Does adding a rear leaf spring void factory warranty?
Discussion in 'Suspension' started by wolftree, Jun 21, 2012.
  1. Jun 21, 2012 at 9:32 AM
    wolftree
    wolftree [OP] Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I am in a debate with the Toyota field service tech over whether adding a third party (local spring shop) rear leaf spring will void factory warranty. Has anyone ran into this before?
  2. Jun 21, 2012 at 9:37 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You will not be able to get any Warranty work done to the leaf springs because they are after market. But no it will not viod the Truck's warranty.
  3. Jun 21, 2012 at 1:09 PM
    wolftree
    Rick
    Ohio
    I am trying to talk the Toyota Factory rep into authorizing having a third party (spring shop) add an additional leaf to my suspension 2+1 leaf. As I have a regular cab it does not come under the TSB, though I have all the same problems, squatting under load, excessive body lean, wander, sway and undeersteer to a certain point. I would prefer the spring shop leaf to the Toyota TSB.
  4. Jun 21, 2012 at 1:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Have the spring shop do it, no harm done. Toyota will no longer warranty any items associated with your rear leafs but can not void the warranty on the whole truck. The only gray area you could possibly run into is say if one of your U-joints were to blow out. Toyota could point to the AAL, blame it on you for altering the drive line angle and then you'd have a fight on your hands. Legally, they'd have to prove that your aftermarket part caused their part to fail.
    mrjordan415 likes this.
