Does anyone have experience with Gasket Masters?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KrazyKen, Aug 13, 2024.
  1. Aug 13, 2024 at 4:28 PM
    KrazyKen
    KrazyKen [OP] New Member
    Ken
    2005 Tacoma TRD 4x4
    I have 2005 Tacoma TRD 6 speed with 222,000 miles and a head gasket leak confirmed by pressure test and borescope. Gasket Masters in Manteca CA will do the job for about $3,400, which is at least $1000 less than everyone else. They say that OEM gaskets are junk and they only use Fel-Pro, and they offer a 1 year unlimited mileage warranty. If I insist on a Toyota gasket they will not offer a warranty.
    I'd like to save a grand, but I'm not sure about them. Does anyone have any feedback, or have a shop to recommend in Jackson/Sonora/Stockton/Sacramento CA?
    Thanks,
    Ken
  2. Aug 13, 2024 at 6:27 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Fel-Pro gaskets are not known to be all that great. I think you'll get a consensus here that OEM gaskets are much better. I'm sure you know that 2005 and early 2006 4.0L Tacoma had head gasket issues, that Toyota fixed with an updated part. My 2007 still has the original head gaskets and just passed 530,000 miles. So their statement that "OEM gaskets are junk" could be true if you are only referring to the original ones in the model years I listed.
    I'd keep looking for someone else to do this repair for you and will use OEM stuff.
    Good luck
  3. Aug 13, 2024 at 6:49 PM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    I was kind of skimming thinking okay... guy who drinks the OEM koolaid until I got to the "just passed 530,000 miles on the original gaskets" part.
    Sir, you have my undivided attention.
    KrazyKen[OP] likes this.
  4. Aug 13, 2024 at 9:39 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    First owner?
    What kind of oil?
    What oil-change interval?
    Thanks
  5. Aug 13, 2024 at 9:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Felpro certainly dont have a great reputation in the industry.
    I used felpro on my 2001 Jeep simply because the kit was the cheapest.
    On anything worthwhile I use OEM.
    Toyota headgaskets do fail, but after many many years, and typically due to corrosive coolant.
    Your 05 was known for headgakets and made it this far.
  6. Aug 13, 2024 at 10:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Well, that kind of sucks. :rofl:
    I literally just ordered Fel-Pro valve cover gaskets for my 4.0
    Mine are “seeping”, but not enough to be wet. Just “greasy”.
    Getting ready to do spark plugs and ordered Fel-pro cover gaskets “just in case” the plug wells have oil in them.
    I guess here is hoping they don’t:fingerscrossed:
  7. Aug 13, 2024 at 10:24 PM
    Bishop84
    For valve covers its fine, but for a headgasket I want as good as I can get.
    We usually try to get Victor Reinz or Mahle for valve covers. You'll be fine either way.
    When I first started the felpros wouldnt sit nice in the valve cover and they'd fall out when you tried to install it.
    TnShooter[QUOTED] likes this.
  8. Aug 14, 2024 at 9:34 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I just used recent production Felpro for valve covers/timing cover on a 1GR-FE, they were marked 'made in Japan' and fit very well.
    eherlihy likes this.
  9. Dec 19, 2024 at 5:53 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    Sorry for dredging this thread up from the dead. I stumbled across this thread looking for confirmation on Fel-Pro MS 96641 would fit for the intake plenum. (I have found elsewhere that it will.)
    I have used Fel-Pro gaskets on the valve covers on my 2001 Toyota Avalon with a 1MZ-FE. They fit well, and have been working well for over 10 years.
    Because they worked so well on the 1MZ-FE, I have since ordered a Fel-Pro VS 50634 R gasket set for the 1GR-FE in my Tacoma. Because installing it will require removal of the plenum, I also ordered the Fel-Pro MS 96641 for that. I plan to install both next month.
