Does anyone have these headlights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by schecter517, Jan 29, 2018.
  1. Feb 16, 2018 at 9:01 AM
    #361
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I did, was just looking for opinions. Especially about the heat thing, whether that much heat can damage a low quality lens like that (if that's the case, no need to try another one).
  2. Feb 16, 2018 at 9:31 AM
    #362
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    Just ordered a set for my '12. We'll see what happens when they arrive.
    Edit: Got mine from tacomabeast
  3. Feb 16, 2018 at 10:05 AM
    #363
    schecter517
    schecter517 [OP] MX4LYFE
    Richard
    San Diego
    2014 DCSB TRD Sport 4x4
    TRD Pro Wheels Falken WildPeak AT3W 265/70-17 Black Spyder Projector HL w/LED Bar Morimoto XB LED Fog Lights Spec-D Black Tail Lights Truxedo Deuce 2 Tonneau Cover Tinted Windows Bed Mat Debadged Blue LED Interior Lights LED Switchback Turn Signals Led Reverse Lights and License Plate Lights DDM Ultra HID 55W 55K Kit
    I haven't had any issues with heat. I'll keep an eye on the lens as time passes but I think they should be ok.
    ChadsPride likes this.
  4. Feb 16, 2018 at 10:13 AM
    #364
    schecter517
    Richard
    San Diego
    This is not related to this thread but I thought I would ask here first before searching or posting something new. I have LED license plate lights and they keep flickering. Anyone know why? the bulbs are maybe a month and a half old.
  5. Feb 16, 2018 at 10:18 AM
    #365
    TacoJoshC
    TacoJoshC Member
    Josh
    Surprise, AZ
    2013 Tacoma TRD off-road DCSB
    Bilstein 5160/6112 3" lift with Headstrong AAL
    Just got a set of these for my '11 DCSB from TacomaBeast, and they're absolutely not plug 'n play. the LED DRL's have a cheap little connection that I'll have to splice into the factory harness. Anyone else have issues with this, or is it just the 05-11 version?
  6. Feb 16, 2018 at 10:24 AM
    #366
    Boyk1182
    Northern Colorado
    The 2014 just had 3 plugs, plugged them in and they worked.
  7. Feb 16, 2018 at 10:35 AM
    #367
    schecter517
    Richard
    San Diego
    Are you sure?
    My buddy has an 11 and got the same ones from TacomaBeast and they were plug and play. Super easy. We did the install the other night. Took all of 20 min.
  8. Feb 16, 2018 at 10:36 AM
    #368
    ChadsPride
    Sponsored by TacomaWorld.com
    Did your truck come with factory DTRL? ​
  9. Feb 16, 2018 at 10:48 AM
    #369
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    So need these for my 2015, was going to do bhlm but man these look way better.
    schecter517[OP] and ChadsPride like this.
  10. Feb 16, 2018 at 10:49 AM
    #370
    schecter517
    Richard
    San Diego
    I love mine! they look and perform great!
  11. Feb 16, 2018 at 11:06 AM
    #371
    TacoJoshC
    TacoJoshC Member
    Josh
    Surprise, AZ
    Yes, truck does have factory DTRL, the double filament bulb that is also the turn signal. My TacomaBeast headlights came with one connection for the low/high beams, and one small red connection for the LED lightbar, which plugs into nowhere on the factory harness.
    ChadsPride[QUOTED] likes this.
  12. Feb 16, 2018 at 11:10 AM
    #372
    TacoJoshC
    TacoJoshC Member
    Josh
    Surprise, AZ
    @schecter517 does your buddy have photos of the install by chance? Curious to see if mine are missing anything...
  13. Feb 16, 2018 at 11:17 AM
    #373
    schecter517
    Richard
    San Diego
    unfortunately he does not. I know there are 2 plugs, one for head lights and one for the turn signal. Then there should be a little wire taped to the side with a red plug, if I remember correctly, and the plug goes plugged in where the side marker goes. You need to remove the bulb from that pig tail and plug that connector in and then attach that pig tail in the hole. Kinda confusing but there is an LED chip on the side of the light so the stock bulb is not needed for the side marker. Hope that helps.
    SliMbo4.0 and nateshrum like this.
  14. Feb 16, 2018 at 12:03 PM
    #374
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I always thought of getting a set of these then transferring my OEM lenses over to the aftermarket light and resealing. Both negating moisture buildup since a lot of people end up having poorly sealed eBay lights, and also then utilizing a higher quality lens. Or doing somewhat the opposite...buying a set of these and tranferring the guts to my OEM light. Bu that sort of negates buying them in the first place lol, and then you are left without a spare set of OEM lights should something go wrong.
  15. Feb 16, 2018 at 12:08 PM
    #375
    Boyk1182
    Northern Colorado
    I have thought about that too, I don't know that the OEM lenses would be a perfect fit on these housings? If I knew that they would, I would strongly consider doing it. Even if I can live with these small scratches/cracks, I don't think these will hold up over time to the sun (at least not as well as the factory lenses).
  16. Feb 16, 2018 at 12:21 PM
    #376
    nateshrum
    nateshrum Well-Known Member
    Nate
    Boise, ID
    2005 Tacoma
    THIS.
  17. Feb 16, 2018 at 1:34 PM
    #377
    schecter517
    Richard
    San Diego
    So I found these on Amazon. Just got delivered. They were the only plug and play LED's I could find. Since no modification was needed to install these my warranty is still solid. Obviously I will post some shots later tonight for light output. All the reviews on Amazon were positive so these should be awesome. And if they are not then they were only $25 so not a total loss. Anyway I will keep all of you up to date as time goes on like usual.
    https://www.amazon.com/gp/product/B01IMVQWDM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  18. Feb 16, 2018 at 1:57 PM
    #378
    griffin407c
    Upstate NY
    Try to get a nice shot of the stock bulb vs the LED side by side.
  19. Feb 16, 2018 at 1:58 PM
    #379
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Yea, maybe install one and take some photos
  20. Feb 16, 2018 at 2:03 PM
    #380
    Boyk1182
    Northern Colorado
    Any idea on the hour rating on those?
