Does all of this seem right?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bwilliamson, Mar 30, 2010.
  1. Mar 30, 2010 at 12:31 AM
    bwilliamson
    bwilliamson [OP] Well-Known Member
    Brad
    Magnolia, KY
    I bought an OBD2 scan tool today and after clearing out the codes stored I did a live data stream of what my 2002 Tacoma EXT Cab 4x4 TRD and this is what I got. If you see anything that is out of the ordinary please let me know. Its not throwing any codes right now and hopefully it will stay that way.
    Misfire Monitor Supported
    Fuel Systems Monitor Supported
    Comprehensive Monitor Yes
    Misfire Monitor Complete/N-A
    Fuel Systems Monitor Complete/N-A
    Comprehensive Monitor Complete/N-A
    Catalyst Monitor Supported
    Heated Catalyst Monitor Not Supported
    Evap Systems Monitor Supported
    2nd Air System Not Supported
    A/C Monitor Not Supported
    Oxygen Sensor Monitor Supported
    Oxygen Sensor Heat Supported
    EGR System Monitor Not Supported
    Catalyst Monitor Not Complete
    Heated Catalyst Monitor Complete/N-A
    Evap Sys Monitor Not Complete
    2nd Air Sys Completed
    A/C Refrigerant Monitor Complete/N-A
    Oxygen Sensor Monitor Not Complete
    Oxygen Sensor heat Monitor Not Complete
    EGR System Monitor Complete/N-A
    Fuel System1 Status ClosedLoop
    Fuel System2 Status -----
    Cal Load Value 14.9%
    Engine Coolant Temp 90 degrees C
    Short Term Fuel Trim B1 3%
    Short Term Fuel Trim B2 7%
    Long Term Fuel Trim B1 0%
    Long Term Fuel Trim B3 8%
    Engine Speed 835 RPM
    Vehicle Speed 0 MPH
    Ignition TIming Advance(CLY1) 15 degrees
    Intake Air Temp 11 Degrees C
    Mass Air Flow Sensor 3g/s
    Absolute Throttle Position 9%
    Location of Oxygen Sensor B1S1
    Oxygen Sensor Voltage B1S2 .7 volts
    Short Term Fuel Trim B1S2 99%
    Please tell me all of that is within parameters.
