the first day it came off the lot but then again, what truck ever is 100,000 miles later?
  4. Mar 31, 2015 at 10:54 AM
    #284
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    50k miles on mine and the dash noise sounds like the radio is gonna fall out in yer lap.
    There's other noises too. Intake rattle, glove box, driveline thunk when stopping.
    After 7 years you expect some, but this is too much IMO. The whole truck is just very light weight construction IMO & stuff is shaking loose.
    But it still goes like hell when you mash the gas. I can forgive a lot if it keeps doing that. ;)
  5. Mar 31, 2015 at 11:26 AM
    #285
    prerunner 06
    prerunner 06 Well-Known Member
    David
    Springfield OH
    06 Prerunner SR5 DCSB
    125K, no rattles but I drive very conservative, I miss all pot holes if possible and go over RR tracks slow, idle speed when cold. Don't see a lot of other drivers doing that they just run through everything so not sure how solid it would be if I was normal (did I say that)?
  6. Apr 9, 2015 at 2:58 PM
    #286
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Hmmm...well they are built in Mexico.... :rolleyes:
  7. Apr 9, 2015 at 3:03 PM
    #287
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    I'm getting this more and more. I don't believe it's my radio now.
    I believe it's because all the plastic A/C & defroster ducts have shrunken with age & are loose at the ends where they should be jammed tight.
    I say that because of the sounds, which sound like thin plastic jiggling about.
    Anyhow, they should be easy to shim up, but probably very difficult to get to with the dash in place. :(
  8. Apr 9, 2015 at 5:49 PM
    #288
    Bawlmore
    Tim
    Kingsville, MD
    I have a feeling the plastic holsters that keep all the wiring in place have come loose and are bouncing around. I'll be sure to report my findings when I rip it all open.
  9. Apr 9, 2015 at 7:35 PM
    #289
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    My 08 Tacoma just turned 200,000 miles today and yes there are noises and rattles but that is normal wear and tear. If anyone finds a vehicle that remains tight and silent with this many miles let me know.
