Does anyone actually use their dimmer switch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sporttracguy, Jan 6, 2012.
  1. Jan 6, 2012 at 9:12 AM
    sporttracguy
    sporttracguy [OP] Well-Known Member
    Puyallup, WA
    Magnetic gray tx pro double cab
    3" Lift spidertrax wheel spacers grillcraft grill Color matched grill Color matched eylids PIAA 520 lights behind grill HIDs in headlights and fog lights Debadged Plasti dip lower grill
    Just installed some new lights on my truck and I was thinking about installing a switch where the factory dimmer dial is (just to the left of the steering wheel) Does anyone actually use this thing? I cant for the life of me figure out a situation where I would want to dim down my dash.
    I'm thinking about just setting it on high and hiding it behind the dash. Does anyone have a simple way to remove the switch? I tried a little prying but it started to mar up the dash so I stopped. Is there an easy access from behind the dash or do I need to just go for it?
    I have a tx/pro double cab so all of the extra blanks in the dash are used up by the factory bells and whistles, doesn't leave much room for my own toys.
    Thanks
  2. Jan 6, 2012 at 9:17 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i'm thinking the same thing for some reverse (tailgater) lights, it pops out of the dash but it's easiest if you can get a hand behind it. Thats what sucks about the off roads, no extra blanks for switches
  3. Jan 6, 2012 at 9:27 AM
    vtdog
    vtdog Well-Known Member
    NH
    If you use the dimmer to keep the lights below max they will last essentially forever and you can save yourself some money in replacement costs down the road. I have never replaced a light in a tacoma dash, but based on previous experience with other cars is it either a real PITA to do it yourself or very costly to pay the labor to have a dash opened.
    If you do a lot of night driving it is simply easier on the eyes to have reduced dash lighting. In addidtion, your night vision will be better. One car manufacturer (SAAB) was famous for a switch that turned off all dash lights except the speedo if you wanted.
  4. Jan 6, 2012 at 9:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've used it on long highway trips. I'll set the cruise control and dim the dash lights. I found it's easier on your eyes without all the lights shining back on you. Other than that, it's kind of stupid because not all the LEDs in the dash actually dim.
  5. Jan 6, 2012 at 9:29 AM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    I use mine almost everyday, I dim the lights at night and make it brighter during the day. I hate the light shining back at me at night.
  6. Jan 6, 2012 at 9:31 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    mine is set a smidge above completely off at night...and it stays there 24/7.
  7. Jan 6, 2012 at 9:32 AM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    I typically use it when I'm stalking someone at night
  8. Jan 6, 2012 at 10:01 AM
    BadgerCO4x4
    BadgerCO4x4 Active Member
    Gilbert, AZ
    '11 DCSB SR5 4x4
    Rear leaf TSB, extra D-rings in bed
    This is what I do and exactly why I do it, night vision and reduced eye fatigue.
  9. Jan 6, 2012 at 10:17 AM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    I generally turn mine down a little, especially on long drives. My Corolla has very bright, white gauges...those get turned down a lot.
    As far as more switch space, I had to do this:
  10. Jan 6, 2012 at 10:22 AM
    Aw9d
    Aw9d That one guy
    I have a dimmer switch?
    No never used one in any car ever in my life. I like bright gauges.
  11. Jan 6, 2012 at 8:54 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Every time I drive after dark. I adjust it according to the light conditions around me--brighter for city, dimmer for highway. Always just enough to see the guages clearly at a glance without cocking up my night vision. Seeing what's in front of me is ALWAYS more important than what's going on under the hood.
  12. Jan 6, 2012 at 10:02 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    +1
  13. Jan 6, 2012 at 10:03 PM
    TunnelDV
    TunnelDV Well-Known Member
    Derek
    Denver
    10 4Dr Tacoma White
    It is a good idea to dim the instrument lights at night. Pilots are trained to dim their instrument slights at night to improve their visibility outside. Works the same for driving. Dimming the instrument lights to just bright enough to see them allows you to see more outside.
    Derek V
  14. Jan 6, 2012 at 10:05 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    mine doesn't work.... so I don't use it :)
  15. Jan 6, 2012 at 10:08 PM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    On long drives all white at 100% hurts my eyes so yes, I use it often. :)
  16. Jan 6, 2012 at 10:10 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i use it at night. back roads and maybe interstate i turn it down. down town or city driving i turn it up.
  17. Jan 6, 2012 at 10:19 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    Yep use mine all the time. Bring the lights up bright in nighttime city traffic and when out in the country with no ambient lighting, dim them down. Helps the night vision and the ability to see whats on the road, the shoulders etc.
    Ray
  18. Jan 6, 2012 at 10:23 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    All the time. When driving at night on unlit roads I'll turn them off and set the cruise control in the city it will be about 1/4 the way up.
  19. Jan 6, 2012 at 10:51 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Yep, my old 9-5 had the classic NightPanel switch. I loved it actually - it turned all lights off except for what was immediately necessary - if you were going under 80 MPH only 2/3 of the speedo would light up. If you were low on gas or your revs get to high, it would turn those on. It was a nifty switch - at least for me, who has somewhat crappy night vision. If I ever got on a long night trip I will use the factory dash dimmer in my Tacoma for sure.
  20. Jan 6, 2012 at 10:55 PM
    Warhorseforever
    Will
    Sand Lapper
    I'd love to have one of those on my taco.
