Does anyone have any tips on using touch up paint
Discussion in 'Detailing' started by Bart, Oct 8, 2008.
  1. Oct 8, 2008 at 11:48 AM
    Bart
    Bart [OP] Well-Known Member
    Franklin,NC
    08 TRD OFFROAD V6 4x4
    metra ipod
    I have a few chip's and scraches I've tried using touch up paint on my older truck's and it just look's bad anybody got any advise on how to do it correctly with out making it look obvious that it has been touched up?
  2. Oct 8, 2008 at 11:50 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what you wanna do is put a little touch up paint on, then let it dry. then, do this a few different times and let it dry good with each coat till its even with the other paint. then, once the last coat is dry, polish and wax the area. should look really good then.:)
  3. Oct 8, 2008 at 11:52 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i actually just did some touch up on my truck. i went to the dealer and got some, it comes in a pen form also so makes the touch up easier. test the paint first on a part on the inside of the door and go along the scratch with the paint pen or use the brush if its a chip. wait a day and do another layer till the paint rises above the scratch. then wait bout a week and get some scratch remover (i used quixx) and follow the directions. this will blend the old paint with the new paint together better and wont be as noticeable. im gonna put some quixx on tonight and will try to get some pics up
  4. Oct 8, 2008 at 11:57 AM
    Bart
    Franklin,NC
    metra ipod
    I will try that I guess the problem I had was to much paint at one time those brushes and pen's put alot out at once.
  5. Oct 8, 2008 at 12:01 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you're like me ..... you don't have the time or energy (or urge) to do a fully professional repair - but you want it to look decent...
    Get this stuff:
    http://www.langka.com
    I've been using it on all our vehicles and it's really cool and I really like it.
    You gotta buy touch-up paint for your vehicle - the pen/small brush version (not spray). The Langka allows you to plop the paint on, allow it to dry, and you can rub off the excess paint thus only leaving the paint in the chip. It takes a bit of practice but it's soooo much better than ploppin paint on and leaving blobs there.
    The one thing I have learned is....the metallic colors (speedway blue) are harder to make it look invisible versus a straight color. But again, it's better than having blobs of paint and/or exposed metal.
  6. May 19, 2009 at 10:02 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Tacomaman is right about this. It's difficult to get it right, but if you take your time, and layer some paint on the chip, eventually, you'll get it up to the point where it's even, or above the level of the surrounding paint. Once you get it to that point, polish with scratch-x or something along those lines to remove the excess paint, and it will blend right in. I did a bunch of chips on my Mag Gray '09 last night, and a few of them are to the point where you can't even tell. Others, not so good, so I need to go back and layer more paint on them and polish again.
  7. May 19, 2009 at 1:21 PM
    Bart
    Franklin,NC
    metra ipod
    Will do havn't go around to it yet.
