Does anyone feel like a woman with IFS???
Discussion in '4 Cylinder' started by Bachenstien, Nov 25, 2009.
  1. Nov 25, 2009 at 11:25 AM
    Bachenstien
    Bachenstien [OP] Well-Known Member
    Andy
    Portland area, oregon
    Tacoma SR5
    3" Fabtech coil overs/rear block, Front and rear diff locked.
    What are the advantages of crappy IFS?
  2. Nov 25, 2009 at 11:28 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    With IFS, you get a better ride, ability to go over more types of terrain at greater speeds.
    Remember the H1 has independent suspension. As does the LM002 and just about every all terrain vehicle.
  3. Nov 25, 2009 at 11:32 AM
    Bachenstien
    Andy
    Tacoma SR5
    yeah it has IFS front and rear.
  4. Nov 25, 2009 at 11:33 AM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    what? :confused:
  5. Nov 25, 2009 at 11:33 AM
    rutherk1
    09 Silver TRD 4door
    I could drive around in a pink volkswagen beetle with rainbows and unicorns on it and I would still not feel like a woman.
    Dont let the design of your front suspension determine your sexual security
  6. Nov 25, 2009 at 11:37 AM
    Bachenstien
    Andy
    Tacoma SR5
    lol i know. i was joking.
  7. Nov 25, 2009 at 11:41 AM
    83cj
    83cj Well-Known Member
    Gulf Shores,AL
    Tacoma when I get the cash currently cj7
    but ifs can't take a beating like solid axle, tire size is limited before this happens[​IMG]
  8. Nov 25, 2009 at 11:43 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    hahaha. Do you?
  9. Nov 25, 2009 at 11:43 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It takes a different type of beating. Trophy trucks run IFS with 39's at 120mph+ with no issues.
  10. Nov 25, 2009 at 11:45 AM
    rutherk1
    09 Silver TRD 4door
    It's all in how you build it. GM has weak tie rods. Always have. Too much truck, too big of a tire, weak OEM tie rods = breakage.
    Put 38s on a stock dana 30 and start going over big rocks and you will see breakage.
  11. Nov 25, 2009 at 11:45 AM
    Jason'sLawnCare
    don't they also use solid out back though? I don't understand why, to circumvent the use of cv's?
  12. Nov 25, 2009 at 11:49 AM
    83cj
    Gulf Shores,AL
    true but there are better axles than a dana 30
  13. Nov 25, 2009 at 11:50 AM
    rutherk1
    09 Silver TRD 4door
    Correct. Their are better IFS than a stock GM setup.
  14. Nov 25, 2009 at 11:53 AM
    Bachenstien
    Andy
    Tacoma SR5
    I heard bad stuff about a dana 30. I have heard really good things about stock toyo rear axels
  15. Nov 25, 2009 at 11:54 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    In my opinion it's no contest. Solid front axles (SFS) are tough as nails and have tons of articulation. Also, lifting the vehicle to insane heights (over 3-4 inches) is easy and cost effective. Any serious rock crawler chooses solid axles.
    However if you are a normal Joe who uses their Tacoma for everything from being a daily driver to some fun weekend off-roading, IFS gives a smoother ride with less unsprung mass over generally smooth terrain. IFS lets you drive really fast with a lot of control, and IFS handles better on the pavement while you can still tackle some rough terrain.
    So, unless you want to trailer your rig and cart it around to just do rock crawling IFS will be a far better system overall.
  16. Nov 25, 2009 at 11:59 AM
    Bachenstien
    Andy
    Tacoma SR5
    Makes perfect sense. Thank you
  17. Nov 25, 2009 at 12:01 PM
    83cj
    Gulf Shores,AL
    It depends what your doing with them, I have dana 30 on my jeep with upgraded axle shafts and 37's it works fine but if you start bouncing any tire off some rocks it will break somewhere in the drive train.
  18. Nov 25, 2009 at 12:04 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ifs vs solid axle again...
    Go get this magazine, and read the ifs vs solid axle article...
  19. Nov 25, 2009 at 12:06 PM
    Bachenstien
    Andy
    Tacoma SR5
    I have put my toyo through some abuse and nothing has broken in the front end. Its really good.
  20. Nov 25, 2009 at 12:10 PM
    mjp2
    NJ
    Generally speaking the front suspension takes more abuse than the rear, and the passenger side takes more abuse than the driver's side. The rear doesn't need to be quite as supple as it's just following the front over obstacles, so a solid axle will do.
    Also, most desert rigs are 2wd and a solid axle tends to be more reliable than CV shafts on IRS. You can push crazy power through the axle without worrying about CV angles and such.
    From what I can tell, the main difference between trophy trucks and class 1 buggies is the rear suspension. Buggies use independent rear suspensions while the TTs run solid axles.
    Nicely done. :thumbsup:
