Does anyone have Wet Okole seat heaters?
Discussion in 'Product Reviews' started by BBiggs, Dec 27, 2010.
  1. Dec 27, 2010 at 4:12 PM
    BBiggs
    BBiggs [OP] Well-Known Member
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    I'm ordering a full Wet Okole set on Friday, and I want to get heat in the 2 front seats.
    I'm wondering if anyone has done this. How good are the heaters? And did you wire it up properly rather than just plugging in to the power outlets? I would like to order some switches and mount them properly for a stock look, does anyone know where such a switch could be found?
  2. Dec 28, 2010 at 4:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Dec 28, 2010 at 7:57 AM
    gringo77
    gringo77 Member
    Braselton Ga
    2011 DC LB TRD Sport
    good write up!
  4. Dec 28, 2010 at 8:07 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I have the heaters in my Wet Okoles. They work quite well, just one setting though, so they get pretty hot after a bit. I have not gotten around to hardwiring them in yet. They draw 10amps (per WO customer service) so any switch rated that high or higher will work. I will be rewiring them as soon as it gets a bit warmer and will try to write something up about it.
  5. Nov 21, 2011 at 2:58 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    If you haven't hard wired them in, how do they get their power?
  6. Nov 21, 2011 at 3:06 PM
    JDMcQ
    The plug in to the power ports on the dash.
  7. Apr 23, 2012 at 7:44 PM
    312necro213
    312necro213 New Member
    Bryan
    Davis
    12 Prerunner Dynod @ 421hp
    Oh, wouldn't you like to know.
    You could always wire in a relay, then you could use any amperage switch to control the circuit. Opening up a lot more oem switch applications. Also for this setup you don't need a 2 pin or even a specific amount of pins. All you need is a non-momentary (meaning push in and stays in until pushed again) switch that opens or closes the circuit. The relay will be the only amperage draw in the circuit meaning the amperage should be well below 1 amp with proper wiring. You could also put a resistor in-line with the relay & seat covers to reduce heat, putting a variable resistor with a knob here would make the seat heater adjustable amperage and thus adjustable heat output. Hope this helps!
    Bryan
