Does anyone elses truck ride like a donkey?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RDAY, Feb 10, 2011.
  1. Feb 10, 2011 at 6:59 AM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    I have put up with this for some time now and im getting sick of it? How good do the tacomas ride normally with a lift? real decent or really really stiff?
    This is what I have done I have had the rear tsb done, billy 5100s all the way around and ome 885 coils with nitto terra grappler tires. 285/70/17
    What could be making my truck ride so bad.
    I replaced the rear shocks a few months back and had no diffrence in ride.
    When i hit a bump it almost makes me loose control of the truck cause it throws it all over the place.
    Thanks for any help guys
    CharlesCity likes this.
  2. Feb 10, 2011 at 7:05 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    05 Taco 4x4 SR5 TRD AC
    I have never ridden a donkey.
  3. Feb 10, 2011 at 7:06 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Stock UCA's? You may not have enough caster for those 33's
  4. Feb 10, 2011 at 7:08 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Its that rear leaf set thats killing you. The stock rear leaf's suck, and than when they throw that additional leaf on there it sucks even worse. The billies make the front ride much better but when you go over the road the front makes smooth contact and the rear makes stiff contact so it feel like the amount of suspension feedback you are getting never changed, even though its the rear leafs making it feel that way. I went with the OME Dakar leaf pack from toytec, not it rides smooth all the way through
  5. Feb 10, 2011 at 7:09 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    He said rides shitty, caster being off would make it drive shitty.
  6. Feb 10, 2011 at 7:11 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    My money is on the fact that your PSI is way to high in the tires. Go 32 in front, 34 in back..or your roads suck like they do up here when the ground freezes and everything heeves and rides like shit...so its not your truck is everyone feeling the jarring of the road bumps.
  7. Feb 10, 2011 at 7:12 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    ive got the nittos and mine feels the same way it beats me to death:mad:
  8. Feb 10, 2011 at 7:15 AM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I think a big part of it may be the fact that the back of the truck is so light. Mine rides like a Cadillac, but I've got a shell. I've got just the stock Bilsteins. Try throwing a dirtbike in the back and see if it smooths out.
    RZ Rob
  9. Feb 10, 2011 at 7:17 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    thats part of it im sure
  10. Feb 10, 2011 at 7:19 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I had NTGs before the Duratracs and had no issues with them seeming to be made of cement.
  11. Feb 10, 2011 at 7:20 AM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    by no means is my truck a Cadillac, but it sure aint no donkey! :p
    I think it rides just fine, but the truck I drive at work bounces like a trampoline so how would I know..00426547_02ad36885c883db891cfb68ba4040493da3f8b55.jpg
  12. Feb 10, 2011 at 7:20 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Unless you're loaded, you should do the opposite. The majority of the weight is over the front, the back ends of the truck are very light. You should be running more pressure in the front tires vs the back unless you've got some additional weight in the bed. The stock leafs and hard tires would make the situation worse.
  13. Feb 10, 2011 at 7:24 AM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    1794 4WD FUNDRA/01TACO DCOR/05TACO DCOR/97 LX450/91 4R 4WD
    Ballin on a Budget
    Quick Question. I got 285 70 17 bfg allterrains. What should the psi be on those? Every place I go tells me different. Mainly for highway driving.
  14. Feb 10, 2011 at 9:03 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    Alrite I forgot to mention that i did get the add a leaf from toytec to lift the back up but it wasnt the dakar.
    As far as ucas i went with the light racing.
    And tires i have set on 32 all around i just checked it.
    Do u guys think its just the tires that ride rough?
  15. Feb 10, 2011 at 9:58 AM
    Pugga
    Massachusetts
    F-150 Mod
    No, but tires are the easiest thing to adjust. If your tires are rock hard, they won't help the suspension absorb any of the bumps in the road.
  16. Feb 10, 2011 at 12:53 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    my tires arent to solid tho are they?
  17. Feb 10, 2011 at 12:58 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    those Nittos are 10 ply which is way to heavy for our little Tacoma's. Get something 6 or 8 ply and you will be g2g.
  18. Feb 10, 2011 at 1:00 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Maybe you're not used to driving a truck?
  19. Feb 10, 2011 at 1:00 PM
    Pugga
    Massachusetts
    F-150 Mod
    I would say probably not. I'm at 32 psi myself but I've got 265/65R17. You could always do the chaulk test to see how your tires are doing with the pressure you're running. The chaulk test is simply drawing a chaulk line across the tire, driving for a short distance and then examining the line. If it's wore in the center of the tread and untouched on the outside of the tread, you've got too much pressure in your tires. The opposite if the line is only worn at the outside edges of the tread. The line should wear off nice and even. There's no magical tire pressure since so many of us run different size tires, encounter different road conditions and have different brands and load ranges.
  20. Feb 10, 2011 at 1:10 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    cant do the chaulk test till spring lol and ive had this truck since 2008.
    And my father has a tundra that rides alot better thats why i was just wondering.
    My truck didnt seem to always ride this bad just within the last 8 months.
    Maybe it is my leaf springs but i would hate to buy just buy and try stuff when i dont know wut it is.
