does anybody sell adjustable cambers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnw, Aug 11, 2009.
  1. Aug 11, 2009 at 3:31 PM
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    im thinking i need adjustable cambers for the truck does anybody sell those?
  2. Aug 11, 2009 at 3:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    adjustable cambers?? care to elaborate?
  3. Aug 11, 2009 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. :confused:
  4. Aug 11, 2009 at 4:06 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
  5. Aug 11, 2009 at 4:15 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Do you mean something to adjust your camber? If so, that would be an Upper Control Arm (UCA) and then the answer is YES. Light Racing, Total Chaos, Icon, Total Chaos all sell UCA's that allow you to change caster, camber and toe... Check the alignment sticky at the top of this forum and read the links on tirerack.
  6. Aug 11, 2009 at 4:19 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    if you mean camber bolts...you already have them, they are on your lower control arm.
  7. Aug 12, 2009 at 9:31 AM
    johnw
    john
    orlando florida
    yah thats what i mean sorry for being so blank about the question i helped my cousin instal a drop kit on hit 03 f-150 lighting svt and he got new camber bolts and it aloud you to adjust the camber for the lowering but his was on the top bolts not the bottom
  8. Aug 12, 2009 at 12:32 PM
    johnw
    john
    orlando florida
    bump
  9. Aug 12, 2009 at 12:44 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    the only ones we have are on the bottom. Nothing on the top is adjustable. you can get modified upper control arm's if you want alot of lift but even those are not adjustable, just longer. You'd still use the lower camber bolts to get the front end aligned.
    And why do you think you need them?
  10. Aug 12, 2009 at 4:24 PM
    johnw
    john
    orlando florida
    because when i lift it i dont think i will be able to have proper alignment after the lift
  11. Aug 12, 2009 at 4:45 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    you can do 3 inches with no modification, if you go to 6 then you will need upper control arms, which are not adjustable, but since they are longer they allow the lowers to move with the camber bolts and obtain a proper alignment.
  12. Aug 12, 2009 at 4:49 PM
    johnw
    john
    orlando florida
    ok because im doing procomp front 3 inch lift with toy tec rear tsb AAL
  13. Aug 12, 2009 at 6:24 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    dont listen to that guy he doesnt know what he is talking about ("you can do 3 inches with no modification" - you can, but you wont get OEM specs out of your alignment..."if you go to 6 then you will need upper control arms" - if you do 6" you need a drop bracket kit..."which are not adjustable" - some ARE adjustable (lightracing and i belive icons, to name a few)...:rolleyes:)
    anything over about 2" on our truck will not be able to get OEM alignment specs w/o new UCAs. i've heard good things about the light racing UCAs, and the price is not bad either at $450 from wheelers...
  14. Aug 12, 2009 at 6:27 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    x2. i had to get tc uca after installing toytec coilovers set only at 2''
  15. Aug 12, 2009 at 6:31 PM
    johnw
    john
    orlando florida
    oh true thankyou for info and without oem alignment how bad should it be of and will it eat tires horribly
  16. Aug 12, 2009 at 6:35 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i have the bilstein 5100 set at 2.5" w/ the OEM coils. i got my alignment pretty close... you will wear the outside of your front tires, but its really not that bad on mine...just make sure you rotate frequently and you should be ok...but spend the $450 if you have it lying around!
  17. Aug 12, 2009 at 6:39 PM
    johnw
    john
    orlando florida
    ya i dont got it lying around im buy the procomp front 3 inch lift then toytec lift AAL tsb
  18. Aug 12, 2009 at 8:05 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Apparently i do know what i am talking about considering i have a full 3in procomp kit on my truck...i said you can do 3 without modification (you agreed) ... so is another guy in charlotte that isn't on this board...its not dead on but it is "within acceptable specs"....as for your 6inch's comment, if you get a 6 inch kit (fabtech etc) it will come with a drop bracket so why mention it, most people go with a total chaos UCA which isn't adjustable, Icon's are...they are the only one's i've seen...but i don't scour the web looking for UCA's i have better things to do.
  19. Aug 12, 2009 at 8:18 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    as i also stated, you will NOT get OEM specs w/ 3" lift and OEM UCAs...like you said, "its not dead on" which means increased outer tire wear and cupping....hence the reason for needing UCAs w/ more than ~2 lift (lightracing, TC, Camburg, icon, all-pro, etc...i have nothing better to do than scour the interwebz all day...:D)
  20. Aug 12, 2009 at 9:15 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    With your 3 inch lift, your truck will handle better with aftermarket uca's. Light racing uca's are a good choice and a good price. And since they are adjustable you can fine tune them to get the best alignment possible.
