Does anyone have a wiring diagram for the rear tail lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by paradox4286, Aug 17, 2017.
  1. Aug 17, 2017 at 8:50 AM
    paradox4286
    paradox4286 [OP] Well-Known Member
    San Antonio, TX
    17 TRDOR DCSB P/T JBL
    I swapped my cap from my previous 16, which was professionally wired, to my new truck. My cap only has a positive an a negative, so that should be all I need. I have done a ton of searching, but I can't find anything on the 3rd gen, and from what I see on the wiring, it is different than the 2nd gen.
    Any help appreciated!
  2. Aug 17, 2017 at 8:52 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  3. Aug 17, 2017 at 9:23 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Assuming you did the removal on the 16', where did you unplug the wires from? Nothing has changed in the 17's so put it right back where it was. I am not sure if they tapped off tail lights, trailer harness, or 3rd brake. That will give us a better idea of the correct wire colors you are looking for.
  4. Aug 17, 2017 at 9:26 AM
    paradox4286
    San Antonio, TX
    I did not remove the wiring from the tail light portion of the other truck. I just bought a new matching waterproof connector.
    Definitely my fault for not peeking where it was tapped on the truck before trading. It was definitely tapped into the drivers side tail light and not the trailer wiring harness
  5. Aug 17, 2017 at 9:29 AM
    MESO
    State of Jefferson
    Pop a tail light out. You will be dealing with the Middle connector of the tail light.(triangle in shape)
    Peel back the black loom to expose the wires.
    Tap the wires accordingly:
    Negative from cap light ---->goes to White/black stripe
    Positive from cap light---->goes to blue
    dingokevin, MoneyMan55, C41n and 4 others like this.
  6. Aug 17, 2017 at 9:34 AM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
  7. Aug 17, 2017 at 9:36 AM
    paradox4286
    San Antonio, TX
    Thanks! I'll report back once I'm done
  8. Aug 17, 2017 at 9:41 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    May want to pop the plastic latch over and put a bit of dielectric/ silicone grease (metal contact portions) in there if you're near coastal areas or in mud and water often. I've seen exposed taps like that corrode joints at the point of entry into the jacketing.
    MoneyMan55 likes this.
  9. Aug 17, 2017 at 9:44 AM
    c4lvinnn
    It's actually not my picture. It was the PO's when he took off the shell I bought. However, mine does look similar since we used taps. I was going to redo it with a pigtail and a male/female quick disconnect.
    GPsevinSixx[QUOTED] likes this.
  10. Aug 17, 2017 at 9:49 AM
    MESO
    State of Jefferson
    Hey I guessed right. After 20+ pairs of lights I better know :goingcrazy:
  11. Aug 17, 2017 at 9:56 AM
    paradox4286
    San Antonio, TX
    Impromptu golf club.
    Blue for positive and white with black stripe for negative.
    @mesojdm i should've just PMd you in the first place but hopefully this thread will help future persons digging like I was.
    Thanks for everyone's help!
    I soldered it afterwards just FYI
    SilverII likes this.
  12. Jan 7, 2019 at 10:52 AM
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    Thank you to MesoJDM for his knowledge and to the OP for starting this thread. Wired up a third brake light for my KBVooDoo rack. When the RTT is up there it covers up the third brake light, now I just feel so much safer on the road with this light ;)
  13. Jan 12, 2019 at 8:37 PM
    ronin_yota
    ronin_yota Well-Known Member
    Haha yes! This helped me quickly find the right wires to tap into! Thank you all who contributed to this thread! I appreciate all the knowledge! Got the rear light working instantly on the Alucab canopy.
    nvnv likes this.
  14. Mar 20, 2019 at 4:38 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Same, helped me wire up the GFC brake light
  15. Apr 21, 2019 at 8:40 PM
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    Has anyone built/bought a harness adapter instead of tapping into factory wires?
  16. Apr 21, 2019 at 11:46 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    You can buy @mesojdm total tail and tap into that instead… that’s my plan at least
  17. Apr 22, 2019 at 1:11 AM
    COdude3
    Colorado
    I'm just looking for the wire harness. If I could find the OEM connectors online, I will just build my own harness.
    houser1995 likes this.
  18. May 23, 2019 at 8:54 PM
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    Another thanks to @MESO. Got the third brake light wired up on my Alu-Cab.
    MESO likes this.
  19. Jul 13, 2019 at 8:43 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I've purchased this .. and I have a 2nd gen 2015 so is the wiring the same as 3rd gens? I have three wires on this .. so do I tap into all three wires that attach to the bulb?Screenshot_20190713-114019.jpg
  20. Jul 13, 2019 at 8:51 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    Is it better to tap into trailer wires? Vs tail light?
