Does any lights come on if I don't have TPMS in my new rims?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rainman443, Sep 7, 2021.
  1. Sep 7, 2021 at 12:11 PM
    Rainman443
    Rainman443 [OP] Well-Known Member
    A Big Island
    2021 TRD OR
    I have new tires and rims. Don't wana pay the extra $200 for a sensor swap since I air down and up using gauges anyways. Is this gonna make my taco complain?
  2. Sep 7, 2021 at 12:12 PM
    bigmace
    bigmace Well-Known Member
    Salem, OR
    2020 DCLB SR5 4x4
    Yes of course. Why would they come with sensors if they didn't do anything.
  3. Sep 7, 2021 at 12:16 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I pulled the TPMS years ago. Doesn’t cause any issues except the tire pressure light is always on.
  4. Sep 7, 2021 at 12:19 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Put a piece of black tape over the tire light symbol.
    shakerhood likes this.
  5. Sep 7, 2021 at 12:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The yellow tire pressure light in the gauge cluster will flash then illuminate solid when the truck is on. I sold my OEM wheels and tires the day after I took the truck home, so the light has been doing that for the past two and half years. I usually idle for 30 sec after engine start in the morning and use the flashing tire pressure light as a timing reference...
  6. Sep 7, 2021 at 12:27 PM
    Rainman443
    A Big Island
    2021 TRD OR
    Does it beep? That's the only thing I can't handle is the Toyota beep
  7. Sep 7, 2021 at 12:32 PM
    Rainman443
    A Big Island
    2021 TRD OR
    Or is there something that can clear the codes y'all?
  8. Sep 7, 2021 at 12:33 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    The light will stay on because there is a “failure” in the system. Does your state do a safety inspection? If it does they will check for a working light when the ignition is on then make sure it goes off to show it’s running fine. Remember this system was brought to you by the government, Ford, and Firestone in response to low tire pressure on Ford Explorers. Now we all have to have it.
  9. Sep 7, 2021 at 12:41 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I run winters without TPMS for 6 months a year, warning flashes and then stays on 30 minutes into a drive. Once it's parked in the driveway (tpms tires are in the garage) it goes away. I can go most of the winter commuting without it coming on- road trips it's on though..
