Does anyone have an issue with auto transmission shifting from 3rd to 4th gear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtman75, Dec 31, 2011.
  1. Dec 31, 2011 at 1:20 AM
    vtman75
    vtman75 [OP] Member
    virginia
    2011 Prerunner
    Only 6k miles on the truck. Feels like it strains going from 3rd to overdrive. Thanks
  2. Dec 31, 2011 at 1:23 AM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i have 34’4**k on my ’07 that i got in may. and no i don’t had issues! about 98% ot the time it just stays in “D” tho. if it is raining hard and i’m stopped on a hill i’ll down shift to 1st and shift my way back to D. some times i have to do that on my drive way when it’s raining.
  3. Dec 31, 2011 at 1:40 AM
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    I assume you have the 2.7, if you like to drive quick the ECU might have picked up on your driving habits and adjusted the shift point to delay longer than normal. You could try resetting it - disconnect the negative battery terminal for about 10 minutes. It should shift normal immediately after resetting, but it will learn your habits during the first few trips afterwards, so take it easy for about 4-6 trips.
    Edit: be sure to check out the 4 cylinder section of TW, lots of us over there
  4. Dec 31, 2011 at 2:08 AM
    vtman75
    vtman75 [OP] Member
    virginia
    2011 Prerunner
    It is the 6 cyl engine. I actually drive the truck very carefully and am not heavy on the gas pedal. You may be right with the ECU reset. Thanks
  5. Dec 31, 2011 at 2:14 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    i have the 4.0 v6. do you shift it like a Manuel allot?
  6. Dec 31, 2011 at 2:20 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    have not had this issue on mine either I have 71000 on mine but will watch this post for answers JIK it does later
  7. Dec 31, 2011 at 2:22 AM
    johnanm
    Up
    Oh ok. I thought all the V6 autos had a 5 speed tranny?
  8. Dec 31, 2011 at 3:13 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    they do as far as i know. 5 speed auto.
  9. Dec 31, 2011 at 3:18 AM
    johnanm
    Up
    Gotcha. OP must be talking about the 4th to 5th shift then
  10. Dec 31, 2011 at 3:20 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    yeah.
