Does a throttle position sensor need set on a 1999 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rjred, Jun 10, 2024.
  1. Jun 10, 2024 at 5:19 AM
    Rjred
    Rjred [OP] Member
    Rick
    1999 trd off road
    I have a 1999 Tacoma. My check engine light came on and after doing the scan I learned it was the throttle position sensor. Replacing the part doesn’t seem too bad on my model but I was curious if I had to set it a certain way (like an old school rotary cap) like there’s a timing aspect that gets thrown off if I position it incorrectly?
  2. Jun 10, 2024 at 6:07 AM
    ChinoXL
    ChinoXL Well-Known Member
    95 Tacoma V6 MT 4x4 Xtracab
    My TPS is reading 12.9% which is higher than the spec of 7-11% and I believe I will have to replace the sensor.
    https://www.customtacos.com/threads/tps-throttle-position-sensor-how-to-set.7845/
    “Your TPS does need to be adjusted, loosen both set screws on the sensor and apply vacuum to the thottle opener (dash pod). Insert a 0.026 thickness gauge between the throttle stop screw and stop lever. Connect an ohmmeter to the bottom two terminals of the sensor. Gradually turn the sensor clockwise until the ohmmeter deflects and tighten both set screws”
    Another guy in that thread says he did the adjustment without applying vacuum, engine off.
  3. Jun 11, 2024 at 6:20 AM
    Rjred
    Rjred [OP] Member
    Rick
    1999 trd off road
    Thanks for the help
  4. Jun 11, 2024 at 8:03 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Just know that sometimes people experience the throttle body getting stuck so that it rests just barely shy of being closed. This may not be a sensor issue…
    ChinoXL likes this.
  5. Jun 11, 2024 at 9:34 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I have replaced a TPS on a 99 and a 2000 and never adjusted either of them. The ECM controls it.
    ChinoXL likes this.
  6. Jun 11, 2024 at 10:32 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Easy way to check is look at the mount screw holes. Earlier years had slots and should be "set". Later years just had round mount holes, your 99 should not need adjustment.
    Now that being said and while Toyota does not specify an "adjustment", there is a tiny bit of slop between the mount screw and the hole. We are talking maybe a degree at most.
    Early type with adjustment slots.
    ChinoXL likes this.
  7. Jun 11, 2024 at 10:45 AM
    Rjred
    Rjred [OP] Member
    Rick
    1999 trd off road
    Thanks, mine has the round mounts and can’t be adjusted like the one in the diagram shown. Appreciate the help!
  8. Jun 11, 2024 at 1:05 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Lucky pre posirioning? The ECM isn't controlled by the tps (throttle position switch) its job is input to % of throttle opening or positioning to be analyzed by the ECM. Inputting switch.
