Does anyone have these headlights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by schecter517, Jan 29, 2018.
  1. Apr 18, 2018 at 9:52 AM
    #761
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Looks great! Is the white light around the projectors on the drl circuit or on with running lights?
  2. Apr 18, 2018 at 12:28 PM
    #762
    maxtherat
    Inland Northwest
    Is your truck equipped with factory drl feature? If so what part of the headlight lights up without turning on the headlight switch at all- just the truck off and parking brake released?
  3. Apr 18, 2018 at 7:15 PM
    #763
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    So I have these lights and really love them. I have been driving around with my marker lights on during the day so they can be seen (I used to always use the DRL).
    The problem with this is the radio is hard to see during the day, and impossible if it's sunny and I'm wearing sunglasses....so I decided to come up with a easy (I thought) solution to have the neon tubes as DRL.
    I saw that the DRL light was duel filament. 1 for DRL, 1 for the turn Signal. So I used my electric tester to figure out which of the 3 wires was the DRL wire and jumped that wire to the led tube wire which I had cut so it was getting no power.
    This worked for DRL and marker light mode! The negative was it also flashed with the signal....when I turned on the headlights the led tube did not illuminate. This is because the DRL uses 1 filament bit when you click all the way up to headlights the yellow light switches to the other filament for some reason. The led tube flashes with the signal in headlight mode.
    I decided if I couldn't get the tubes to work the way I wanted, I'd go back to stock so that's how it sits now.
    The only way I can think of now is to run a separate power wire to the tubes, with a relay trigger, but I don't know what to have as the trigger since the yellow light setup is so wonky....i don't want to add all these wires under my hood personally so that's out for me.
  4. Apr 19, 2018 at 2:49 AM
    #764
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    There is a setting on the radio to turn off auto-dim. I did that and it never dims now.
    SPIN Offroad likes this.
  5. Apr 19, 2018 at 8:07 AM
    #765
    SP Taco Truck
    SP Taco Truck Member
    2015 MGM Tacoma
    So I've been trying to follow along with this thread and I've seen Tacoma Beast, Pro Tuning Lab, and eBay headlights all mentioned. Are they all the same, is there a recommendation on which ones are the highest quality?
  6. Apr 19, 2018 at 8:08 AM
    #766
    Boyk1182
    Northern Colorado
    All the same, down to the packaging.
    ChadsPride likes this.
  7. Apr 19, 2018 at 8:10 AM
    #767
    ChadsPride
    Sponsored by TacomaWorld.com
    Anybody trying to sell their set?
  8. Apr 19, 2018 at 8:14 AM
    #768
    Boyk1182
    Northern Colorado
    I will be very soon, waiting for retros to be done.
    ChadsPride[QUOTED] likes this.
  9. Apr 19, 2018 at 8:16 AM
    #769
    ChadsPride
    Word! Shoot me a PM whenever you're ready.
    Who's building your new set?
    Boyk1182[QUOTED] likes this.
  10. Apr 19, 2018 at 8:19 AM
    #770
    Boyk1182
    Northern Colorado
    Kustom 54, it is taking a while because it’s with the FXRs. Will do!
  11. Apr 19, 2018 at 8:19 AM
    #771
    ChadsPride
    Bad ass!!! :headbang:
  12. Apr 19, 2018 at 11:44 AM
    #772
    SP Taco Truck
    2015 MGM Tacoma
    Thank you! Do you recommend adding some additional sealant or do they already look water tight?
  13. Apr 19, 2018 at 11:55 AM
    #773
    Boyk1182
    Northern Colorado
    I didn't and they have been fine, but it has only been a few months. I think they look solid though and pretty well sealed.
  14. Apr 19, 2018 at 5:35 PM
    #774
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Who'd be interested in a clean solution to enable DRL only on the LED strip?
  15. Apr 20, 2018 at 7:08 AM
    #775
    schecter517
    schecter517 [OP] MX4LYFE
    Richard
    San Diego
    2014 DCSB TRD Sport 4x4
    TRD Pro Wheels Falken WildPeak AT3W 265/70-17 Black Spyder Projector HL w/LED Bar Morimoto XB LED Fog Lights Spec-D Black Tail Lights Truxedo Deuce 2 Tonneau Cover Tinted Windows Bed Mat Debadged Blue LED Interior Lights LED Switchback Turn Signals Led Reverse Lights and License Plate Lights DDM Ultra HID 55W 55K Kit
    You got something?
  16. Apr 20, 2018 at 12:20 PM
    #776
    HawkShot99
    Kingston, NY
    Always interested...i did go and put a bunch of effort into it already.
  17. Apr 22, 2018 at 12:33 PM
    #777
    TexanTacoma
    TexanTacoma Well-Known Member
    Peyton
    2010 DCLB TRD Sport 4x4
    They are DRL circuit, and thanks!
  18. Apr 22, 2018 at 2:35 PM
    #778
    maxtherat
    Inland Northwest
    on my 09 my drls are also my turn signal. Do these flash when you turn signals or hazards are on?
  19. Apr 22, 2018 at 3:45 PM
    #779
    HawkShot99
    Kingston, NY
    The DRL/turn signal is a duel filament bulb. The different filaments achieve different results.
  20. Apr 22, 2018 at 3:59 PM
    #780
    maxtherat
    Inland Northwest
    Thank you. Yes understand how the dual filament works. On my truck when my drls are illuminated and I turn on my turn signal/ hazards the lit bulb cancels out as it flashes. This is different than a tail light (for example) with a 3157 bulb that can have a lit filament (tail lights) and then the other filament either flashes or stays lit when brakes are applied.
