Does anyone have actual experience with tranny fluid change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crosis, Sep 4, 2019.
  1. Sep 15, 2019 at 5:28 PM
    #81
    Labbi85
    Labbi85 Well-Known Member
    Ok done now and a little update on the final result .
    Truck has about 140kM
    Previous owner never did a change of atf because his toyota dealer told him that it isn't necessary
    Truck always had hesitation to shift to first gear when coming to a quick stop
    Truck failed 5 times to shift in 4 or 5 gear and had to switch off car to reset
    Did a change now and when opened drain first time 1.5Quart came out (should be 3)
    Flushed with two gallons.
    Filled first time with 2Quarts
    Had to add in 0.5Q steps 2 additional quarts of atf
    At the end I estimate that 0.4Q came out of the check port
    Last but not least... a big thank you to BillsSR5
    Will update if the transmission works now like it should.
    BillsSR5 likes this.
  2. Sep 15, 2019 at 5:29 PM
    #82
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I watched all the vids were pretty good. I think she actually references TW for info on some things to do with Tacomas
  3. Sep 15, 2019 at 5:31 PM
    #83
    BillsSR5
    bill
    2014 SR5
    wow haha worked out in the end, im going try this with my truck in a few thousand more miles seems legit way to get more trans fluid out than just pan drains, did u use the Toyota WS or aftermarket
  4. Sep 15, 2019 at 5:35 PM
    #84
    Labbi85
    Used valvoline max life ...hot 3G at autozone for 70USD
    BillsSR5[QUOTED] likes this.
  5. Sep 15, 2019 at 5:36 PM
    #85
    BillsSR5
    bill
    2014 SR5
    im going to use Toyota t-iv I can get it by the case im getting 12 quarts
  6. Sep 15, 2019 at 5:37 PM
    #86
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I'm at 144k and I want to change the tranny fluid bad, but I have no clue if the previous owner ever did it. So kinda in the debating mindset right now.
    I bought it at 142k
  7. Sep 15, 2019 at 5:39 PM
    #87
    BillsSR5
    bill
    2014 SR5
    I would really its a transfer, the flush is where u use a cleaner in the trans this way just exchanges the fluid, mines getting done at 116k miles never been fully flushed
  8. Sep 15, 2019 at 6:09 PM
    #88
    Labbi85
    Just Made 5 mile test ride...and wow the truck is like changed.
    Shifts faster but still smoother, was not able to get the shift hesitation when breaking fast to get to a stop (tried it at least 6 times), in general the whole truck feels like it is much faster now and more responsive (drove it until now like a old granny) and on top I think scan gauge shows at least one 1mpg better mileage.
    Maybe I am just delusional because of all the work doing it and hoping for a good outcome, but I don't thinks so.
    Will keep you update after some longer normal driving
    Or maybe it is just this way because I didn't install the heavy skidplates yet:confused:
  9. Sep 15, 2019 at 6:09 PM
    #89
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Does your rig not call for WS?
  10. Sep 15, 2019 at 6:17 PM
    #90
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I changed my old fluid, then replaced it again 5,000 miles later to get rid of any gunk that the new fluid may have stirred up. Zero issues.
  11. Sep 15, 2019 at 6:18 PM
    #91
    Yotacoma08
    Yotacoma08 Cut the corner or do it over again
    Tanner
    Mississippi
    2008 Silver Tacoma Fuel rims
    Fuel rims, black brush guards, blacked out emblems, TRD cold air intake, and interior mods.
    A toyo tech said the only way THEY can do it is through flushing the system. I got that done at like 280 or 290k. It was supposed to be an every 100k thing. I paid about $300 for it. I'm sitting okay now about 30k later.
  12. Sep 15, 2019 at 6:49 PM
    #92
    BillsSR5
    bill
    2014 SR5
    no 2.7l 4 speed is T-VI or MOBIL JWS 3309 whatevers cheaper, theres other aftermarket equivilents but I don't trust using them, both WS and T-IV are made by MOBIL,the aftermarkets are reversed engineered clones although majority seem to work
  13. Sep 15, 2019 at 6:54 PM
    #93
    BillsSR5
    bill
    2014 SR5
    as long as theres no erratic shifting its all good
  14. Sep 17, 2019 at 12:44 PM
    #94
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    Had my fluid checked by the stealership at just over 100k. The tech said it looked like it could use a change so I went through with it. No problems at all.
  15. Sep 17, 2019 at 12:50 PM
    #95
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    What did they charge for that ?
  16. Sep 17, 2019 at 3:26 PM
    #96
    BillsSR5
    bill
    2014 SR5
    if you contact some of the Iffy lubes or Aamco trans places they can do it for you, and they will use your own ATF fluid, theres an Aamco near me that also stocks AMSOIL ATF if you want to use that, I had one done at a Toyota dealers was little over $100 with a sale coupon they used a BG machine
    spitdog[QUOTED] likes this.
  17. Sep 17, 2019 at 3:58 PM
    #97
    spitdog
    I was just curious what a dealer would charge. I thought they only did a pan dump, 3 qts worth.
    I didn’t think they would do the total 11 qts.
  18. Sep 17, 2019 at 4:47 PM
    #98
    BillsSR5
    bill
    2014 SR5
    u got to ask them about the flush, or they will assume pan drain
  19. Sep 18, 2019 at 10:49 AM
    #99
    wade9986
    Ross
    Stuart, Florida
    IIRC it was $200 and change
  20. Dec 6, 2019 at 3:18 PM
    #100
    Tiberius
    Tiberius Well-Known Member
    Aurora, CO
    Nautical Blue v6 SR5 4x4 Access Cab
    The only other advise I can add is buy one of those OBDII readers for your smartphone so you can do the transmission temperature easily without check mode jumper nonsense. Still not sure on correct temperature for mine but I did 110 degrees the last time for the fluid level check.
