Does anyone know the specs of the fog light relay?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iroc409, Aug 9, 2009.
  1. Aug 9, 2009 at 10:43 AM
    iroc409
    iroc409 [OP] Well-Known Member
    Washington
    A red one
    I am looking at getting another one of these to wire in some new Lightforce lights and wanted to know if the relay (#9008087026) would handle the load. It appear the relay is used for several different items such as window relays and stuff, so I would imagine it is at least 20 amps or so. I tried Google with no luck.
    If you have the specs, would anyone also know the pin configuration?
    Thanks!
  2. Aug 9, 2009 at 8:00 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I think it's a 30 amp relay. Costs around $55. I bought a 40 amp relay from autozone when I installed my OEM foglights. Got it for much less than that and just ran my own wires.
    Here's a pinout, but I'm not sure if it's the exactly the same as the OEM relay. Should be very similar. The pin assignments are usually shown on the top of the relay too.
  3. Aug 9, 2009 at 8:08 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'm not sure of the amps, but i have my piaa 510 fogs wired completely through everything stock and i've had no issues over months
  4. Aug 9, 2009 at 9:21 PM
    iroc409
    Washington
    A red one
    Thanks for the replies!
    afd23a, that is not the same pin configuration as the relay, it looks more like what is used for the headlights and dim relay. I was digging through the 2007 wiring diagrams, and I think I figured out the pins. The relays are either 4-pin or 5 pin depending if they are SPST or SPDT.
    jhodge83, do you know what wattage those lights are? I would guess 55w, but it's just a guess. I like the looks of the PIAAs in the fog location. The Lightforce bulbs are 100w, but that shouldn't draw more than10A each, and I wouldn't think Toyota would assign a relay smaller than 20A to so many applications.
  5. Aug 9, 2009 at 10:18 PM
    The_Hodge
    SC
    yeah, they are 55w's
  6. Aug 10, 2009 at 5:09 PM
    iroc409
    Washington
    A red one
    Well the parts guy can't tell me either, except that they want $78 for one. I picked up a couple off eBay for $10 each, I am tempted to get another in case I do 4 lights down the road.
    I guess I'll just try it. What's the worst that can happen, fry the relay?
  7. Oct 18, 2013 at 2:28 PM
    shorephone
    shorephone New Member
    tacoma sport
    I have a 2007 4x4 access cab, Sport, fog lights don't work.
    Exactly where is the relay? When I hit the switch I don't here any relay click, should I?
