does anyone else's 4x4 fight against tight turns?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grangicon, Aug 25, 2015.
  1. Aug 25, 2015 at 2:20 AM
    grangicon
    grangicon [OP] Well-Known Member
    Stephen
    Lubbock TX
    '18 TRD Sport
    Camper top
    My '08 is the first 4x4 I've ever owned, so I didn't think much of it when I first noticed that it wasn't easy to make tight turns in 4 hi. Then I drove a newer tundra in 4x4, and the fighting and jerking of the steering wheel that I'm used to was completely absent. Took it to dealer and asked. The mechanic (service technician) drove it around the parking lot and was kinda surprised by how rough the turns are, but since there's no error light they ultimately said there's no problem.
    Is my truck behaving normally? Does everyone's 4x4 jerk and fight on tight turns?
  2. Aug 25, 2015 at 2:38 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    yes they do.. not suppose to use 4-wheel drive on dry pavement while turning wheel sharply
    Flowin, scottalot and HIYota like this.
  3. Aug 25, 2015 at 2:42 AM
    grangicon
    Stephen
    Lubbock TX
    '18 TRD Sport
    Camper top
    thanks.
    I first noticed this while climbing out of my driveway in several feet of snow this past winter. I haven't been gifted any further adverse conditions to test it in since
  4. Aug 25, 2015 at 2:55 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yes, and on my bro's 06 Tundra 4X4 as well - 4hi or 4lo. This is normal in a 4X4 system. In 4X4 system, the transfer case splits power evenly between front and real differentials. Both drive shafts to the diffs want to turn at the same speed. The more sharply you turn the more the inside tire wants to go slower, and slow down the front drive shaft along with it. This is why in a 4X4 system, you only want to drive off the pavement - so that the slower moving tires slip on the sand/dirt etc... If one insists on driving 4X4 engaged on pavement, they will greatly accelerate wear and tear on the CV an U joints. Not sure why the Tundra was smooth; maybe it has limited slip in front diff, not a common thing to see.
  5. Aug 25, 2015 at 3:34 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Please stop making turns (tight or otherwise) on dry pavement while in 4hi or 4lo. It is advised to exercise your 4x4 in 4hi and 4lo in your owners manual, and by all means please do... But you are going to snap a half shaft or worse if you keep forcing it through turns on pavement.
  6. Aug 25, 2015 at 6:28 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the only thing you should do 4x4 tight turns on pavement with are AWD systems
    AWD has a center differential
    so front and rear can go different speeds and not bind
    in old school 4wd, which is called part time 4wd, which is what almost all pickups have,
    it will bind up when turning on pavement...so only run it on loose surfaces
    where you need it, and if it wants to bind it can break loose and reduce stress on the driveline
    it won't hurt anything once in a while, but you should get used to switching to 2wd as soon as you know conditions are no longer slippery and don't require 4wd
  7. Aug 25, 2015 at 6:41 AM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    The jerking is the driveline binding because all four wheels are engaged and moving at different speeds while turning. Normal, but not a good thing to do if at all avoidable.
    Also, I would steer clear of shops with mechanics like this...
    YOTA LOVER likes this.
  8. Aug 25, 2015 at 6:57 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    That binding is your transfer case saying a big "FUCK YOU!". As others have stated...don't do that unless you have spare vehicles and disposable income.
  9. Aug 25, 2015 at 7:00 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Wait.........the "mechanic" didn't know you shouldn't be doing that in four wheel drive????????????
    YOTA LOVER, scottalot and Arailt like this.
  10. Aug 25, 2015 at 7:16 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Billable hours and job security.........he knew, just didn't care.
    everymanalion and scottalot like this.
  11. Aug 25, 2015 at 7:25 AM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    On the bright side, you can go back to the stealership and teach them? :notsure:
  12. Aug 25, 2015 at 7:28 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  13. Aug 25, 2015 at 7:30 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    In OP defense it does sound like maybe his is binding to fast? then again I've never turned in 4wheel on dry pavement so I wouldn't know
  14. Aug 25, 2015 at 7:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    I made the mistake (once) of pulling out of a swamp on to a hard road in a downpour lightning storm, and not getting out to unlock the front hubs (back in pre gizmo days).
    At about 60 mph the front diff let go, locked up and almost lifted the rear of the IH TravelAll off the ground. Again. Again. Again...... until every tooth was stripped off the ring gear, and it rolled nice and free. Would have qualified as an E ticket ride in those days, for those old enough to know what that means...........
    Boy was I glad it was a company truck :oops:
    everymanalion likes this.
  15. Aug 25, 2015 at 7:47 AM
    YOTA LOVER
    NH
    There's a video floating around on youtube that illustrates exactly how the wheels spin while in 4wd. "Oscillatory" is the only word I can use to describe how the force is delivered out to the wheels when turning. Youtube is blocked for me at work, but if anyone can dig it up and post it I bet a few folks would better understand that the application of torque to the wheels is not linear.
  16. Aug 25, 2015 at 7:48 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    This alone is amazing.
  17. Aug 25, 2015 at 9:14 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I've never had my Tacoma bind on "slick surfaces" I haven't tried it on dry pavement, because that's not really a good idea...The only time it's been in 4x4 on semi dry surfaces is when I load fire wood at the camp and I have to back up a hill and turn in the middle of it. I can't get up there without being in 4x4. I never noticed it binding when I'm going around the turn.
    Although I will say, some trucks I have driven are more "sensitive" to binding or its more "noticeable"
  18. Aug 25, 2015 at 9:41 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Check out the links in @OffroadToy signature. They explain a lot.
  19. Aug 25, 2015 at 10:52 AM
    tgear.shead
    tgear.shead Well-Known Member
    Eh, most AWD's these days *do not* have a center differential. Most AWD's are actually FWD's with a hydraulically actuated clutch that binds the rear axle after it detects a slip exceeding some predetermined threshold.
    Noteworthy *genuine* AWD systems;
    Audi Quattro,
    *SOME* Subaru -- Viscous and DCCD -- their others are NOT center differential,
    Some others.
  20. Aug 25, 2015 at 11:01 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    yeah awd can be different than full time 4wd
    I am basing this off my 1999 4runner limited which has pt 4wd and full time 4wd because it has a center differential that is deactivated when you go to part time 4wd
    so I should have said full time 4wd has a center diff. can leave it in full time all the time
