Does anyone know if the 2017 Tacoma has a problem with the rear main seal
Discussion in 'New Members' started by Bbmaddox89, Nov 12, 2022.
  1. Nov 12, 2022 at 12:54 PM
    Bbmaddox89
    Bbmaddox89 [OP] Active Member
    2017 Tacoma off-road
    2017 Toyota Tacoma rear main seal leak does anyone know what it looks like I have a leak I suspect of being the main seal I just bought the truck 3 months ago it's a shame I love the thing
    Black DOG Lila likes this.
  2. Nov 12, 2022 at 12:56 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    It’s not unheard of.
    Don’t know why you made two threads for it though.
    Bishop84 and Black DOG Lila like this.
  3. Nov 12, 2022 at 12:58 PM
    Bbmaddox89
    Not very familiar with chat rooms or these kind of things trying to get all the help I can get was reading a lot of the threads on here and it seems like there is some smart folks on here
  4. Nov 12, 2022 at 1:00 PM
    BLtheP
    Plano, TX
    There are plenty of smart folks. @Woodrow F Call just had his leaking RMS changed. It is a 1-piece seal and will need the transmission removed. It’s not the end of the world although it is a pain.
    Bbmaddox89[OP] likes this.
  5. Nov 12, 2022 at 1:02 PM
    Bbmaddox89
    It has oil coming out of what they're calling the upper oil pan shield it's a little plastic clip right above the oil pan between the transmission. If I crawl under the truck and have the wife hit the pedal I can see oil come out of that plastic shield...... In your opinion do you think that might be the main seal or hopefully something easier I can fix myself
  6. Nov 12, 2022 at 1:04 PM
    Bbmaddox89
    I appreciate any feedback thank you very much in advance
  7. Nov 12, 2022 at 3:35 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  8. Nov 12, 2022 at 4:13 PM
    Bbmaddox89
  9. Nov 12, 2022 at 4:20 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    If there is too much crankcase pressure it can cause the rear main seal to leak giving the impression that you have a failed rear min seal. I don't know about your case but it is worth looking into.
  10. Nov 12, 2022 at 4:25 PM
    Bishop84
    Bishop84 Well-Known Member
    Not common. Not work you’d do at home. It’s difficult to remove and the transmission is heavy and awkward to remove.
  11. Nov 12, 2022 at 4:43 PM
    Bbmaddox89
    I was looking at what it would take to pull the transmission out and that things huge and trying to line it back up without proper tools I wouldn't even try it maybe on my old Sonoma for Toyota RAV4 but the transmission on the Tacoma looks big
  12. Nov 14, 2022 at 12:01 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Mine had 120,000 miles when it started leaking. Cost $1100ish to repair.
    As far as removing the transmission, they do have a transmission jack.... or you can use a floor jack to back the transmission out. I didn't do mine because I really just have too much on my plate right now. I'm about 900 miles away from my truck at the moment. I don't have a flat surface to safely work on my truck, but that will change soon.
  13. Nov 14, 2022 at 6:17 AM
    Bbmaddox89
    Where was yours leaking when it was the main seal was it right above the pan from the plastic clip
  14. Nov 21, 2022 at 7:24 AM
    Woodrow F Call
    Colorful Colorado
    Basically, oil was coming out of the bell housing of the transmission.
