Does Anyone Acually Use the Power Outlet in the Bed????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, Mar 6, 2015.
  1. Mar 20, 2015 at 5:45 AM
    #81
    Cloudmaster
    Cloudmaster Well-Known Member
    Dustin
    Elko,NV
    2006 Tacoma
    Off road things
    I've also used it to run a coffee grinder and a coffee machine. I have a small 13 foot camp trailer and I can plug the trailer in and have power in it.
  2. Mar 20, 2015 at 6:13 AM
    #82
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    what coffee makers are you guys using, ive never seen one under 400 watts
  3. Mar 20, 2015 at 6:25 AM
    #83
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Standard USB ports put out 0.5 Amps not 0.5 Watts. USB is 5volts so you have to convert from 12 down to 5, and then 0.5 Amps at 5 volts is 2.5 watts. Most of the chargers are 1 to 2.1 amps at 5 volts though which is 5 and 10.5 watts respectively not taking into account conversion losses.
    Buy a 2.1amp USB cigarette socket adapter and things will charge much faster.
  4. Mar 20, 2015 at 6:42 AM
    #84
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Ahh standard USB is actually 500 ma/2.5 W, thought I was reading that as 500 mw which would have been a half watt. That's still a lot less power than the inverter in the bed though.
    I do have a USB cigarette socket adapter, because my truck's USB port always has a music stick in it. It's still completely worthless for trying to charge a Garmin Alpha handheld and dog collar at the same time through a single connection though.
    Not sure what kind of charger the Alpha uses, but it has a splitter on the end to plug both devices into a single charger. After an hour of driving around with the USB cigarette adapter, I only get maybe a 5 % charge. After an hour of driving around on the AC outlet in the bed I get way more than that, probably at least 30 - 40%.
  5. Mar 20, 2015 at 6:50 AM
    #85
    TheMuffinMan
    Coeur d'Alene, ID
    The output of the USB port built into the dash is 0.5 mA. I never use it to charge anything. Cigarette socket adapters for the win. I have 2 adapters, each have 2x2.1 Amp usb ports for charging.
    Phone/Tablet, Garmin Montana GPS, 650 Lumen helmet light, helmet camera, and portable 13Ah USB battery pack when needed. The nest of cables can get intense but it works out.
    Two of these: http://www.amazon.com/gp/product/B00MSYQ96A/ref=od_aui_detailpages00?ie=UTF8&psc=1
  6. Mar 20, 2015 at 7:09 AM
    #86
    JADaus
    JADaus JD
    JD
    Minneapolis
    '13 Tacoma TRD Sport
    Here's what I've done: Bestop 76308-35 Black Diamond Supertop N-Fab T124LB Light Bar 2, Hella 700FF driving lights with 100w bulbs 2, Turbo SII CREE Pair 9 Inch 160w LED lights 17" Black Rock Series 997 Type 8 Matte Black Wheels 265/65-R17 Cooper Discoverer A/T3; (E class) Blue Sea Systems 5026 ST Blade Fuse Block Blue Sea Systems 285-Series Surface Mount 50A Circuit Breaker Vinyl decal by ruggedT: http://tinyurl.com/qg9bw7v Firestone W217602407 Ride-Rite Kit Daystar KU09140BK Air Bag Cradle Dog platform mod Fog lights anytime mod LED interior lights 886 Backup light mod Supreme Suspension Tacoma Lift Kit 2" Front Suspension Lift Carbon Fiber Seat Heater Kit Here's the Plan: El Cheapo Heated Mirrors mod Bilstein 24-239370 Shock Absorber (front)
    I've used it quite a bit to charge my dog collar when out hunting. I've also used it with a small crock pot while on my way hunting (had to warm the chili somehow).
    I also have a battery charger (which also has a air pump for my airbags) that i can trickle charge and a spot light for shining deer i can also charge back there.
    i haven't used it a lot, but it's come in handy a few times.
  7. Mar 20, 2015 at 7:19 AM
    #87
    Snowbrdr1220
    PA
    Hmmm, didn't know that outlet could run a small crock pot. I see some warm homemade chili or beef stew in my future after a cold morning of Steelhead fishing next fall :)
  8. Mar 20, 2015 at 7:31 AM
    #88
    Snowbrdr1220
    PA
    I have a Mr Coffee maker that is 400 watts, but the pot is so tiny that I don't like messing with it. I usually just heat up a big pot of water on a gas burner or over the fire and use a french press out in the woods.
  9. Mar 20, 2015 at 7:45 AM
    #89
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I was just going to post a video clip of that scene. :D
  10. Mar 20, 2015 at 7:48 AM
    #90
    ThirdCoast
    ThirdCoast Well-Known Member
    Houston
    2011 DC TRD TX
    yep used it many a time
  11. Mar 20, 2015 at 7:52 AM
    #91
    CodyWayne718
    CodyWayne718 Active Member
    Indiana
    2011 Trd OR access cab
    Tried running a shop vac in my 06 x runner. Didn't work. Never used it again
  12. Mar 20, 2015 at 7:55 AM
    #92
    Mclovin80
    Mclovin80 Not Well-Known
    Tampa, FL
    2021 LR TRD Pro
    It's a good stereo hookup for tailgate parties and bonfires!
  13. Mar 20, 2015 at 7:55 AM
    #93
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    You need to look at the amp. Not just plug it in and hope for it to not blow the fuse. 3.3 amp
    I use it to charge laptops during road trips. Few tools and lights.
  14. Mar 20, 2015 at 10:41 AM
    #94
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    You whppersnappers are spoiled rotten. Camping is supposed to be out there roughing it, sleeping on rocks and drinking cowboy coffee made over a camp fire. Air mattress pumps and coffee grinders! Humph! Next, someone will say they always pack an electric razor for out in the boonies. You wanna take something useful? Take a woman. Way more satisfying than french pressed coffee. What the hell is french pressed coffee, anyway?
  15. Mar 20, 2015 at 10:46 AM
    #95
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    You can still make french press over the fire, all you need is hot water and a press. I do it almost every time.
  16. Mar 20, 2015 at 10:53 AM
    #96
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    LMFAO!
  17. Mar 20, 2015 at 10:53 AM
    #97
    Aw9d
    Aw9d That one guy
    Woman, useful?
  18. Mar 20, 2015 at 10:57 AM
    #98
    Boone
    Boone, NC
    Airbags deployed
    Sammiches, among many other things. Hard to hike with
  19. Mar 20, 2015 at 11:02 AM
    #99
    theJCKRBBT
    theJCKRBBT Well-Known Member
    Paul
    Milwaukee
    2018 DCSB TRD OR, Blazing Blue Pearl
    Boss 2.0 + AAL Lift, NFAB Predator Steps, BFG 265/75 r16 KO2
    I've used it for a air-compressor, and to power a stereo at tailgate parties. It's not the most useful or best located outlet, but it's an outlet on a truck. I'd rather have it and not need it...
  20. Mar 20, 2015 at 11:44 AM
    #100
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    I need to use it more often. Tried charging my iPhone on it a couple months ago and it wasn't working?.... Turned on truck, pressed button, nothing...
