Does anybody know what this is for?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steelerfan7p, May 8, 2009.
  1. May 8, 2009 at 5:57 PM
    steelerfan7p
    steelerfan7p [OP] My other car is a Bugatti
    Yes
    Fairmont, WV (1 Hour South of the City of Champi
    Non-TRD, Non-SR5, Non- Prerunner
    Rear Leaf Spring TSB, Metra IPod Adapter, AFE Pro Dry S Air Filter, I was added to the truck to make it better, so does that count as a Mod?
    This plug that is hanging down is underneath the steering wheel in the column. It doesn't plug into anything. It's on my truck that has no options and its on my father-in-law's truck which is SR5 TRD off road. I want to cut one of the metal connectors out of it to hook up my cruise control but just wanted to know what its for. The only thing I can figure is that they make one standard harness for a ton of different vehicles but not all the plugs are used in every vehicle. :notsure:
  2. May 8, 2009 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It looks like the Steering Angle Sensor wireing harness.....
  3. May 8, 2009 at 6:42 PM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    it's where you plug in the flux capacitor
  4. May 8, 2009 at 7:00 PM
    steelerfan7p
    Yes
    HAHA you guys are too much.
  5. May 8, 2009 at 7:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was being serious.
  6. May 8, 2009 at 7:02 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    could it be a plug in for a diagnostics scanner?
  7. May 8, 2009 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think so. The OBD port is attached to the dash.....I think its for the Steering Angle Sensor....Its part of the CAN system.
  8. May 8, 2009 at 7:22 PM
    beastlytaco
    Ian
    08 Access Cab SR5
  9. May 9, 2009 at 5:43 AM
    steelerfan7p
    Yes
    Well, since it doesn't go anywhere, I'm cuttin it apart.
  10. May 9, 2009 at 5:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are you absolutly sure it doesnt go anywhere?
  11. May 9, 2009 at 6:01 AM
    steelerfan7p
    Yes
    Yea, when I took the bottom piece of plastic off underneath the steering wheel for the first time, it was just hanging there. And in my F-i-L's truck, which has all the steering controls for the radio and everything, his was the same way. My guess is its for another vehicle and instead of making different wiring harnesses, they just made a generic one for all types of vehicles.
  12. May 9, 2009 at 6:03 AM
    steelerfan7p
    Yes
    Or it could be some type of test plug. I dunno.
