Does anyone know if a 2nd gen radiator and ac compressor will fit like the oem on my '16?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016 Tacoma SR5, Mar 18, 2019.
  1. Mar 18, 2019 at 8:51 PM
    2016 Tacoma SR5
    2016 Tacoma SR5 [OP] Member
    SoCal
    2016 Tacoma SR5 Super White Access Cab 4 Cyl.
    Does anyone know if a 2nd gen radiator and ac compressor will fit my '16, like the air filters that have different part number but work on the 3th gens. Thanks.
    tcjacado likes this.
  2. Mar 18, 2019 at 9:02 PM
    tcjacado
    tcjacado Well-Known Member
    That's a good question. Unfortunately I do not know the answer to it though. I know a lot of parts can transfer over. I have had a similar question about part cross overs on a rack and pinion. All 4 models look the same in pics 2wd/4wd 2nd gen and 2wd/4wd 3rd gen. No one has been able to confirm for sure or been able to explain the differences in 2wd vs 4wd or 2nd gen vs 3rd gen.
    This probably doesn't help much. But probably going to need to pull it an see if mounting, inlet and outlet are in the same locations. They should be close as not much has really changed.
  3. Mar 19, 2019 at 8:26 AM
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    While many 2nd and 3rd gen parts are interchangeable they will normally have the same part numbers such as the brake rotors, calipers, hubs etc. The radiator and ac compressors have different part numbers and are substantially different in price. For example, the 3rd gen ac compressors are 3 times more expensive than the 2nd gen compressors. You may do a search for Toyota oem discount parts and there are many dealers that will come up that you put your truck information in and find any part numbers you want. You can also put in a 2nd truck and compare the part numbers. If you want to find used parts then go to car-part.com and get a great price. Most body shops get their parts this way. Hope this helps.
  4. Mar 19, 2019 at 8:30 AM
    tcjacado
    I have good info that says 2nd gen 4wd racks are the same as 4wd 3rd gen racks even though they are different part numbers.
    skyking3[QUOTED] likes this.
  5. Mar 31, 2019 at 3:52 PM
    2016 Tacoma SR5
    SoCal
    I bought a denso one from ebay part number
    221-3139 for 05-16 models 90 shipped it was a little bit thin but it worked as for the compressor i just know that 16s and up use the new r1234yf but it turned out that i just had an ac leak compressor is good thanks.
  6. Mar 31, 2019 at 3:56 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    why would you want to put a 2nd gen radiator or compressor in a 3rd gen truck the whole thought and concept is dumb
    Garyji and na8rboy like this.
  7. Mar 31, 2019 at 4:01 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think they might be hoping it would basically be the same part for less money.
  8. Mar 31, 2019 at 4:04 PM
    2016 Tacoma SR5
    SoCal
    Correct plus gunny1005 told me that theyre the same. :confused:
    shakerhood[QUOTED] likes this.
  9. Mar 31, 2019 at 4:13 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Totally different engine and heat dissipation requirements. Do what you want tho. I would spend the money and get the right part. Geez you spend $35K on the vehicle. Don't skimp.
    BillsSR5 and rev25sharp like this.
  10. Apr 1, 2019 at 6:51 AM
    BillsSR5
    bill
    2014 SR5
    If I needed to get a part for my truck I would use the correct year, model,engine, trans. and VIN # because you would be taking the risk of completely dismantling the truck and finding out discrepencies too late. plus his trucks only a 2016 how could his radiator and AC compressor be on the way out this soono_Oplus if u go to the CAMELBACK site it shows different part numbers and prices for the radiator for both auto and manual trans on a 2.7l engine between 2016 and a 2013 model truck https://parts.camelbacktoyota.com/p...SYSTEM&group=COOLING SYSTEM&subgroup=RADIATOR https://parts.camelbacktoyota.com/p...SYSTEM&group=COOLING SYSTEM&subgroup=RADIATOR
  11. Apr 1, 2019 at 6:51 AM
    BillsSR5
    bill
    2014 SR5
    this:thumbsup:
    hiPSI[QUOTED] likes this.
  12. Apr 1, 2019 at 7:36 AM
    2016 Tacoma SR5
    SoCal
    Because the truck gets driven day and night around farms with a lot of idling and also had to get 2 batteries replaced under warranty, truck has 40k miles. Ac compressor is good it just leaked out all of the freon.
  13. Apr 1, 2019 at 7:47 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Seems like strange parts to be replaced on a 4 year old truck. Did you wreck it??
    G.
    BillsSR5 likes this.
  14. Apr 1, 2019 at 12:43 PM
    BillsSR5
    bill
    2014 SR5
    what the hell are you growing on your farm?:rasta:
  15. Apr 1, 2019 at 1:32 PM
    2016 Tacoma SR5
    SoCal
    I bought it new and no wrecks.
  16. Apr 1, 2019 at 1:34 PM
    2016 Tacoma SR5
    SoCal
    :gossip:
