Does anyone have experience with these?
Discussion in 'Wheels & Tires' started by JackB191, Sep 1, 2014.
  1. Sep 1, 2014 at 9:53 PM
    JackB191
    JackB191 [OP] Member
    Jack
    NJ
    08 TRD Off Road AC Auto
    Black Ebay headlights, black ebay grill, tinted fogs w/ hyper yellow bulb, Black tail lights and 3rd brake light
    I was looking at Vision 372 Raptor wheels (16x8, 6x139.7mm, 0mm offset 110mm bore). After reading through countless threads here on TW, I have come to the conclusion that these should work as long as I use hub-centric rings. My question is will my stock tpms sensors will work, and if anybody on here is using these wheels? ( http://www.visionwheel.com/wheel.cfm?id=1143 )
  2. Sep 2, 2014 at 5:22 AM
    JackB191
    Jack
    NJ
    Morning bump
  3. Sep 2, 2014 at 5:29 AM
    Prim3sTacoma
    Prim3sTacoma Active Member
    Long Island
    11 4dr trd blue
    Blue balls, full stereo rewire and upgrade, Bullbar custom painted grill roof rails supercharger and trd intake and exhaust bronze rims new tires. Custom headlights with bi-xenon and projectors
    Wheels look nice def put a beef tire on them. As far as I know I put the same rim size but a -12 offset and I have the TPMS sensors in them and no problems. I also have the same tire size as the stock tires but youd never tell. Hoped that helped
  4. Sep 2, 2014 at 7:49 AM
    JackB191
    Jack
    NJ
    265 70 16 for now (tires are almost new), going to jump up to 265 75 terra graplers when I need new tires. Thanks for the info. Now I have to decide on matte black and phantom black...:cool:
  5. Sep 2, 2014 at 9:36 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I have a different model vision wheel with (if I remember correctly) similar/same fitment specs. The lug nuts have a shoulder on them that keeps them concentric - no rings on mine.
  6. Sep 2, 2014 at 2:52 PM
    JackB191
    Jack
    NJ
    No issues with vibration with out the rings?
  7. Sep 2, 2014 at 3:59 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Nope. I had some rubbing with 265/75-16s on the flaps. By removing the flaps and cutting the "bumps" off and flattening them with heat, I was able to get rid of he rubbing.
