Does an additional 1" of ground clearance really make a difference?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rainman443, Aug 6, 2021.
  1. Aug 6, 2021 at 5:08 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Rub the tires you have now the right way and you may just get that extra inch out of them. Be gentle.
    Junkhead and golfindia like this.
  2. Aug 6, 2021 at 5:12 PM
    Rainman443
    Rainman443 [OP] Well-Known Member
    A Big Island
    2021 TRD OR
    This silver pipe, unsure of what it is. right next to the crossmember, hangs down to the height of the rear diff, maybe even further. Does a suspension lift raise the crossmember and whatever this pipe is?
    Also those things below the crossmember hang pretty far down too
  3. Aug 6, 2021 at 5:13 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
  4. Aug 6, 2021 at 5:19 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Your lift kit gives you zero added ground clearance. You have .5 inch more ground clearance with 265/75 as opposed to stock 265/70.
    MJTH and HoytK9 like this.
  5. Aug 6, 2021 at 5:23 PM
    Shellshock
    Iowa
    No it just kills your fuel economy.
  6. Aug 6, 2021 at 5:25 PM
    Mark77
    Mark
    Nothing yet
    This just made it the official Friday thread.
  7. Aug 6, 2021 at 5:27 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    That is the blow off tube for the turbo. Hold down your emergency flasher to engage.
    44-16 Taco, TacX2, Junkhead and 2 others like this.
  8. Aug 6, 2021 at 5:27 PM
    Mastiffsrule
    Scott
    Silver pipe is expansion chamber for 2 stroke upgrade
  9. Aug 6, 2021 at 5:30 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  10. Aug 6, 2021 at 5:32 PM
    OnHartung'sRoad
    Wow, how did you flatten that? Its so banged up already! :eek:
    I’m kidding.... You are correct, it certainly doesn't look good the first time you see it, right? Besides better offroad tires, consider a reroute of that for more clearance because that crossover exhaust is the first thing to get hit on rocks if you want to be doing any off-roading over rougher terrain.
  11. Aug 6, 2021 at 5:34 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    No you don't. Your suspension lift did not increase the height of the lowest points of your truck. You gained 1.5" that looks like lift in your wheel wells from the lift and actually gained .5" of real lift from your tires.
  12. Aug 6, 2021 at 5:40 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Rainman443[OP] and Junkhead like this.
  13. Aug 6, 2021 at 5:41 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Clearance is nice, but more importantly big tires roll over obstacles better. If you look at the real off-roaders, they aren't running big lifts and big tires, they're running modest lifts with lots of travel and big tires.
    gudujarlson likes this.
  14. Aug 6, 2021 at 5:42 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    And allows to drop pressure meaning more sidewall before hitting the wheel.
  15. Aug 6, 2021 at 5:55 PM
    #35
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Once you air down it’s not even a full 1”…
  16. Aug 6, 2021 at 5:55 PM
    #36
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    My experience is that these things make the most difference in order of importance as far as slow speed off road performance.
    4wd (duh)
    Tire compound and thread pattern
    Tire diameter
    Ride height
    Off-road traction control (highly under appreciated)
    Locking diffs
    Edit: tire width might be important too, but I personally have not experimented with it
  17. Aug 6, 2021 at 6:41 PM
    #37
    Mastiffsrule
    Scott
    Mark77 and hiPSI like this.
  18. Aug 7, 2021 at 8:47 AM
    #38
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    depends
    an etra ‘ inch ‘ & Uv got a New girl friend when U get home ..............................
  19. Aug 7, 2021 at 8:48 AM
    #39
    OnHartung'sRoad
    Fix’d it. Sorry for the sarcasm. You have to admit though, those crossover exhaust pipes look damaged and accidentally flattened fresh off the lot.
  20. Aug 7, 2021 at 8:53 AM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    Then I'm not sure it's really appropriate to call whatever you are doing 'wheeling'.
    Form over function will never a good wheeler make.
    Tip. Don't touch it after a drive. And it can be relocated. (Toyota dummied up here)
